Go Back   Nissan Titan Forums > Titan Discussion > Titan General Discussion
User Name
Password
Help with crazy sound @ 1300RPMS (sound clip) - being discussed at Nissan Titan Forums in the Titan General Discussion section.
Old 04-30-2008, 03:42 PM   #1
trogers
Unhappy Help with crazy sound @ 1300RPMS (sound clip)
Hey Guys,
I have been having a problem the last 6 months. Anytime I am driving at 1200-1400 RPMS, I get this crazy rattling/vibration sound coming from my engine (I can't really describe the sound, you will have to hear the clip).
I had my girlfriend hop in today and hold it at 1300rpms in park while I crawled under and took the sound clip.
Obviously its usually intermittent because I am never holding on 1300 rpms when I am driving, but it its load as hell and I know there is something wrong.
It has gotten progressively worse the past 6 months.
Any idea what it is? I wanted to see if it is something that I can fix before I pay the dealership to do so...
Any advice would be welcomed!
Here is the link to the clip...
http://media.putfile.com/Nasty-sound-82
trogers is offline   Reply With Quote
Old 04-30-2008, 03:45 PM   #2
Carbeaux
Carbeaux's Avatar
Re: Help with crazy sound @ 1300RPMS (sound clip)
Does it sound like it's coming from the cats?
Hook 'Em Horns!
- Frank Zappa
Old 04-30-2008, 03:46 PM   #3
Amadeus
Amadeus's Avatar
Heat shield rattle?
Use to have that problem on another vehicle I owned.
Yours sounds like a thin bit of metal from what I can hear, so start with every thin piece of metal on your undercarriage and try to wiggle it.
2005 LE 4x4,Big Tow,Leer 700 tonneau
Flowmaster 40 with dual 18" tips,Parrot 6100
XM XPress RC,Weathertech mats,K&N Drop-In w/ redneck mod,5% tint
and full insurance coverage with KIMBER, USA
Amadeus is offline   Reply With Quote
Old 04-30-2008, 04:12 PM   #4
ablexus
ablexus's Avatar
Send a message via AIM to ablexus
99% chance of heat shield rattle. Get under your truck and look at the cats, then grab the aluminum heat shields (wait for the engine to cool down!) and see if they're loose. If they are loose, either tear them off or you can bind them down. Dealers actually use zip ties more often than not and it seems to work without melting or breaking off.
Andrew
Here's my truck and an angry little force-fed 4-banger:
I'm looking for a chrome bug shield and a sub box for under the rear bench seat. Please PM me if you have one / know where one can be located.
ablexus is offline   Reply With Quote
Old 04-30-2008, 04:15 PM   #5
titanmoon
I've had my 04 in a couple of times for heat shield rattle when it was still under warrantee. This week it got really loud- you could hear it when the sound was reflected at a drive thru and even on a freeway ramp.
Get under the truck with it off and bang on the exhaust with a rubber mallet. My heat shields rattle like crazy.
Not sure how to cure- maybe a hose clamp around the shield where it rattles against the pipe?
My shields also make a clicking noise constantly w/ engine running and as it cools down after running.
2004 Titan SE 4x4 Offroad
Big Tow
Utility bed package
Popular package w/bench
titanmoon is offline   Reply With Quote
Old 04-30-2008, 04:28 PM   #6
sudden urge
sudden urge's Avatar
Wow, that does sound nasty!!!! I have no idea what it is though.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software, best 1/4 mile time of 14.660@93.14 MPH running BD reg 87 tune +2 timing and DA@1830'. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 04-30-2008, 04:28 PM   #7
ablexus
ablexus's Avatar
You CAN remove them without much issue; their main purpose is to retain heat so the cats heat up faster to eliminate unburnt fuel.
But you know what I say, pour oil on a seagull and fvck the environment!
Andrew
Old 05-01-2008, 12:15 AM   #8
trogers
Thanks for the replies guys. Seems like most of you think its the heat shield vibe. I will definitely look into that. An easy fixed like I hoped!
But dang, a simple heat shield can make a helllll of a lot of noise. As one of you mentioned, in a drive through or overpass, that think is SO loud!
Old 05-01-2008, 07:32 AM   #9
HRTKD
HRTKD's Avatar
I had the heat shields on my '91 Ranger rust enough that the brackets broke and the shields started to rattle. What a nasty noise. I was embarrased at intersections (and not just for driving a Ford!). I pulled them off and now there's no more noise. I was told that the reason they are there is to prevent the heat generated by the catalytic converters from sinking into the bottom of the cab.
Still, your noise sounds like an internal mechanical noise not an external rattle. Maybe I'm hearing it wrong though. Try using some wire to hold down the heat shields as a test.
«ClearBra, Leer 100XQ, MM SI9500 Winch, Airaid TBS, Volant PowerCore, AMSoil in everything but the transmission»
«SAW Coilovers and rear shocks, PRG upper control arms»
Jim
Old 05-07-2008, 04:10 PM   #10
titanmoon
Found my rattle! One of the narrow bands that clamp the heat shield to the cross pipe was broken, rattling. Amazing how something so simple could make so much noise. At start up or reving engine or even on a freeway ramp it sounded like maybe the timing chains were rattling inside their covers!
User Name
Password
S&B cai sound clip Chevy4740 Titan Pictures & Media Post 1 05-28-2007 01:09 PM
Stillen sound clip juganaut Titan Performance Modifications 1 05-13-2007 07:33 PM
Sound Clip V8 TITAN Titan Performance Modifications 0 12-17-2006 06:26 PM
Sound CLip?? Titanguy86 Titan General Discussion 6 02-03-2005 06:18 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
