Old 05-18-2008, 03:29 PM   #31 (permalink)
Re: Nitrogen inflated tires...
oh and as for wear or gas mileage, I have no opinion on that.. except it might make a little sense that if the pressure is low for the first few miles, that might would cost you a few drops of gas?
CessnaSovereign is offline   Reply With Quote
Old 05-18-2008, 04:08 PM   #32 (permalink)
loufish's Avatar
From a Corvette owner with the time pressure system which gives digital readouts on the dash screen of tire pressure, each morning the pressure would be 3-5 psi lower per wheel until it was driven.. when I filled it up with nitrogen (I have a nitrogen tank) there was no fluctuation..
Not going to change your milage, not going to make your tires last longer....
Did you do an evacuation of the tires before filling with Nitrogen, or was there plenty of air still left in before you filled up?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Air vs. Nitrogen filled tires PennTitan Titan General Discussion 34 11-16-2007 10:24 AM
Nitrogen lilguy Titan General Discussion 8 08-31-2007 08:03 AM
Got Nitrogen? CoeCEO Titan Wheels, Tires & Brakes 27 06-14-2007 03:54 PM
Got Tires filled with Nitrogen. gratefullife Titan Wheels, Tires & Brakes 56 02-28-2007 07:54 AM
Nitrogen for Tires Tx_flip Titan Wheels, Tires & Brakes 36 05-07-2006 07:55 PM
