Re: Hella Lights Wiring *Help*
1st of all, run 1 relay per pair of lights, but you can run both from 1 switch.
Since you want to be able to run them whenever, forget trying to tie into the high beams. You need a seperate switch. Then you can run battery power straight to the relays and the switch but I would recommend a 15 amp fuse to the switch.
Hope this helps.
