Re: What MPG are you guys getting with your Fat A55 35 inch tires
Originally Posted by bills1974
My roof sits at 7.5 feet high and I'm rubbing with 35's as well and I've done the pinch weld mod...the fat tires will rub at full turn...
well i dang sure hope i can clear my 38.5's. i will be on 13 inches running 38.5x14.50x17. i will be pissed if they rub
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
from what i've seen it's the stock wheels that keep you from rubbing. it's the guys that do a leveling kit and put on aftermarket wheels with the tires that rub alot. plus i'm going with terragrapplers and not some aggresive M/T so i'll have less tread to worry about rubbing also. i doubt i'm going to go with 35's now anyway because of gas prices and the fact that i can barely afford to fill up my truck as it is.
08 Titan SE 4x4 KC. Magnaflow X-pipe muffler with dual 2.25" tailpipes, Hypertech Max energy. 14.85@91.8 best time(9.49@74 in the 1/8th). 6000k H.I.D. low beams. 302.8rwhp before the hypertech.
well my roof is 7'10" and i am running 38.5x14.50.17's no rub. i am getting about 15.3-15.6mpg on the highway and about 11.5 in the city. non big tow.
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
I will also confirm that it is possible to run 35's with a leveling kit. I have a 2007 CC 4x4 non-BT, running the NCD 2" leveling spacers, with a set of 17" offroad wheels and 315/70R17 BFG AT's. I didn't even need to do the pinch weld mod, I just trimmed a little meat of the front left mud flap. The tires will rub the mud guards only a little when I'm turning and going over a bump at the same time. I'm currently using a K @ N drop in filter and I average 12.5-13 in the city. I can't get a good Hwy figure because of all the traffic. I recently swapped the muffler for a glasspack, and it appears that I'm getting slightly higher mileage. I try not to floor it too much now because it sounds like an old GTO on steroids. Don't get me wrong, I love it, but it scares people. LOL
You get better MPG's than I do. How the F' is that?
__________________ "I feel sorry for people that don't drink because when they wake up in the morning, that's the best they're going to feel all day." - Frank Sinatra
2008 SE CC
Mods: Debadged, 8" CST, Eibach Springs, 18x10 Raceline Renegade 6, 35" Toyo MT's, Gibson Catback, K&N CAI, Billet Grille, Roadmaster Active Suspension, Nissan Factory Hitch, Big Tow Mirrors, Fog Lights, N-Fab Step Rails, Tech Box w/ 2 SD 12's, CDT Comps, CDT Rears, SD 100.4 Amp, BULLY DOG (ruff ruff).......more to follow!
100% highway mileage
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
I have 35z on 20"s I get a steady 10mpg tank to tank...
also with 10" wide wheels backspace doesn't matter... you'll always rub.. because you can only fit 5.5ish backspace... I have 5.79 and my toyo MTs rub the frame was thinking of getting 13.5"s for the next set but not sure now maybe I'll put on my 1/4" wheel spacers one day... or just stick some 2" ones on and see how much I rub the place where my pinch weld used to be
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
what is with everybody and gas mileage, why did you buy a truck and then lift it and then put big tires on it then some poweradders and now your worries about gas mileage. i work on the ultimate create work project THE MORE WE BURN THE MORE WE HAVE TO GET OUT
because some people would like to have a bad *** full size truck with the best gas mileage we can get. Why wouldnt you want to have the most efficiency you can have and still have the lift and tires like you want. So your telling me if you can have truck A that gets say 14mpg or truck be that gets 10 mpg with the lift and tires your going to pick truck B just cause who cares about gas mileage? Dude STFU your a trip.
Oh and just maybe just maybe you ever though of this one? Maybe some people would like to get an idea on what lifted trucks or getting so that can decided on the pros and cons on getting a lift to decide if they want one or not.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
I lost count.... First off my speedo is off cause of the new tires, so it looks like I travel less than I really do cause I haven't calibrated it yet! So know way for any body to really know what they get with 35's. I just go till 1/4 tank and hit up a Costsco cause there gas is always so tastefully cheap. Yummy! All I know is that its not as good as having stock tires on it! Also, learn to love the truck and cruise in it more not thromping the pedal all the time. On the freeway try to keep it on or just above the 2 RPM mark the sweet spot for the freeway you will be getting the best gas mileage.
I'm getting 11 mpg w/my no fear bad boy plus 2* timing mod, banks monster and intake, anyhow that's according to the on board computer, could be more or less , all I know is that it's been killing me a while. But that's the sacrifice you take for a having one bad mother sucker!
" plan your work then work your plan"
