Old 08-03-2008, 11:36 PM   #31 (permalink)
vilim12's Avatar
Re: tow vs big tow
Our salesman referred to it as big tow?
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Stock For Now
vilim12 is offline   Reply With Quote
Old 08-04-2008, 12:11 AM   #32 (permalink)
HRTKD's Avatar
Re: tow vs big tow
I'm not sure how the term "Big Tow" got started. It's just how we refer to the Tow Package.
Jim
Old 08-04-2008, 12:16 AM   #33 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: tow vs big tow
well i will straighten this much out, you dont have the big tow package just cause you have an overload spring, nor does the absl help or come on, on a 2007 2wd se. i have one and my absl light has never come on or if there isnt a light it dont work. i have a 17' 8" boat weighing about 5600lbs and it will pull it out of a boat ramp(if it isnt too steep) just fine. you just have to easy on the gas, hold the brake then easy into the throttle. i have sank my truck to where the bed was in the water cause i have a 14' flat bottom i launch right out of the bed, lol. i know it is redneck but i have not built a trailor or bought one and havent had a problem with it so i just keep doing it. i have an overload spring as well. i have pulled alot of things with my truck. 10,000lb camper for work 33footer, 7800 56hp john deere diesel tractor, 6000lb generator/light plant for work, these trucks are hosses. truck was bought new in may of 07 and has 36000 miles and have not had a drop of problems out of it.
"PIT CREW" 2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
POSSIBLY 4-LINK THE REAR END
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, AMERICAN RACING VICTOR TEFLON 17X8, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 38.5x14.50x17 PRO-COMP XTREME AT'S, 3" BODY LIFT, HITCH, JENSEN IN DASH DVD 7" MP3/WMA/CD/, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, BLACKED OUT CCFL HALO PROJECTOR LIGHTS, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS,
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 08-04-2008, 09:08 AM   #34 (permalink)
HudsonValleyTitan's Avatar
Re: tow vs big tow
Initially, BIG TOW was the actual name of the tow package. Yota has a CT or Camel Tow package.....don't confuse the two!
- Joe
Old 08-04-2008, 09:11 AM   #35 (permalink)
Re: tow vs big tow
Unless your truck has the Trac Package, you don't have the rear wheel ABLS. Probably why you've never seen the light.
- Joe
Old 08-04-2008, 09:14 AM   #36 (permalink)
Quartz's Avatar
Re: tow vs big tow
Originally Posted by GFC-TITAN View Post
And to further confuse everyone and throw everyone off...2005 SE 2wd with BIG TOW package....and came with front tow hooks.
My 06 2wd SE with Big Tow came with tow hooks also.
Old 08-04-2008, 10:39 AM   #37 (permalink)
Re: tow vs big tow
2008.5 Mine did not come with any tow package, had to have a reciever hitch installed, still researching to find out if the truck has the wiring harness for the 7 pin plug that goes at the hitch for the brake controller. My truck does have the Transmission temp gauge though.
Big Kahuna is offline   Reply With Quote
Old 08-04-2008, 10:51 AM   #38 (permalink)
Re: tow vs big tow
That's because you have the Trac Package on a 2WD SE.
- Joe
Old 08-04-2008, 10:52 AM   #39 (permalink)
Re: tow vs big tow
From 04 to 08, you had to have the Tow Package to get the tranny temp guage. From 08.5 to 09, the all have it standard. And according to the 09 brochure (not sure if there was an 08.5 book), you have to have the Max Utility package to get the under dash wiring harness and the 7 pin trailer connector.
- Joe
Old 08-04-2008, 11:36 AM   #40 (permalink)
Re: tow vs big tow
I have not really taken the time to get up under the truck and dash to see if the harness is there or not. It would seam like regardless they would put it there when they are wiring the frame, but who knows. I use to have a 8x16 enclosed trailer with elec brakes, I sold my half to my race partner (we race Jetski's), I can still borrow the trailer if need be, but dont know if I will. If I dont, then I can just hook up a regular set of pigtails for regular trailer, but am thinking I may need to just go ahead and be prepaired.
Old 08-04-2008, 09:36 PM   #41 (permalink)
rtc1184's Avatar
Re: tow vs big tow
my truck does not have the trac package. no tow hooks, 2wd, kc, bottom of the barrel, it didnt even have badges saying that it was a xe
BIG BRAKE UPGRADE
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
MODS DONE!
Old 08-04-2008, 10:05 PM   #42 (permalink)
Re: tow vs big tow
That's right, there is no truck badged XE. It's just says Titan and 5.6
- Joe
Old 08-04-2008, 10:24 PM   #43 (permalink)
rtc1184's Avatar
Re: tow vs big tow
Thanks didnt know that, but i know my truck definetly needs a locker or the tru trac
BIG BRAKE UPGRADE
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
MODS DONE!
Old 08-04-2008, 10:30 PM   #44 (permalink)
Re: tow vs big tow
The trutrac would work great in your truck. Seeing as you have the "bottom of the barrel" truck (as you put it..lol) you don't even have the rear wheel ABLS so it's basically a 1WD truck. I'd go for the TT depending on where and how you use your truck.
- Joe
Old 08-04-2008, 10:38 PM   #45 (permalink)
rtc1184's Avatar
Re: tow vs big tow
well i definetly need it. i play in the mud alot and i also have a boat. once i put my 37's i will def have to have it, lol.
BIG BRAKE UPGRADE
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
MODS DONE!
