Milky Substance under oil filer cap - Nissan Titan Forum
post #1 of 11 (permalink) Old 12-13-2008, 12:13 PM Thread Starter
J.Bahde's Avatar
iTrader Score: 1 reviews
I was changing my oil today, and when I went to put in the new oil I noticed that there was a little milky substance under the oil filler cap. I have seen this on other vehicles that I have had before. I just was wondering if this is bad, or what causes this. Thanks!
2004 Titan SE
Mods- A heck of a lot more than I had before I found this forum
The best beer in the world, is the open bottle in my hand
If I'm not here, I'll be somewhere else.
CheapWineWhore™
J.Bahde is offline
Advertisement
post #2 of 11 (permalink) Old 12-13-2008, 12:18 PM
08TitanSE's Avatar
iTrader Score: 4 reviews
Re: Milky Substance under oil filer cap
I just changed the oil in my '08 the other day and noticed the same thing
08TitanSE is offline
post #3 of 11 (permalink) Old 12-13-2008, 01:10 PM
NorthGaTitan's Avatar
iTrader Score: 0 reviews
ANTIFREEZE in oil.........causes foam, or bad PCV.....
NorthGaTitan is offline
The Following 2 Users Say Thank You to NorthGaTitan For This Useful Post:
baseballfanz (12-13-2008), J.Bahde (12-13-2008)
post #4 of 11 (permalink) Old 12-13-2008, 01:18 PM
Yahooligan's Avatar
Antifreeze in the oil causes milky oil, 99% of the time the milky oil under the oil cap is simply from condensation. This is more likely to appear when people only drive their vehicles short distances at a time where the engine doesn't have enough time to get up to temperature and boil off the moisture that has been pulled into the engine. This is especially so with oil filler caps that sit atop a filler neck instead of being directly on the valve cover.
I wouldn't be concerned, this is actually quite common with a lot of vehicles.
The new pup: 2007.5 Dodge Ram 3500 MegaCab SLT 4x4 SRW, Inferno Red
The old dog: 2005 Titan SE CC BT 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, RAS, SnugTop Sport shell, 5000k HIDs - SOLD!
The old fish: 1984 Scarab 21SS - Marine Power 454 - SOLD
The new fish: 1998 Seaswirl 170 BR I/O
Yahooligan is offline
The Following 4 Users Say Thank You to Yahooligan For This Useful Post:
08TitanSE (12-13-2008), baseballfanz (12-13-2008), bbomar (12-13-2008), J.Bahde (12-13-2008)
post #5 of 11 (permalink) Old 12-13-2008, 03:15 PM
Banned
bbomar's Avatar
iTrader Score: 12 reviews
LOL, I had the same issue today!!
I figured it was condesation, because it was only near the cap, and the oil itself was just black and had no milkyness (new word) to it.
bbomar is offline
post #6 of 11 (permalink) Old 12-13-2008, 03:55 PM
Quartz's Avatar
iTrader Score: 8 reviews
Yahooligan gives good advice. As long as the oil doesn't look like hot chocolate I wouldn't worry.
GingerWhore™ BayWhore™
2011 Blue Steel SL, 2WD, BT, CC, Mods: Go Rhino Dominator II Nerf Bars, OEM Bug Deflector, 15% tint, Nav System Hack,
OEM Ipod Interface, Armada Front Spoiler, Leveled, Firestone Air Bags, Extang Solid Fold Tonneau Cover, Bully Dog GT,
LED Interior Lights, CSF 3328 Radiator, Brake Performance Drilled & Slotted Rotors, Wagner ThermoQuiet Pads,
Grounding Kit, Rogue Key, Bilstein 5100's on All Four Corners
Science flies you to the moon. Religion flies you into buildings.
Quartz is offline
post #7 of 11 (permalink) Old 12-13-2008, 04:18 PM Thread Starter
J.Bahde's Avatar
I figured it was just condensation because like y'all said the oil that I drained out actually looked really clean for having 4500 miles on it, but it wasn't milky at all. thanks for the info!
2004 Titan SE
CheapWineWhore™
J.Bahde is offline
post #8 of 11 (permalink) Old 12-13-2008, 04:33 PM
Blavis's Avatar
iTrader Score: 9 reviews
Hmmm...I wonder if the VK56 motor doubles as a cappuccino maker? Now I have to go check my oil cap.
AKA: iWhore™
AKA: BUDWhore™
IRC VK56 "Pit Crew Chief"
Other Ride:
2007 Yamaha V-Star Silveraydo
Blavis is offline
post #9 of 11 (permalink) Old 12-13-2008, 06:05 PM
TitanBlue's Avatar
iTrader Score: 3 reviews
Try a cup or two, and report back.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
post #10 of 11 (permalink) Old 12-13-2008, 06:43 PM
HudsonValleyTitan's Avatar
VWs are famous for this also. Yahooligan is right. It's just condensation more commonly found in vehicles that don't get up to full operating temperature long enough to burn it off.....also, it's more common to see in colder weather.
HudsonValleyTitan is offline
The Following User Says Thank You to HudsonValleyTitan For This Useful Post:
J.Bahde (12-14-2008)
post #11 of 11 (permalink) Old 12-16-2008, 02:11 PM
My 99' Grand Cherokee used to have this problem as well, Jeep actualy designed a different oil filler cap and neck to prevent the foam. but as everyone said before me, don't worry about it.
Quin is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Faulty Oil Cap?? jasonmotox Titan Engine, Transmission & Drivetrain 7 06-27-2008 07:43 AM
Engine Oil Filler Cap roadtripper Titan Parts & Accessories 7 10-19-2004 08:56 PM
First Dealer Oil CHange - Oil cap left off for 20 miles - Problem? bwalkertitan Titan General Discussion 20 05-17-2004 11:27 AM
You may post new threads
You may post replies
