Old 05-15-2008, 03:59 AM   #1 (permalink)
TPMS light on. All tires at 38 PSI
Hi all. My TPMS light has been on for a few days on my 08 SE. I thought this was unusual because my truck has 1800 miles on it. So I finally got around to manually checking the PSI, and all tires are at exactly 38 PSI. So what gives here? Anybody have this problem before? Already brought the truck on the highway to attempt to reset the TPMS, light is still on.
08TitanSE is offline   Reply With Quote
Old 05-15-2008, 06:29 AM   #2 (permalink)
Re: TPMS light on. All tires at 38 PSI
Malfunction prob, take it back to the dealer since it should still be under warranty. Mine only activated when pressure was low and from what I hear those things are very expensive so let the dealer foot the bill. Hope you get it resolved.
Jfree is offline   Reply With Quote
Old 05-15-2008, 06:32 AM   #3 (permalink)
cneary812's Avatar
make sure that all 4 tires have the sensors in them first off. If you have a regular rubber valve stem in any of them then that tire does not have one in it. That will cause the problem. If they all have it then take it in to the dealer.... but if it does not have one then you need to scream at your dealer for selling you a truck without one on it.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 05-15-2008, 07:14 AM   #4 (permalink)
Mars's Avatar
The TPMS light will also light up if it senses a piece of metal. Do you have a nail/screw in any of your tires?
Performance Mods: Uprev Tuned, AEM Brute Force, Volant Exhaust
For looks: 22" Elite wheels, Maxxis Marauder II 305/45/22, Chrome TIS 22" Badges, Chrome LED 3rd Brake Light, Chrome/Black Altezza Tail Lights, Armada Air Dam, 4300k HID kit
Mars is offline   Reply With Quote
Old 05-15-2008, 08:11 AM   #5 (permalink)
tnbowhunter's Avatar
Ditto, either that or one or more of your sensors are bad.
2001 Polaris Sportsman 500.
Old 05-15-2008, 10:25 AM   #6 (permalink)
I don't think so unless there is with no leak. I'll take it to the dealer today after looking for screws/nails. All four tire do in fact have the TMPS, and I've had the truck for 4 months without prior problems (with the TMPS anyway)
Old 05-15-2008, 11:26 AM   #7 (permalink)
chargedTitan's Avatar
Take to dealer and have them pull the code. Even if the light has turned off it will still have a code stored. I went through this with mine. Ended up being a bad sensor. Replaced, and no problems since.
06 CC LE -offroad, tow, nav, dvd, sunroof, srs
K + N 77/Stillen hybrid CAI
Borla dual cat back
295 70r17 toyo mud terrains
DR coilovers
Stillen grounding kit
Stillen sway bar
Stillen supercharger
chargedTitan is offline   Reply With Quote
Old 05-16-2008, 12:03 AM   #8 (permalink)
TITAN DOHC V8's Avatar
Send a message via AIM to TITAN DOHC V8
did you check the spare tire for a tpms sensor and the pressure in that tire?
2004 NISSAN TITAN CC LE 4X4 (born 4/04): BONE STOCK FOR NOW
2003 HYUNDAI TIBURON GT: FEW BOLT ONS
1996 FORD PROBE GT AUTO: NEEDS MAINTENANCE WORK DONE
1994 FORD PROBE GT 5 SPEED: RUNS LIKE A CHAMP
1993 FORD PROBE GT 5 SPEED: WITH A BLOWN ENGINE
1987 TOYOTA SUPRA(NON-TURBO): NEEDS A PAINT JOB AND A TURBO KIT!!!!
TITAN DOHC V8 is offline   Reply With Quote
Old 05-16-2008, 12:05 AM   #9 (permalink)
ignore it, it doesnt work, never worked, never will work...........
mine has been a shiny yellow light since day 2 and 3 miles on the odo
My TT status expired! Time flies! Please don't thank me in any posts. I never cared for that nonsense and in fact hate it. So dont do it!
gyrate is offline   Reply With Quote
Old 05-16-2008, 12:05 AM   #10 (permalink)
wow
1. the spare does not have a sensor
2. even if it had, it would not be factored into the system
Old 05-16-2008, 06:11 AM   #11 (permalink)
cneary812's Avatar
titan only has 4 sensors, spair does not come with one.
airbox mod with K&N
Old 05-16-2008, 08:10 AM   #12 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
i've noted my sensor comes on during trips after 45 minutes of highway driving speeds......
and that is the only time it comes on. i always check fluids, tire pressure, etc. before leaving for any trip.....
2° | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is offline   Reply With Quote
Old 05-16-2008, 08:15 AM   #13 (permalink)
Wiscdave's Avatar
you must not have the right sensors or they need to be set to go with your system...
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
Old 05-16-2008, 10:07 AM   #14 (permalink)
DeadRiver's Avatar
that raises a question: how do you know if they are wrong? typically my tires are never low......
i'm upgrading to 20's and don't plan on adding the sensors to those... why bother?
The Urinator™
Old 05-16-2008, 11:26 AM   #15 (permalink)
cneary812's Avatar
hmm they are supposed to be a safety feature but they don't have to be there. would the stock TPMS fit in the new rims? If so if I were you I would swap them over. But thats just me, heck why not just disconnect your ABS fuse and airbag sensors while your at it jk
airbox mod with K&N
F/S 06 LE Wheels/Tires - No TPMS sstitan Buy/Sell 25 07-30-2008 10:23 PM
TPMS-tire pressure warning light whiteLE Titan Problems & Dealer Service 22 01-13-2008 07:25 AM
LE TPMS - which tires are listed? Trick Titan Wheels, Tires & Brakes 7 09-20-2007 05:20 AM
XE Wheels, Tires, TPMS FFtitan Buy/Sell 9 07-27-2007 07:05 PM
FS:xe silver wheels with tires and tpms jakes Buy/Sell 2 03-19-2007 06:42 PM
