Old 04-17-2008, 12:11 AM   #1 (permalink)
2008 XE without keyless entry
Hi I'm new here and hope someone can help. I just purchased a 2008 XE without keyless entry and the dealer said it didn't come with it. I do have power windows and locks but reading some posts say it may/may not be compatible for keyless entry. I've priced the FOBs on ebay but I don't know if it comes with the receiver already installed. Does anyone know if I can just purchase the FOBs and program them or do I need to purchase an entire keyless entry system including the receiver?
Thanks
lilbit2378 is offline   Reply With Quote
Old 04-17-2008, 01:18 AM   #2 (permalink)
SFCIngrum's Avatar
Send a message via Yahoo to SFCIngrum
Re: 2008 XE without keyless entry
Send a PM to tgmotoman he should know.
IRC VK56 Member "Special Operations Crew Chief"
2008 Red Alert CC LE - Nismo CAI, Advance Cover quad-folding tonneau, 2* Advance, Keypad, Third Barke Light Billet, Black Altezza Tail Lights, Banks Exhaust, Powder Black Grill Gaurd, Billet Grill, Xenon Headlights, Tailgate Mod, PRG Shackles, **BULLYDOG TUNED**, Tech12volt under front seat subs
Current:
http://s285.photobucket.com/albums/l...E%20Build%202/
Gone but not forgotten:
http://s285.photobucket.com/albums/l...LE%20-%20Gone/
Wife's Ride:
http://s285.photobucket.com/albums/l...%20Versa%20SL/
SFCIngrum is offline   Reply With Quote
Old 04-17-2008, 01:59 AM   #3 (permalink)
Mars's Avatar
I also have an XE w/o keyless entry. From what I was told, you have to buy the whole system. There is no receiver for the FOB on the XE models. Just get an alarm with keyless entry, that's what I did.
Performance Mods: Uprev Tuned, AEM Brute Force, Volant Exhaust
For looks: 22" Elite wheels, Maxxis Marauder II 305/45/22, Chrome TIS 22" Badges, Chrome LED 3rd Brake Light, Chrome/Black Altezza Tail Lights, Armada Air Dam, 4300k HID kit
Mars is offline   Reply With Quote
Old 04-17-2008, 04:06 AM   #4 (permalink)
Brundy's Avatar
All I had to do for my 06 XE was buy the fobs. The rest was already installed.
If I remember correctly, to program the truck, slide your key in and out of the ignition until the dash lights flash, then hold the lock button on the fob until the doors lock.
Brundy is offline   Reply With Quote
Old 04-17-2008, 05:15 AM   #5 (permalink)
My 08 XE CC with the preferred package has keyless entry. I think I had to get the preferred package to get it, but power windows and locks are standard on the CC XE, but not available from the factory on the KC XE.
08 CC XE Galaxy Black Big Tow Preferred Package Spray-in Bedliner Westin bull bar Westin chrome nerf bars
07 Ford Focus SE For when I need gas mileage
bubbs71 is offline   Reply With Quote
Old 04-17-2008, 09:16 AM   #6 (permalink)
I have the XE without the preferred package and I tried to have them get me the keyless entry clicker at the dealership and they said they cant do it. Im just going to go ahead and get a remote start.
SDHQ SERENA is offline   Reply With Quote
Old 04-17-2008, 09:25 AM   #7 (permalink)
HudsonValleyTitan's Avatar
Thanks
For 08, keyless entry is only available on an XE if it's a CC and has the PR package. XE KCs can't have it...even with the PR package.
- Joe
Old 04-17-2008, 10:24 AM   #8 (permalink)
I have the 2008 XE CC without the preferred package. I just don't want to purchase FOBs and not have them work if there isn't a receiver installed.
Old 04-17-2008, 11:49 AM   #9 (permalink)
It's hard to say. My guess is that all you need is the keyfobs themselves because you have the power windows etc. It's been done here before where members just bought the fobs and programmed them. No idea why the XE KC can't have keyless and the CC XE can though. You can always return the fob to the dealer if it doesn't work out.
- Joe
Old 04-17-2008, 12:52 PM   #10 (permalink)
i have a 07 CC XE. the dealer tried to program a FOB but couldn't get it to work. I read somewhere on here that there is a way to change the programming options with consult II. have yet to get it back to the dealer to try this
i can't post links yet, but search user "cpaul" and "07 XE Keyless Entry" as the title
Ok, I figured this would happen so I went out yesterday evening and programed a 07 cc XE w/power windows and locks just to make sure I wasn't crazy. To perform this procedure hook up Consult and select Nissan and give it a few minutes to load. In the menu you will have selections like engine, trans.,abs,bcm,airbag,hvac, and so on. not in that order. Select bcm. then select bcm again. Scan down the list till you see configuration and select. You have two options. one is read configuration and the other is write configuration. Select write configuration and when the screen pops up to only do this when replacing bcm select ok or yes don't remember which it says. When you see the next screen it will say manual setting item over two columns. First column will say over the top of it Item. The second will say Set Val. Under the column that says Item there will be one that says Keyless Entry, across from it under the Set Val column is the current setting. If it says With then your truck is already set up for it, if it says Without then tap the screen over the word Without and it will change to with. Then press change and it will start to print the list of manual setting items and the list of auto setting items. I will also have the part # of your bcm which should be 284B2-ZJ20A. Then press OK. Since you are already in the bcm area go to the part to program the remotes and program them. I have the Consult printout where I did this in my hand but for some reason my scanner does not want to scan them or any thing else for that matter. Oh the part where it says auto setting items the dealer cannot touch. I know it would be tempting to try to change some of these other items because I have read a bunch of other threads about some of them but the dealer can't.
silverslayer is offline   Reply With Quote
Old 04-17-2008, 02:43 PM   #11 (permalink)
Thanks for the advice! Where do I go to change the programming with the consult II? Is this something I can do or does it have to be done by the dealer?
Old 04-17-2008, 03:11 PM   #12 (permalink)
The dealer has to do it and for 08, it's the consult 3. They can turn certain options on and off thru that handheld. Talk to someone in service...or the service manager.
- Joe
Old 04-18-2008, 08:11 AM   #13 (permalink)
JohnS's Avatar
08 XE king cab does not come with power windows or locks, in the brochure the are listed as N/A on KC, so no locks mean no remote enty
John
JohnS is offline   Reply With Quote
Old 04-18-2008, 03:21 PM   #14 (permalink)
John
You may be right.
- Joe
Keyless Entry bigpic87 Titan Parts & Accessories 1 09-29-2007 10:33 PM
keyless entry? christo Titan General Discussion 14 03-23-2007 08:20 AM
keyless entry greenwade Titan General Discussion 6 02-21-2006 09:44 PM
Keyless Entry Dpol4 Titan Parts & Accessories 9 02-22-2005 08:54 PM
Keyless entry. mrpink Titan General Discussion 2 10-29-2004 02:42 PM
