Old 12-27-2008, 10:04 AM   #1 (permalink)
anmut's Avatar
Filter wasn't dry enough yet!
Cleaned my AEM filter yesterday. Today after letting it sit out and dry for 24 hours I put it back on my truck and went for a drive. Apparently it wasn't all the way dry because as soon as I gave it some gas the truck lurched and felt like it was bogging down.
Turned around quick and went home and took the filter off. Sure enough there's water inside. Took off the MAF and used a hair dryer on 'cold' to dry that off.
Question - has anyone done this before and was the MAF shot after getting it wet? The three little resistor looking things that stick out look to be in tact. I hope I didn't F anything up...
Mods: Bully Dog Tuner · 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow
Nissan OEM Brush Guard · Hellwig Traction Springs · 4 Hella 500FF OR Lights
Line-X Bed Liner · Jason Topper · Nasta Nerf Bars
Wish List: Nitto Mud Grapplers · Rims
Waiting For Support On: TruTrac / PowerTrax
SaveTheTitan Website IRC Chat: Server = Dalnet / Channel = nissan_titan
anmut is offline   Reply With Quote
Old 12-27-2008, 10:08 AM   #2 (permalink)
baseballfanz's Avatar
Re: Filter wasn't dry enough yet!
You should be OK, I have read of peoples going off road and sucking more water than that.
It took about 2 days for my AEM to dry last time I cleaned it. I bought a cheap filter from auto part place to use during the wait.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 12-27-2008, 10:17 AM   #3 (permalink)
anmut's Avatar
Sh1t man! On AEM's website it says that it's dry in a half of an hour! WTF.
AEM - AEM DRYFLOW Air Filters
Q: How long does it take to clean the DRYFLOW filter?
A: The DRYFLOW filter media is hydrophobic, which is a fancy way of saying it does not soak up water. Under normal conditions, cleaning will take about an hour. We recommend that you follow the instructions that are included in our intake systems and DRYFLOW filter replacement filter kits (CLICK HERE for downloadable cleaning instructions). Unlike oiled filters that must be cleaned, then dried, then oiled, then wait for the oil to wick to the material and finally fill in any “gaps” where the oil did not wick, with the DRYFLOW you simply bucket soak it, bucket rinse, shake it out and it will be dry in approximately 30 minutes! CLICK HERE for a cleaning demonstration video!
Someone needs to let them know that is not the case!
Old 12-27-2008, 12:49 PM   #4 (permalink)
titaninak's Avatar
Here's a trick that i do when i clean my K&N, after re oiling it and letting it sit over night, i hook up my shop vacuum to the filter and run it for an hour or so, just to make sure if i over oiled it, it will suck up any any oil before i put it back on my truck, i tested it out and checked the MAF and nothing.
2006 LE, CC, BT, 4x4-Blizzard White
titaninak is offline   Reply With Quote
The Following User Says Thank You to titaninak For This Useful Post:
twistedfreedom (12-27-2008)
Old 12-27-2008, 02:07 PM   #5 (permalink)
themaildude's Avatar
I've had problems with the AEM drying slowly also. Let it outside fro 24 hours and it was still damp so I put it on a rack in the clothes dryer and it still took 1 hr to dry.
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 12-27-2008, 02:34 PM   #6 (permalink)
TitanBlue's Avatar
I had same problem. Ran rough for 12 miles to work, then was OK on trip home. I will dry it much more than just setting it out overnight, next time!
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 12-27-2008, 03:18 PM   #7 (permalink)
krh2's Avatar
Genious! Great idea!
krh2 is offline   Reply With Quote
Old 12-27-2008, 03:37 PM   #8 (permalink)
Blackbeauty's Avatar
That's why I bought two filters.. One resides in the truck.. the other one dries for as long as it needs until I have to change the one in the truck. It's pretty idiotproof, IMO.....
Old 12-27-2008, 03:53 PM   #9 (permalink)
nytitan1's Avatar
I had the same problem with mine when i first did it so i bought another one cheap online and just put that one on until it dried all the way took two freakin days.
aka chubbywhore
nytitan1 is offline   Reply With Quote
Old 12-27-2008, 04:56 PM   #10 (permalink)
krh2's Avatar
I did the same.. Got tired of waiting for the filter to dry etc.... Bought a backup Nismo (AFE) filter from enissan parts... Now I always have a fresh filter ready to go..
Old 12-27-2008, 05:22 PM   #11 (permalink)
I think you're not supposed to use any heat source beside the SUN.
Something about the filter element shrinking.
Nissan ODB2 Codes
Old 12-27-2008, 05:29 PM   #12 (permalink)
krh2's Avatar
Correct.. That is why I bought a back up....
Old 12-27-2008, 05:36 PM   #13 (permalink)
titaninak's Avatar
thank you, thank you sir! LOL, a friend of mine had a K&N on his silverado ss and he messed up his MAF from over oiling. and told me what he does when he cleans his filter after that expensive mistake.
Old 12-28-2008, 12:12 PM   #14 (permalink)
anmut's Avatar
Well guys everything is fine. Put the filter on my computer case fan for another 24 hours and she dried out fine. Also took out the MAF and let it dry in the warm house for the same amount of time.
Old 12-28-2008, 12:27 PM   #15 (permalink)
AF-Medic's Avatar
Where's the cheapest place to buy a replacment AEM filter for a spare.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's, Two 12 volt tech underseat subs with CDT 4100 and cdt replacment door speakers,MD DVD player with 8.5 screen Shift Pass You
AF-Medic is offline   Reply With Quote
Volant Dry Filter???? husker1206 Titan Parts & Accessories 5 04-28-2008 11:36 AM
What is best stock replacement dry air filter? 1chris79 Titan General Discussion 11 08-21-2006 07:32 PM
VOLANT with AEM DRY FLOW FILTER WHITE340 Titan Performance Modifications 16 12-02-2005 10:56 AM
AEM Brute Force W/Dry Filter SPECIAL Tony@Performance Buy/Sell 0 10-21-2005 04:54 PM
AEM dry filter to fit NISMO intake Papa_D Titan Performance Modifications 1 09-12-2005 07:35 PM
