Old 04-06-2008, 10:44 AM   #1 (permalink)
Serious Ignition Problem Please Help!!!
so ive had a few issues one being i would fry the number 2 cylinder coil( this has happened twice) and the second being my fuel pump. the issue with that was i would drive somewhere, not far shut it off do what i was doing come back out and it wouldnt fire had 12 volt going to the pump. i was told that 04 and 05 titans are having fuel pump issues and to change it out so i did. well friday i was letting my truck run in the driveway and its starts to miss again, i had thought my coil issue was gone but i guess not. just as a note my truck is "bagged" so i had to move my main fuse box, it unexpectedly got wet sometime ago figured this may be causing my problems so i changed it out from a wrecked truck i found in town. started my truck up and it wasnt missing about a minute later it started to. then it started missing really bad come to find out it fried 4 voils by the time i got it shut off not sure if it would have done more or not if i kept it running. can someone please give me some sort of path to go. i was thinkin of changing my ecm but not sure if it will solve my problems. Thanks Robby
bodydropped72 is offline   Reply With Quote
Old 04-06-2008, 10:47 AM   #2 (permalink)
37L1's Avatar
Re: Serious Ignition Problem Please Help!!!
Did you ever solve your grounding problem?
2004 Titan Smoke LE CC
Born 11/18/03
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
Old 04-06-2008, 11:20 AM   #3 (permalink)
konigfritz's Avatar
IT does sound like you might have a poor ground somewhere.
Poor grounding can cause nasty problems
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, JBA Cat back
Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
http://s3.bite-fight.us/c.php?uid=180006
MOΛΩN ΛABÉ
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 04-06-2008, 11:22 AM   #4 (permalink)
i thought i did checked them all fixed some i had forgot to reattach heres a question i had to move my battery to my bed and i have it grounded to the frame rail think i should run a cable to where it used to attach in the engine compartment, the only thing is i dont remember where it used to be bolted to..i really think there is something wrong with my computer
Old 04-06-2008, 11:26 AM   #5 (permalink)
konigfritz's Avatar
there may be, if a loose or bad ground caused a voltage spike, or inconsistant voltage, you may have partially fried the computer, or caused some mild damage.
Also did you grind the frame where you attached the ground, so you had good clean contact?
Check your grounds with an ohm meter, not just a voltage tester, make sure that there is very little resistance.
Good luck
04' Galaxy CC/BT/OR
Pioneer 6900UB
2* Timing Advance
MOΛΩN ΛABÉ
Old 04-06-2008, 11:31 AM   #6 (permalink)
back in august i had an exhaust issue that melted all the wires together above the heat shield where the stock muffler goes only did about 4 inches of the harness but i was just about every wire and it did not pop any fuses so im wondering if the computer took the hit and its just gradually been gettin worse
Old 04-06-2008, 11:36 AM   #7 (permalink)
on checking the resistance do you go from a connection to frame or engine or...
Old 04-06-2008, 01:31 PM   #8 (permalink)
TitanBlue's Avatar
Absolutely maintain all original ground points! This is serious! Get a heavy cable back to the original connection. Extra grounds will be OK. I think this is the cause of your problems...
I have had 2 trucks at work, have strange problems because of a lost ground, even though battery to frame was good. One was from Block to Frame, even though other paths that looked as good, were still there. Just not the same as an original path. Never delete an original ground path, the computers and sensor are terribly dependent on very close tolerances of resistance.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 04-06-2008, 04:27 PM   #9 (permalink)
so should i think about getting another computer plus run the additional cable for ground...where did it used to attach?
Old 04-06-2008, 07:01 PM   #10 (permalink)
bump......
Old 04-06-2008, 07:46 PM   #11 (permalink)
Clint's Avatar
Go to a dealer and ask to open a hood and study where they are and take some pics and notes, good luck.
You have two choices in life:
Old 04-07-2008, 06:52 AM   #12 (permalink)
loufish's Avatar
You should have a large ground wire running from the batt to the engine, that's the way all vehs are wired, then most have a (or two) good sized wire from engine to the frame.
Remember the eng/trans mounts that isolate noise & vibration also don't conduct...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-07-2008, 10:30 PM   #13 (permalink)
well i redid my battery ground to the engine block replaced the "4" coils that burnt and fired it up ran maybe 2 minutes then i heard it starting to pop so i shut it down i dont know what else to do is there any place out there that can diag a computer id rather spend the money to diag it to make sure its the problem than spend the money on another computer and it do the same thing
Old 04-07-2008, 11:54 PM   #14 (permalink)
SOCALTITANKC4X4LE's Avatar
I see two things you need to think about.
1. When You replaced The Fuel Pump Assembly, maybe the wiring got pinched and is causing problems with The ECU or other things like relays etc.
2. You said that you moved The Main Fuse Box, maybe a wire or wires were damaged.
2005: Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b]BLUE LED DASH LIGHTS MOD STILLEN RADIATOR
1997 PATHFINDER
w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 500,000 miles . 9/06/2009. Totaled on 9/13/09. R.I.P.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 04-08-2008, 08:06 AM   #15 (permalink)
none of the wiring is damaged i just moved it up away from the upper control arm i dont know what else to do
Key wont come out of ignition Rugrat Titan Problems & Dealer Service 3 09-27-2007 10:22 AM
scratches around ignition key SpeedFreak Titan Interior Discussion 4 05-02-2007 04:24 PM
Ignition Key Sticking TXTitan05 Titan Problems & Dealer Service 14 01-15-2006 03:51 PM
ignition won't turn royjratc Titan Problems & Dealer Service 6 01-25-2005 08:23 PM
