Old 05-22-2008, 08:55 AM   #1 (permalink)
Camber Kit?
Hi
Has anyone found a good camber kit for a 2008 1/2 nissan Titan quad cab? My truck has 3400 miles on it and I had the front end done at a local front end shop. This guy sets up cars for the NationWide Nascar Series. He sugests a camber Kit.
Bill
boltsy is offline   Reply With Quote
Old 05-22-2008, 09:12 AM   #2 (permalink)
Pops's Avatar
Re: Camber Kit?
Do you mean something like replacing the Straight Bolts with Cam Bolts so you can adjust your camber??? I don't think the 2008.5 are different than pre-2008 other than having a longer spindle so I think the kit in this link might work but I could be wrong.
http://www.yournissanparts.com/catal...19767&detail=1
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Old 05-22-2008, 10:33 AM   #3 (permalink)
Shane06fl's Avatar
Re: Camber Kit?
Why are you having your front end aligned at 3400 miles? That is covered under warranty during the adjustment period. If they can't adjust the camber properly under warranty the should install the camber bolts for free.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Camber Kit ArmyAviation Titan Suspension 24 11-01-2008 09:29 PM
Camber adjuster dbolemiss Titan General Discussion 15 07-20-2007 09:53 PM
Camber adjuster dbolemiss Titan General Discussion 2 07-15-2007 10:59 PM
Camber TSB Quartz Titan Suspension 18 01-17-2007 05:33 PM
camber kit northtextitan Titan Suspension 7 11-14-2006 11:22 AM
