Old 04-24-2008, 06:01 AM   #1 (permalink)
Towing Question
This may seem like a silly question. I just got a 2006 Nissan Titan. I pull a bass boat that weighs about 1900 lbs. The manual is somewhat vauge on the towing aspects. When I tow the boat and put it in tow mode, do I need to go to 4th gear or do I leave it in drive and the tow mode makes the necessary adjustments so I don't kick into overdrive? I do not want to cause any transmission trouble. Thanks for any advice.
Titonkid is offline   Reply With Quote
Old 04-24-2008, 07:07 AM   #2 (permalink)
Re: Towing Question
if it starts to down shift on its own then put it in 4th. thats not alot of weight so you wii just have to see what it does also if you have alot of hills where your at then most likely you will have too put it in 4TH
08 Pro-4x moonroof,Tow,DVD,SWB.. melting in Az
adkl1 is offline   Reply With Quote
Old 04-24-2008, 07:12 AM   #3 (permalink)
vipzach's Avatar
Re: Towing Question
Do you have the BT on your truck? That tranny temp gauge can be your best friend!
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
49 20 77 68 6f 72 65 2c 20 74 68 65 72 65 66 6f 72 65 20 49 20 61 6d 2e
vipzach is offline   Reply With Quote
Old 04-24-2008, 07:27 AM   #4 (permalink)
Carbeaux's Avatar
Re: Towing Question
Combine what both of the above posters have said. It's not a lot of weight, so you'll probably be fine in 5th, but if you have the gauge, watch it. If it starts to climb, put her in 4th. The tow mode will not make the adjustment to keep you of ouf O/D, it only raises the shift points in the first 3 gears to help you get it all moving more easily.
Hook 'Em Horns!
"A veteran is someone who, at one point in his life wrote a blank check made payable to "The United States of America" for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it."
Towing question.....obviously! robby1824 Titan Towing & Hauling 11 11-15-2007 01:48 PM
towing question titan14 Titan Towing & Hauling 9 05-10-2007 11:09 PM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 02:03 PM
Question about towing CoachBoone Titan General Discussion 17 07-19-2004 09:02 AM
Towing Question smhinds Titan General Discussion 1 04-28-2004 05:49 PM
