Old 05-08-2008, 05:32 AM   #1 (permalink)
rear diff gear oil...amsoil, mobil, or royal purple??
the forums here have me sold that I can do this easy....just need to know which gear oil to get...I know it is 75-145....I will be towing a trailer at times..not full time..........28K on her (first diff change!)...05 SE 4x4........basically I will be doing the 30K service myself. What specific goes into the transfer case?? I am a little confused..is this the same thing as the front diff???...thanks!
robby1824 is offline   Reply With Quote
Old 05-08-2008, 05:39 AM   #2 (permalink)
54warrior's Avatar
Re: rear diff gear oil...amsoil, mobil, or royal purple??
It's easier to change than your motor oil.
It requires 75W-140 NOT 75W-145 as you posted. I used Valvoline from AutoZone, about $16/qt.
I believe the front diff. requires something different???
Not sure what the T-Case requires either.
Old 05-08-2008, 06:13 AM   #3 (permalink)
Blackbeauty's Avatar
I just changed all mine with Amsoil Severe Gear....
Rear takes 75W140
Front takes 75W90
Transfer case takes Amsoil ATF.
It's a high quality fluid and if you contact the right rep, cheaper than the Mobil1 or even the Valvoline that 54 mentioned... I did all of it for about $80 shipped to me. Mobil1 would have cost me over $105 with tax at Autozone.....
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Blackbeauty is online now   Reply With Quote
Old 05-08-2008, 06:14 AM   #4 (permalink)
VA06TITAN's Avatar
For the rear differential, you can try 75W-140 (retails for $14.65/qt) http://www.amsoil.com/storefront/svo.aspx
For the front differential, you can try 75W-90 (retails for $12.15/qt) http://www.amsoil.com/storefront/svg.aspx
For the transfer case, try Universal Transmission Fluid (retails for $9.55/qt) http://www.amsoil.com/storefront/atf.aspx.
If interested shoot me a PM and I can save you about 25%.
AMSOIL Independent Dealer
Email: cwsynthetics@msn.com
Web: www.lubedealer.com/cwsynthetics
VA06TITAN is offline   Reply With Quote
Old 05-08-2008, 06:15 AM   #5 (permalink)
^^^^DING DING DING...... We have a winner! That's the way to go!
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 05-08-2008, 08:36 AM   #6 (permalink)
HRTKD's Avatar
+1 to the AMSoil. If you order from AMSoil consider getting the bottle pumps also. It makes putting the gear oil into the transfer case and differential a lot easier and a lot cleaner. You'll want two pumps. One for the differentials and the other for the transfer case.
Jim
Old 05-08-2008, 10:05 AM   #7 (permalink)
TYTAIN's Avatar
I prefer AMSOIL also, but have had good luck with Mobil 1, not to sure about the purple stuff.
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 05-08-2008, 10:21 AM   #8 (permalink)
Juday's Avatar
+1 to AMSOIL products. I have the 75W-140 in the rear, 75W-90 in the front and the AMSOIL ATF in the T-case. Like mentioned before, make sure you buy two pumps to go along with them (it'll make life much easier).
I'm a customer that likes the products so much, I bought the company...or at least their Preferred Customer membership.
Changing all of those is easier than changing the engine oil (no filters involved). Make sure you read the "How To" threads about all of them. It makes it a breeze.
Here's something you might find helpful:
http://www.amsoil.com/scripts/runisa...msoiloaf:index
Good luck!
285/70/17 BFGoodrich All-Terrain T/A KO
DIY Air Box Mod w/ Drop in AMSOIL EaA Air Filter
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
Old 05-10-2008, 04:22 PM   #9 (permalink)
Just finished!!!!!!!!!...........VERY easy, except I put the non-magnetic plug in the bottom and filled it with one quart before I realized it!!!!!!!.....quite the pain to re-drain into the bottle...par for the course for me tho to do something that brain dead.........I went with the purple...my tire/oil guy said it was good, and I got it for 9.99 a quart at pepboys for the 75-140...used the high temp permatex............never would have tried this without this forum..THANK YOU ALL!!!!!!!!!
Old 05-10-2008, 04:25 PM   #10 (permalink)
FYI.........we buy folgers coffee at costco and I save the big plastic containers...perfect for the draining.......tackling the airbags next!
Little over 2 quarts got me filled...........
Royal Purple???? import2nr Titan General Discussion 4 05-05-2006 02:23 PM
Royal Purple, Amsoil, or Mobil 1 for the Diff's.?? carpediem425 Titan Engine, Transmission & Drivetrain 41 04-14-2006 05:54 PM
What weight Royal Purple synthetic for diff new man Titan General Discussion 9 02-01-2006 06:07 AM
Royal Purple good for 9 rear wheel horse power (Horsepower TV Video) markislive78 Titan Performance Modifications 90 01-04-2005 01:51 PM
