Old 10-02-2008, 09:27 AM   #1 (permalink)
bumpy/bouncy ride
i just bought an 2008.5 crew cab se. it is my first truck. to me, it is a very bouncy/bumpy ride. talking with some guys that own trucks, i guess this is "normal". i mean i understand that the ride is not going to be anything like a car, and the freeways here in socal are terrible as well.
i was going to take it to the dealer just to make sure the tires are all balanced and everything is good in that regards.
i also thought i read somewhere here that someone changed out the rear shocks to bilsteins and that really smoothed things out. anyways, any input or thoughts would be much appreciated.
nathanrazo is offline   Reply With Quote
Old 10-02-2008, 02:55 PM   #2 (permalink)
HudsonValleyTitan's Avatar
Re: bumpy/bouncy ride
I have the PRO-4X with the harder off-road shocks and think the ride is one of the best as far as trucks go. I'm not sure what you're comparing it to though. Did you drive it and/or others before you bought it? It can't hurt to have the dealer check it out but it's probably fine. Remember, you have a solid rear axle and leaf springs...not exactly made to deliver a Lexus-like ride. Maybe you're having some sort of vibration issue rather than just a bumpy ride? There have been people here complaining about that and a tire balance or some other remedy cured the problem. Have it checked because, in general, the Titan....especially the LWB model, has a very nice ride for a truck IMO.
- Joe
Old 10-02-2008, 03:52 PM   #3 (permalink)
ten~39's Avatar
I've owned a number of trucks, and driven a number of trucks for company purposes, over the years, and in my opinion the Titan has the smoothest ride I've ever had out of a 4WD truck.
You're probably just not used to the overall ride of a truck yet.
2004 Titan KC LE BT 4X4- Smoke Paint
305/65/18 BFG AT T/A's
1.5" PRG Leveling Kit
PML Rear Differential Cover
OEM Armada Front Spoiler
Amsoil Fluids and Filters Throughout
ten~39 is offline   Reply With Quote
Old 10-02-2008, 03:58 PM   #4 (permalink)
Fox Delta's Avatar
more than likely the So-Cal roads (well Interstate)- I've been down smoother dirt roads! My truck has never bounced so badly on a paved street LOL....
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 10-02-2008, 05:52 PM   #5 (permalink)
i went to the dealer and drove another titan. pretty much the same. i have the crew cab and not the long bed, so thats the shorter wheel base right? and I do not have the 4x4 either. i guess the truck with the shorter bed would bounce around more? in any case i think its just a case of me getting used to how the truck drives and rides. i don't feel any shaking or vibration so i don't think its the tires. but i do think i will change out the shocks in the back, i guess that might smooth things out?
Old 10-02-2008, 08:17 PM   #6 (permalink)
Changing shocks can't change the nature of a solid axle with leaf springs, but it can help with rebound if its' bounce you're feeling due to bad roads in your area. Swapping out the rears should be fairly cheap and easy. Let us know if that does it.
- Joe
Old 10-03-2008, 10:28 AM   #7 (permalink)
I am not sure if any one mentioned to check the tire pressure. Should be 35-36 psi cold.
amati5 is offline   Reply With Quote
Old 10-04-2008, 01:09 AM   #8 (permalink)
loufish's Avatar
Well the 08' have more payload capacity then say my 04' so I'm sure they "beefed" up the rear springs a little.
Being new to trucks, you have no other experience to measure against, so it might be normal for a truck.
We have plenty of choppy freeway sections here to beat you up a little while driving, and my rear DR nor my SAW rear shocks could save me from that...It's a truck, but when you get on a good section and it's still too rough, then I'd start thinking new shocks...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-04-2008, 01:37 AM   #9 (permalink)
miketan's Avatar
If you think an '08 rides rough, you should try a '05 Titan. When I had an '08 for the day while my brakes were being worked on at the dealer, I couldn't believe how "plush" the '08 rode compared to mine. It felt like a Caddy compared to my truck.
The roads here in So. Cal are pretty bad. Sometimes I feel like I'm going to puke up a kidney driving over some of these roads. Serious. The freeways are just as bad, if not worse with their slab tilt construction. If you want a slightly smoother/softer ride, try lowering the tire pressure. When I had my tires at 29-30psi, the ride was significantly smoother and less harsh over rough roads. However, since increasing mpg is my primary goal at the moment, I have the front pumped up to 38.5 psi and the rear pumped up to 34.5. Let me tell you, that 4-8 psi difference makes the ride quality a lot worse. Try lowering them down to 30 psi and see how it rides. On an '08, it should ride like a mid '70's Eldorado.
'05 Titan XE
K11 Smoke
18" LE wheels/tires-Leer 700 tonneau cover-Ram air hood scoop with custom insert-SRT-10 replica rear spoiler-2.5" PRG leveling kit-3/4" rear blocks-Bodyside moldings-Wheel well trim moldings-Foglights with parking light mod-Dunder Dan upper/lower grill powdercoated in custom silver met-Red ceramic painted brake calipers-Stainless steel resonator exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather floor mats-Microfilters-Aftermarket alarm with power door locks-Nissan plate frames-Wheel locks-Hood decals-Airhog-Tint-OEM bed extender.
Coming soon: Color matched rear bumper-2* timing advance-Prothane front swaybar bushings-......
miketan is offline   Reply With Quote
Old 10-04-2008, 06:43 AM   #10 (permalink)
08TitanXE's Avatar
My 08 has a very smooth ride except on some parts of the road, especially I15 by San Diego pretty bumpy but after a short stretch it's fine.
08 Titan XE
2008 Titan XE CC/SB, Adopted 11/07, Radiant Silver 4X2, prefered package, 6 disc CD changer, key less entry, 6 spoke alloy 18" wheels, Nissan step tubes, Nissan tow hitch (not package), Factory Bed Liner, S&B CAI, Power Aid TBS, Magnaflow 18" muffler swap, 4" rolled tip, 2* Advance Timing, Scangauge II, LE Big Tow Mirors (non-power), RE-Q5, Sony 4 channel amp, 6x9 and 6.5" kicker door speakers, MX 2channel amp, under seat sub w/enclosure, and Bullydog PP.
08TitanXE is offline   Reply With Quote
Bouncy ride--need some help! heyitischris Titan Problems & Dealer Service 5 09-29-2008 05:05 PM
bumpy ride around 45 mph. yfztitan Titan General Discussion 4 04-07-2007 11:37 PM
Bouncy Ride Jingaling Titan Suspension 12 10-25-2006 10:21 PM
Bumpy Ride PUNISHER Titan General Discussion 2 06-08-2005 12:18 PM
