Old 04-30-2008, 08:50 PM   #1 (permalink)
cobra989's Avatar
radio question....
hey guys i looked to see if there were any threads and i couldn't find an answer... SO... usually when its cold outside and i go to start my truck in the morning i look at the radio and it freezes, like i will adjust the volume and the volume number will be frozen on the screen. THEN i will play with the temperature knobs and the air speed levels and the screen will.. for lack of a better terms, freak out and display gibberish on the screen. like i said it usually only did this when it was cold but today it did it too and it was 65 degrees outside this morning. anyone else had this problem?
in the competition between 2007 nissan armada vs. 2004 chevy impala... the impala looses every time... well i totaled both cars so no one really won did they...
2006 nissan sentra SER Spec-V- traded for 2006 Armada
2006 Nissan Armada gone with the Impala
cobra989 is offline   Reply With Quote
Old 05-01-2008, 02:41 PM   #2 (permalink)
Clancy's Avatar
Re: radio question....
Pop the radio faceplate off (the whole thing - from the curve in the top of the dash down under the heater controls). A flat screwdriver gently slipped in the joint at the top and a gentle tug will free the whole thing.
There is a small cable that connects to the radio display on the passenger side of the faceplate. My guess is that it's pinched between the radio and the faceplate (you'll see what I mean when you go to put it back on).
Im not sure how it's related to the heater controls because they each have their own wiring harness, but it's worth a peak and takes less then 2 minutes...
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Radio question bvr127 Titan Visual & Audio Discussion 6 07-31-2007 09:25 AM
I have a radio question for an 06... Your Friend Titan Interior Discussion 0 10-03-2006 09:32 PM
XM Radio Question TexasTitan04 Titan Interior Discussion 8 02-08-2005 07:03 AM
XM Radio question Kal Titan General Discussion 24 04-26-2004 12:02 PM
XM Radio Question darius2112 Titan General Discussion 2 04-26-2004 11:39 AM
