Old 07-11-2008, 01:51 PM   #1 (permalink)
bada$$titan's Avatar
tow vs big tow
someone please expleain the differences between the two, went to the dealer today and told them i have to have big tow, crewcab, 4x4, they did a dealer locate, not one dealer had a big tow, but some had a regular tow package, so what the difference. Ill say what i noticed, then please correct me if im wrong, normal mirrors, no tranny temp guage, other than that what else, what about gears, hitch work etc.
bada$$titan is offline   Reply With Quote
Old 07-11-2008, 01:55 PM   #2 (permalink)
baseballfanz's Avatar
Re: tow vs big tow
Technically there's no such thing as a regular tow package. Just a Titan or a Titan with the big tow package.
The big tow package give you
# Class IV receiver hitch
# Additional 7-pin wiring harness plug
# Trailer brake controller pre-wiring under instrument panel
# Heavy-duty battery (710 CCA)
# Lower final gear ratio (3.36:1)
# Extendable tow mirrors (N/A on XE)
# Increased tow capacity
# Front tow hooks
Towing capacity XE, SE, LE
Without Tow Package
4x2 6,500 7,400 N/A 7,200
4x4 6,500 7,400 7,200 7,200
With Tow Package
4x2 9,500 9,500 N/A 9,200
4x4 9,400 9,400 9,300 9,200
If you can get the big tow package as it's only $450 as a package.($400 for me in 05)
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 07-11-2008, 01:56 PM   #3 (permalink)
Re: tow vs big tow
Big Tow Includes
Dumbo Ears
Gears -
Hitch - a big boy hitch
Tranny Temp Guage
I don't know what just plain "Tow" is.
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 07-11-2008, 02:07 PM   #4 (permalink)
md2420's Avatar
Re: tow vs big tow
my guess would be that if the dealer sees a hitch receiver on the truck, they consider that a "tow package".....I remember seeing some other posts on here that mentioned it happening to others.....but we know better!
'06 Smoke 4X4 SE KC OR BT
Airaid CAI, TBS and Banks
2* Advance
md2420 is offline   Reply With Quote
Old 07-11-2008, 02:11 PM   #5 (permalink)
Re: tow vs big tow
# Front tow hooks
god i love this site
OK the truck i looked at today sound identical to that description, on my 2006 titan the sticker said BIG TOW, this just says tow package which has me thinking its not what im looking for. i just need to make sure im getting the right truck since i tow 8000lbs regularly, i would hate to get the wrong truck due to me reading the tag wrong
Old 07-11-2008, 02:16 PM   #6 (permalink)
Re: tow vs big tow
the other thing is i didnt see a tranny temp guage on the XE
Old 07-11-2008, 02:31 PM   #7 (permalink)
blkkctitan's Avatar
Send a message via Yahoo to blkkctitan
Re: tow vs big tow
I have an 05 LE with big tow, but i have reg mirrors. Is it an option to get the reg mirrors instead of the dumbo ones? I have the tow mode button under the radio, but no temp gauge. Do i just have the reg tow mode?
blkkctitan is offline   Reply With Quote
Old 07-11-2008, 02:35 PM   #8 (permalink)
Re: tow vs big tow
If you don't have the big tow mirrors or the temp gauge you do not have the big tow package. ALL Titan have the tow mode button.
When looking at the window sticker, see where the "tow package" is listed. If it's to the right it's usually a "dealer added" option.
Old 07-11-2008, 03:02 PM   #9 (permalink)
HRTKD's Avatar
Re: tow vs big tow
Early on the package name may have been "Big Tow", but that was before my time. In the '07 brochure it is simply referred to as the "Tow Package". Around the Titan forums we simply call it the "Big Tow" package. Why? Beats me. It's kind of like calling a water heater the hot water heater.
Everything baseballfanz said is correct (just confirming here, not that he needs my help). Oddly enough the tow capacties for '08 haven't changed except for maybe 100 lbs less for the long bed version.
Jim
Old 07-11-2008, 03:06 PM   #10 (permalink)
Re: tow vs big tow
I beg to differ, in my '08 it was still called the "Big Tow" package.
However, the '09s have the "Max Utility package" which will combine the "Big Tow and the Utility Bed package" according to the dealer booklet I read.
2008 CC SE 4x4 Titan, Majestic Blue, Born: 15MAY07. "Chuck Norris drives a Titan out of fear of it being the only thing on earth that could kick his ***."
CRYPYKev is offline   Reply With Quote
Old 07-11-2008, 03:14 PM   #11 (permalink)
HRTKD's Avatar
Re: tow vs big tow
Where did you see "Big Tow"? I don't see that on the Nissan web site for the Titan or in the '07 brochure. I looked before my original posting just to make sure.
If it was on a window sticker then it could be that the dealer is referring to it that way. I thought the dealer could print their own sticker.
Jim
Old 07-11-2008, 03:44 PM   #12 (permalink)
Re: tow vs big tow
Not sure what the brochure or window sticker say but www.nissanusa.com jsut has it as "Tow package"
Old 07-11-2008, 04:37 PM   #13 (permalink)
JohnS's Avatar
Re: tow vs big tow
Just looked at my window sticker and it say tow package but mines an XE so it did not come with the mirrors or temp gauge
If you can read this, thank a teacher. If it is in English, thank a veteran.
JohnS is offline   Reply With Quote
Old 07-11-2008, 06:12 PM   #14 (permalink)
Re: tow vs big tow
Be careful,
Ive seen dealer just install a tow hitch and advertise it as a tow package.
You didnt get the
# Front tow hooks
SpeedFreak is offline   Reply With Quote
Old 07-11-2008, 06:27 PM   #15 (permalink)
Z-Hauler's Avatar
Re: tow vs big tow
I have an '05 XE w/out tow package, yet I have tow hooks in the front. I thought all Titans had tow hooks. (?)
2005 Galaxy black XE 4X4 - NCD 2.5" leveling kit - K&N Drop in filter and airbox snorkel "chop off" mod - Goodyear Wrangler tires with Silent Armor
Z-Hauler is offline   Reply With Quote
