Another couple questions from this newb
First, is there a way to disable to disable the TPMS sensor light in the gauge cluster (easily). I suspect my newly acquired Titan doesn't have a TPMS sensor in one of the wheels (they are incorporated into the valve stem, correct?). If so, are there any easy ways to disable the light without buying a new sensor and having the ECU programmed?
Second, this probably sounds crazy, but does anyone else's truck make a mechanical/motor sound in the dash just behind the center console? I noticed this last night after I shut it down and again today while sitting idling at a light. Kind of sounds like pump or something but the sound cycles like a clock's 'TIC-TOC'. Not something I'm used to in any of my other cars. At first I thought it was the ABS pump cycling, but the truck wasn't even started. What is this sound?
Thanks!
