Old 11-12-2008, 12:10 PM   #61 (permalink)
Re: Project: Ballistic Titan
Nice work thus far...I have to say something about DTD..I have been going to them (mulitple times) to swap out my tires and rims for my auto-x car and they have the best prices and professionalism. I'm glad to see that they are build this project truck and when it comes time to upgrade my tires and suspension, I'll be going to DTD first to see what they can do for me. In any case, some of the products listed here are going to be heavily considered.
Joeycurl is offline   Reply With Quote
Old 11-12-2008, 04:35 PM   #62 (permalink)
Supporting Vendor
Discount Tire's Avatar
Originally Posted by Brundy View Post
You can take pics of mine if you like. The PRG spacers and shackles aren't visible, so the susp. looks stock photgraphically. My Ranchos are off a stock rig too. PM me if you want to try it.
Thanks for the offer, I may actually take you up on this. There are a few other Titans here at work that I may shoot I really want a completely stock 2dw KC to shoot side by side and I plan to get underneath it too shoot each section of parts that get replaced or added for before and after shots. I think they will be the easiest for everyone to see how and where all the new parts end up. The lift is the most complicated install we have here and I would like to explain it in a relatively efficient way.
Originally Posted by Joeycurl View Post
Nice work thus far...I have to say something about DTD..I have been going to them (multiple times) to swap out my tires and rims for my auto-x car and they have the best prices and professionalism. I'm glad to see that they are build this project truck and when it comes time to upgrade my tires and suspension, I'll be going to DTD first to see what they can do for me. In any case, some of the products listed here are going to be heavily considered.
Thanks for your support Joey. There are a lot of us here that are enthusiasts just like you guys. Some of us are truck guys, some of us are classic car guys and some of us are into track and speed sports as well. We're glad you like the write up. let us know when we can help you again with your wheels and tires.
-Travis
We guarantee the Lowest Delivered Price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE.
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect
Discount Tire is online now   Reply With Quote
Old 11-17-2008, 05:27 PM   #63 (permalink)
Supporting Vendor
I will have to apologize in advance, the pictures for this install will be mostly close ups because I can't giveaway the finished look of the truck until I have completed all the write-ups. (2 more after this) You'll have to use your imagination for the time being.
Project # 5: Bushwacker Pocket Fenders
Product: Bushwacker Pocket Fenders 70907-02 (Utility Box option)
Installation Time: 1 1/2 Hour
Difficulty: 3 (1-10 scale)
People Needed for the Job: 1 (2 would have been helpful and faster)
Tools Needed: Utility Knife, #2 ratcheting screw driver, Drill w/ 5/16th bit, T45 torx bit (included), 1/2" socket.
Instructions are available for download at Titan Bushwacker Fenders Click "Download instructions sheet". (there are also some pretty good pictures to give you an idea of how the finished product will look.)
First Check for Parts: Driver Front flare(1pc), Pass. Front flare(1pc), Driver Rear Flare(2pc), Pass. Rear Flare (1pc), Hardware bag (1), Edge Trimming (1pc).... Check.
Step one: Install Rubber Trim on the top edge of all flares. Strip backing off in 1ft increments press into place, cut (utility knife) to length after installed.
Step Two: Use Your 5/16" drill bit to drill through dimples in each flare.
Step Three: Insert bolts (don't forget the washers) tighten with 1/2" socket and T45 Torx (Torx included), Repeat a gazillion times.
Step Four: One corner at a time, remove the factory fender lining screws (black ones only) align the Pocket fender up to the truck and reinstall the factory screws. (do not tighten) Install new clips where indicated by instructions. Once all clips and strews are started, double check fender alignment and then tighten each screw.
(new clip proper installation)
Step Five: Install Driver Utility box fender. First strip off edge protector on utility box door.
Align and install 2 piece Driver fender making sure the door has clearance to open and close before tightening fender liner screws.
Step 5: Finished.
Here are a few tease shots, I will post a before and after once all of the write ups are complete.
Installation and Product Review
Once again I am impressed with another after market product. These were easier than I expected to install and would be even easier to take off in the future if you were to choose to. There were a lot of little steps that take some time i.e. drilling all the holes and installing all the bolts, one at a time but it is worth it for the finished look. It was also a little difficult to hold the fender in place while starting the first few screws but once you get two of them in it was easy. All the parts were included. I was happy to see the torx head or it would have cost a trip to the hardware store. And everything aligned nicely. In comparison to some of the horror stories I had heard about tuner body kits not fitting and needing bondo or a skilled fiber glass repair man, these were a piece of cake. I choose to leave them in the matte black finish to match the wheels and I can't wait to show you guys the finished product. They compliment the black accents on the truck nicely. These flares added 2" to the body width and are now protecting the truck from most of the mud and road debris that's getting kicked up by the Mud Grapplers.
Two thumbs up here from me. -Travis
1.888.459.4080
Old 11-17-2008, 05:33 PM   #64 (permalink)
albonismo's Avatar
those bolts are just for looks right? if they are, are they close enough to scratch the paint underneath? thanks Mr.TT Tire, haha.
'06 Smoke XE CC FFV
Mods: AEM Bruteforce Intake, Stillen Dual Rear Exhaust, 2° Timing Advance, 8k HIDs, ReadyLift 2" Leveling, Deaver C-30 pack, Rear Bilsteins, PRG DCBB, LE rims, BFG AT KO 305/65r18, StreetScene One Piece Custom Grill powder-coated black, Color-Matched rear bumper, VHT NightShade painted tail lights, Debadged
Future Mods: UpRev, Nismo headers, Detroit TruTrac, SAWs in front I need new pictures
albonismo is offline   Reply With Quote
Old 11-17-2008, 05:36 PM   #65 (permalink)
Supporting Vendor
haha, I dig it. They aren't close enough to scratch the paint, there is plenty of space between them and the truck. You would have to smash the fender in to get them to scratch and if that were to happen, you'd probably have bigger problems than scratched paint.
1.888.459.4080
The Following User Says Thank You to Discount Tire For This Useful Post:
albonismo (11-17-2008)
Old 11-18-2008, 07:33 PM   #66 (permalink)
george_titan's Avatar
I have Gibson on my Titan, and it sounds just fine. Oh yeah and it's fast too!
george_titan is offline   Reply With Quote
Old 11-18-2008, 07:35 PM   #67 (permalink)
I hope those Bushwackers dont restrict tire turn ratio!?
Old 11-18-2008, 09:47 PM   #68 (permalink)
etalian2005's Avatar
Send a message via AIM to etalian2005
Any plans to paint the flares? I'm not a fan of the black plastic look of the flares with the paint.
No, they don't.
ESCORT SOLO S2 RADAR DETECTOR FOR SALE!!!
2008 PRO-4X Black on Black 4x4 w/ Leather package, Big Tow, and Utility Bed
BlackJack
Mods:
Performance: Superchips FlashPaq - 93 tune, 18" Magnaflow Muffler
Suspension: PRG 1.5" Leveling Kit
Wheels & Tires: 20x9 Ballistic Offroad Jesters, 33x12.50x20 Toyo Open Country M/T
Audio: 2 12" RE Audio SE's, Sundown SAE-1000D amp, Tech12Volt Sealed Box
Accessories: 6000K McCulloch HID Lows, 6000K DDM Tuning HID Fogs, 20% front tint, 5% in the back, and 5% on top of windshield, Hardwired Valentine 1, RBP 4.5" Black Exhaust Tip
etalian2005 is offline   Reply With Quote
Old 11-19-2008, 09:32 AM   #69 (permalink)
Supporting Vendor
Nope The wider tires and wheels have had an effect on it but the fenders them selves don't effect it at all.
Nope, not at this point. Maybe in the future but for now, we're digging the black accents.
1.888.459.4080
My Titan to become Project Titan in Nissan Sport magazine... Triple S Titan General Discussion 15 03-31-2007 06:24 PM
Project Titan baseballfanz Titan General Discussion 7 01-08-2006 10:19 PM
Titan Project on hold ... new project has arrived ... mikegronholz Off-Topic Discussion 5 01-22-2005 07:55 PM
