Old 03-03-2008, 05:48 PM   #1 (permalink)
torker8403's Avatar
Will a OPTIMA 34 RedTop Battery fit?
Will the OPTIMA 34 RedTop Battery fit my 2004 titan?
[b]2" Ready lift leveling kit, Banks exhaust, 2* Timing, K&N FIPK Air Intake, 17x9 ProComp Xtreme, BF Goodrich AT 285/70/17. Superchip! B]
TOYS-2007 HONDA TRX450R
torker8403 is offline   Reply With Quote
Old 03-03-2008, 06:10 PM   #2 (permalink)
Re: Will a OPTIMA 34 RedTop Battery fit?
You need a reverse terminal version.
http://cgi.ebay.com/Optima-Top-Post-...QQcmdZViewItem
http://www.amazon.com/Optima-Batteri.../dp/B000MS9VZA
Old 03-03-2008, 06:11 PM   #3 (permalink)
Shane06fl's Avatar
If it is the height and width yes it should fit.
Why are going with a Optima? Are you replacing the factory battery?
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 03-03-2008, 08:56 PM   #4 (permalink)
goathead's Avatar
optima R34 will fit. just did the conversion myself. you will have to do something like this so that it will work, but its well worth it. also, advance usually will have this battery in stock, where most other auto parts places will have to order it.
steve
Old 03-03-2008, 09:36 PM   #5 (permalink)
spooled's Avatar
Link isn't coming through, I would be interested in seeing this though. Also, just a heads up...those prices at Advanced are not firm. I was able to talk them down to $125 for my Optima Red Top.
-=Rick
Mobile, AL
2005 Titan Crew Cab LE 4x4 Off Road
spooled is offline   Reply With Quote
Old 03-04-2008, 12:09 PM   #6 (permalink)
Clancy's Avatar
My work firewall blocks the links too... I think what he's showing is an extention for the positive terminal side. Mine looks like your typical audio guy's terminal connector, but with a post on top to get it closer to the cable as the positive cable really doesn't have much length.
And as other have stated - it's the 34R...
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 03-04-2008, 12:17 PM   #7 (permalink)
BayStateSuks's Avatar
You will need an extension for the positive terminal. I ran a top post to power take off post cable (the kind used for dual battery set ups) and connected the existing terminal to the top post of the cable. Wrapped some electrical tape around the terminal-post of the cable to avoid any shorts. Has worked great so far.
2008 Titan SE Crew LWB 4x4
BayStateSuks is offline   Reply With Quote
Old 03-04-2008, 12:43 PM   #8 (permalink)
Clancy's Avatar
Google is coming up with nothing. I'll take and post a picture tonight...
Old 03-04-2008, 12:49 PM   #9 (permalink)
roy365's Avatar
There are two red tops......one works and one doesnt!!!! I found out the hard way. bestatchess is right.......the terminals are in different locations. And unless you want to run longer cables forget it!!!!
0-60MPH@5.60 & 1/4 mile@14.25 F/S/T
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 03-04-2008, 12:59 PM   #10 (permalink)
P2000's Avatar
Send a message via MSN to P2000
I had to modify the battery box so that my RT would fit. The adapters they provide did not secure it good enough. A dremel and a longer bolt with washers fixed it. Then just add the posative terminal extension and your golden.
2005 Silver SE CC 4X4
w/ OR,BT,UB,PP w/ Capt. Chairs
Purchased 9-1-05
Mods:
17" Enkei RT6's
BFG TA KO's
Optima RT
Tru-Trac
JBA Evol Exhaust
Volant v3 CAI
Airlift Air Bags
PRG 2" Leveling Kit
Tekstyle Profile Cover
+misc. other mods
P2000 is offline   Reply With Quote
Old 03-04-2008, 01:05 PM   #11 (permalink)
roy365's Avatar
Group 25/35
Group 75/25
Group 34 & 34R
Group 34/78
LOL......you need to get the right kind!!!!! Those are ALL red tops.
The 34R model was the one that had enough CCA. AND.............it fit!!!!
Old 03-04-2008, 01:09 PM   #12 (permalink)
roy365's Avatar
+1.
Old 03-04-2008, 04:36 PM   #13 (permalink)
Clancy's Avatar
pics...
First pic is the post extender thingy. Second is the factory hold down - only the spiffy battery box is missing because the optima is way smaller than the stock battery.
will-optima-34-redtop-battery-fit-img_0348_small.jpg  will-optima-34-redtop-battery-fit-img_0349_small.jpg
Old 03-05-2008, 07:00 AM   #14 (permalink)
goathead's Avatar
fixed the link, sorry. shoulda checked it. here is the pic. btw, this is not mine but mine looks very similar.
steve
Optima yellow or red?? Or what battery to get?? pi3yeargrad Titan Performance Modifications 33 01-26-2008 07:54 PM
optima yellow top battery Voodoo Titan Parts & Accessories 21 10-06-2005 08:21 AM
Pic of my Optima Battery and Grounding Set 1BadTitan Titan Interior Discussion 16 02-24-2005 08:26 PM
Optima Battery for Titan 1BadTitan Titan Interior Discussion 3 02-22-2005 04:09 PM
