Old 03-15-2008, 09:04 AM   #1 (permalink)
anmut's Avatar
OR Lights on Brush Guard
Anyone ever mounted OR lights to a brush/grille guard before? If so - did you drill holes in the guard rail or clamp them down? How did you secure the wiring?
Mods: Bully Dog Tuner · 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow
Nissan OEM Brush Guard · Hellwig Traction Springs · 4 Hella 500FF OR Lights · Line-X Bed Liner · Jason Topper
Wish List: Nerf Bars · Tires · Rims
Waiting For Support On: TruTrac
"I can't find anyone to race..."
anmut is offline   Reply With Quote
Old 04-30-2008, 07:44 PM   #2 (permalink)
Pops's Avatar
Re: OR Lights on Brush Guard
Bump... I'm curious about this as well. Advance Auto has a Hella Optilux 1900 complete kit for $50.00 that I'm looking at, just trying to figure out how they'll mount onto the Brush Guard.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Old 04-30-2008, 07:57 PM   #3 (permalink)
Kronos1965's Avatar
Yep!
Here's a picture of mine.
If your brush guard does not come with holes already...
1. Tap the spot where you want the holes to be drilled.
2. Drill a small pilot hole first and then widen it to the desired bore.
I recommend a long enough bolt to go through the top and bottom of the guard.
3. You may need to scrape away some of the powder coating for good ground.
lock washers and and lock bolts on the bottom, washers on the top of the grill guard (slightly bend them) to contour the guard.
4. Wiring-run the wiring from the hole through the tube to the lower grill.
5. Install the wiring as per the light instructions. You can determine if you want to run them from the fog lights or if you want to run them independently (I did that.)
Kronos1965 is online now   Reply With Quote
"Custom" Westin Brush Guard w/ Lights cav241 Buy/Sell 2 12-07-2007 02:12 PM
Brush guard on an 07 XE CC? MrHunter602 Titan General Discussion 5 09-10-2007 05:27 PM
F/S brush guard taaz024 Buy/Sell 7 07-18-2006 08:14 AM
Brush Guard $200 pImpNaTitaN Buy/Sell 6 11-22-2005 11:01 PM
Brush Guard InNae Titan Interior Discussion 14 04-12-2004 10:33 PM
