Old 10-14-2008, 09:08 AM   #31 (permalink)
Supporting Vendor
Discount Tire's Avatar
Re: Project: Ballistic Titan
Originally Posted by DeadRiver View Post
30k on a radiator cap? that's some BS right there.. I just flipped 30k not too long ago.
Sorry to hear about your luck.. still on my original cap and battery....
I thought it was odd too. These things happen I guess. When I lived in Oregon I was lucky to get 3 years out of a battery due to the cold winter temperatures. Here in AZ I guess your lucky to get three years with the heat. Good news is my new battery has a 7 year prorated warranty and will be replaced for FREE if it fails within the first 2 years.
The cap was replaced under warranty so at least I wasn't out any money for that one.
Originally Posted by theextra1 View Post
I really dig your write ups, very detailed. Great work!
Thanks. I am adding the install of the PowerAid throttle Spacer today. Next week I should be doing one for the New Frozen Rotors I am installing. Following that will be the big one with the Trailmaster lift and lastly I will be installing a set of Bushwacker flares.
We guarantee the Lowest Delivered Price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE.
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect
Discount Tire is offline   Reply With Quote
Old 10-14-2008, 10:17 AM   #32 (permalink)
theextra1's Avatar
Looking foward to seeing it all come together!
"The Killer Tomato"
08' Red Alert Titan SE 5.6L 4x4 with No Fear package, 6" ProComp lift, 18" ProComp Extreme Alloy wheels, 35" ProComp tires, Flowmaster Y into the Dynomax Bullet dumped, 2* timing advance (Thanks FaFaFooey), sway bar removed, aluminium mesh grill inserts. No Fear badging on grill, sides, and tailgate. Stainless steel instument cluster and pedals w/ No Fear badging, No Fear floor mats.
theextra1 is offline   Reply With Quote
Old 10-14-2008, 12:08 PM   #33 (permalink)
vilim12's Avatar
Originally Posted by Discount Tire Direct View Post
This leads me to something.... a short tangent.
It's going to take me some time to give it a through cleaning. Last week my battery fell subject to the Arizona heat and needed to be replaced. (less than two years and less than 30K) I opened up the hood to jump it and I quickly realized that the radiator cap had failed and had let coolant spray all over the inside of my engine. Apparently these caps get replaced every 30K but mine, also with the Arizona heat, didn't last that long. So dirt and dust happily stuck on like spider monkeys. The car wash quoted $80.00 of clean it up top and bottom. I can't see paying that much so I'll be scrubbing some more shortly.
Nothing a pressure washer wont take off,
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is online now   Reply With Quote
Old 10-14-2008, 04:20 PM   #34 (permalink)
Supporting Vendor
^I hope it does. I am going to attempt it this weekend.
1.888.459.4080
Old 10-24-2008, 03:42 PM   #35 (permalink)
Supporting Vendor
Project #3. PowerAid Throttle Spacer
Product: PowerAid Throttle Spacer
Install time: Start to finish: 20 minutes
Difficulty: Very Easy (1 on a scale of 1-10)
People needed for the Job: 1
Tools Required: 5mm Allen wrench, 10mm socket & wrench, flat head screwdriver.
First: Check for parts (check)
I flew through this installation. It will probably take me longer to write this up than it did to install it.
Step one: Disassembly
Remove the Engine Beauty cover: I loosened and removed the two 10mm bolts on the engine cover and popped the cover off its rear rubber grommets so that it could be lifted out of the engine compartment.
Remove the main intake tube throttle side: I used a screw driver to loosen the hose clamp on the main intake tube, you could also use the 5/16" socket for this. I then pushed it up and out of the way.
Remove throttle body: With the intake tube a little out of the way, I worked around it to remove the 4 bolts holding the throttle body to the engine. 5mm Allen wrench.
I wasn't able to get clear pictures of this with out taking more of the intake system out but the pictures on the Powerraid website show it clrear. Here is a link to their pictures for this part of the installation if you need it. It looks like they removed the main intake tube just for the photos. I didn't have to. Installation instructions]PowerAid Titan spacer
Step two: I next installed the rubber O-ring into the Spacer.
Step Three: Before installation of my shiny new part it was cleaning time. I cleaned out all the dirt and grime I could not reach with the engine cover on. If you haven't taken your engine cover off to clean I highly recommend it. Although it seems to make your engine look nice when its on there it has the effect of sweeping the dirt under the rug if you know what I mean. I then reassembled. I slid the spacer back behind the throttle body and bolted the throttle body and spacer back onto the engine using the new hardware provided. I also reattached the intake and tightened the screw clamp. (oh, clean again )
I then bolted the cover back on and...... done.
Install Review
Piece of cake. All parts were included, they fit great and are high quality. Directions were clear and mentioned everything I needed to know.
Product Review:
Great addition. Adding this spacer to Airaid intake system really helped on the lower end and torque. It noticeably idles stronger now and pulls harder through the low gears. The Spacer is designed to, for lack of a better word, swirl incoming air to the engine so that it enters quicker and more directed. This helps to optimize the amount of air entering the engine and helps the air mix with the fuel more thoroughly as well.
I am very pleased with the quality and performance of both the Airaid Intake and the PowerAid Throttle Spacer. Airaid has really put some time into developing products that work and install exactly the way quality after market parts should. I highly recommend these two products they are great bolt-on additions for anyone that looks to easily improve their trucks performance and sound.
1.888.459.4080
Old 10-26-2008, 03:30 PM   #36 (permalink)
albonismo's Avatar
do you plan on dynoing the truck when all is completed?
'06 Smoke XE CC FFV
Mods: AEM Bruteforce Intake, Stillen Dual Rear Exhaust, 2° Timing Advance, 8k HIDs, ReadyLift 2" Leveling, Deaver C-30 pack, Rear Bilsteins, PRG DCBB, LE rims, BFG AT KO 305/65r18, StreetScene One Piece Custom Grill powder-coated black, Color-Matched rear bumper, VHT NightShade painted tail lights, Debadged
Future Mods: UpRev, Nismo headers, Detroit TruTrac, SAWs in front I need new pictures
albonismo is offline   Reply With Quote
Old 10-27-2008, 01:51 PM   #37 (permalink)
Supporting Vendor
It has crossed my mind. It would be good to see the numbers. It would have been good to Dyno it before and then after to see the difference... I may be able to use another stock dyno test sheet to compare.... I'll look into it more, thanks for the suggestion.
1.888.459.4080
Old 10-27-2008, 02:15 PM   #38 (permalink)
rynomx785's Avatar
Would you dyno it before or after 35" mud grapplers?
Old 10-27-2008, 02:26 PM   #39 (permalink)
vilim12's Avatar
Hopefully before lift and tires, and I think ive read somewhere that some dynos can factor tire size in?
Crew Cab Long Bed
Old 10-27-2008, 03:30 PM   #40 (permalink)
Supporting Vendor
I hate and love to brake it to you guys but I finished up the lift yesterday and I installed the wheels and tires as well so it might already be too late for that. Today the truck is at the alignment shop and, hopefully, by Wednesday, I will be able to install the flares. It looks meaner than I thought it would as it stands now and rides unexpectedly smooth but I will be writing a full review shortly so please save the questions until I post it. I hope to have the Frozen Rotor write up done in the next few days. The lift, fender and wheel and tire write-ups will follow.
1.888.459.4080
Old 10-27-2008, 04:14 PM   #41 (permalink)
vilim12's Avatar
alright looking forward to it, goodjob on the writeups btw
Crew Cab Long Bed
Old 10-27-2008, 06:56 PM   #42 (permalink)
d0va's Avatar
same here, hope to see alot of pictures pls
2006 4x4 Nissan Titan Texas Edition
ProComp 6" Stg1, 35x12.5x17 BFGMudterrains, 17x8.5 MBWheel, AEM Intake, Helix TBS, Thrush Glasspack
d0va is offline   Reply With Quote
Old 10-27-2008, 07:29 PM   #43 (permalink)
First, this is a awesome write up, thanks Discount tire for doing this, looking forward to alot of good info!
next i would like to hear what others say about the Air raid filter system and the poweraid? Whats others experiences with this stuff, is there better out there?
I have always thought about adding these parts, but it concerns be that my luck something would happen to the motor and the dealer would blame those parts, or say that water entered through the filter because its open and caused a problem, so i went with a K&N instead. Could someone shed some light on this? are there any down falls to adding these?
288sunny is offline   Reply With Quote
Old 10-27-2008, 07:31 PM   #44 (permalink)
I also wanted to ask discount tire, any thoughts of getting the bullydog or superchips to go along with all these excellent mods?
Old 10-28-2008, 01:05 PM   #45 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
man... you sure modded that thing quick!!
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
My Titan to become Project Titan in Nissan Sport magazine... Triple S Titan General Discussion 15 03-31-2007 06:24 PM
Project Titan baseballfanz Titan General Discussion 7 01-08-2006 10:19 PM
Titan Project on hold ... new project has arrived ... mikegronholz Off-Topic Discussion 5 01-22-2005 07:55 PM
