Old 06-05-2008, 10:36 AM   #1 (permalink)
TankTitan's Avatar
Angry Driver Side Power Window Issue
I'm having an issue with my drivers side power window going up and down. It is EXTREMELY slow whether its going up or down. I try not to roll it down much because I feel that it may get stuck. Today it went down and wouldnt go back up. I waited a minute or so then tried to roll it back up and it worked. I've been reading some of the posts on here about power window issues. Before I take the door panel off and start digging, has anybody else had this issue? I know some of you said the switch was your problem. By the looks of it, I'm leaning more on the motor. Any help would be great!!
TankTitan is offline   Reply With Quote
Old 06-05-2008, 11:02 AM   #2 (permalink)
Blackbeauty's Avatar
Re: Driver Side Power Window Issue
Yes. The motors on them are weak, and they do go.. The rear doors are usually worse. But one thing that helps is to keep the window tracks lubricated. The less friction the mechanism needs to overcome, the longer it will stay functioning well.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 06-05-2008, 12:19 PM   #3 (permalink)
djmars20's Avatar
I heard somewhere that better grounding helps a little.
04 4x4 CC XE
NCD 2" level kit
2* Timing Advance
Air box mod w/ k&n filter
"If you don't want to stand behind our troops then by all means, stand in front of them!!!"
djmars20 is offline   Reply With Quote
Old 06-05-2008, 02:17 PM   #4 (permalink)
Mine is only slightly slower, thanks for the tip
TheRidge is offline   Reply With Quote
Old 06-05-2008, 08:48 PM   #5 (permalink)
Treebasher's Avatar
My driver side has always been a bit slower than the passenger side, since day 1. Never have I been concerned that is was not going to come back up. It sounds like the motor is weak and possibly on the way out.
Born on 01/2004
K&N Filter Charger and prefilter...........Stubby antenna
Westin Bull bar.........................................Front tint
PRG leveling kit........................dss90c LED bed lights
Access tonneau cover.................Stainless bug guard
GT seat covers.........................Tailgate assist spring
Husky floor mats.............Tailgate key fob locking mod
Banks "Monster" exhaust.......................Keyless entry
AT grounding kit................................HID headlights
Grille inserts.....................295/70 R17 Nitto Grapplers
Alum. rear diff. cover...........................HID fog lights
next?
Treebasher is offline   Reply With Quote
Old 06-05-2008, 09:36 PM   #6 (permalink)
Nissan-Addict's Avatar
Nissan is known for that I guess!! My pathfinder has a slow Passenger front. I thought it was the tint, but I m starting to beleive it is the motor.
Nissan-Addict is offline   Reply With Quote
Old 06-18-2008, 10:22 AM   #7 (permalink)
I also have a problem with my drivers side window. Most of the time when I try to roll it up, it will go half way then go back down. Now it won't work at all. Fortunately it quit working with it in the up position. Any ideas would be appreciated. All other windows work just fine.
Motor replacement or something eles?
jmponde is offline   Reply With Quote
Old 06-18-2008, 10:58 AM   #8 (permalink)
If you hear a solenoid click when you use the switch, that means the switch is ok, so then the motor is the culprit. If you don't hear the solenoid click, then replace the switch.
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle is offline   Reply With Quote
Old 06-18-2008, 11:11 AM   #9 (permalink)
You can try and lubricate the window run-rubber with some penetrating fluid, that seems to work better than spray lube or spray grease. you just have to clean the window off afterwards!!
-Jamie
Check out our site:
www.titanparts247.com
Titanparts1 is offline   Reply With Quote
Old 06-18-2008, 07:23 PM   #10 (permalink)
My driver side window is also slow and makes creaking noises when going up. Plan on cleaning the track and lube it up this weekend.
04 se retired, 06 se, aem cai,flow master 50,sway-a-way shocks,prg traction bars,kmc xd122 rims,
bullittdave is offline   Reply With Quote
Driver Side Window Malfunction! Kortiz Titan General Discussion 3 01-22-2008 06:51 PM
On windy days air gets though the driver side window. Jeostang Titan General Discussion 39 01-10-2008 09:34 PM
front driver side window... white_titan05 Titan Interior Discussion 4 03-06-2007 10:02 AM
Driver side Window STF Titan General Discussion 10 12-01-2004 01:29 PM
Driver Side Power Window Issue smoketitan Titan Problems & Dealer Service 8 07-29-2004 10:01 PM
