Evap vent control valve replacement - Nissan Titan Forum
post #1 of 35 (permalink) Old 01-08-2009, 08:17 PM Thread Starter
Smoke05's Avatar
iTrader Score: 0 reviews
Anyone replaced one yet? Dealer wants big bucks but I seem to be able to find the part for $90. Where on the truck is it and how hard to do? Anyone have any tech info on how to?
Smoke05 is offline
Advertisement
post #2 of 35 (permalink) Old 01-08-2009, 08:48 PM
Walrus's Avatar
iTrader Score: 20 reviews
Re: Evap vent control valve replacement
You know Smoke, they just R&R'd the TC on that truck.
I wonder if something got unplugged or not plueed back in?
Even if that isn't it, I can't imagine that it is too terribly difficult to change.
BaldWhore
Starfishwhore
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing more than half your clothes.
It's not the zombies you have to watch out for. It's the stupid people.
Walrus is offline
post #3 of 35 (permalink) Old 01-08-2009, 09:32 PM Thread Starter
Smoke05's Avatar
Front final drive got R&R'd walleeme. Doesn't look difficult to replace but I don't know where the darn thing is located.
Smoke05 is offline
post #4 of 35 (permalink) Old 01-08-2009, 10:05 PM
bagellord's Avatar
Trouble Code P0455
This help you out?
gaycamellovingwhore
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Hunter Truck Accessories Brush Guard
Black Undercover Hard Tonneau Cover
iPod adapter - May sell since I don't have an iPod anymore
Magnaflow 22" dual in single out muffler
BullyDog Power Pup
5000k HID low beams
Wish List:
Cold Air Intake (AEM or Injen or K&N)
"Those Who Sacrifice Liberty For Security Deserve Neither."
-Ben Franklin
bagellord is offline
post #5 of 35 (permalink) Old 01-09-2009, 02:48 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
This TSB will give you a little more infos. such as part numbers and what all is needed. Once you fix the EVAP valve you need to install a filter.
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #6 of 35 (permalink) Old 01-09-2009, 04:18 PM
clavin48's Avatar
I just changed this part on my 04', the stealership priced it at 505$ for parts and labor 229 of it for parts. I bought the the new valve on courtesy parts .com about 90 bucks , with no filter. I figure the filter cost just as much as the new valve and i heard that it dosen't always make them last longer. I changed this part in 15-20 minutes with no tools, I don't where the dealership got the 3 hours of labor from though. It's located under the truck on the drivers side, back by the gas tank, it sticks out of a black plastic box. give it a 1/8 to 1/4 turn and pull it out firmly. disconnect the connector and the hose and replace with the new piece. It wasn't very hard. I got 74K miles out of my original, and if the new one goes that long I'll be happy.
clavin48 is offline
post #7 of 35 (permalink) Old 01-09-2009, 06:37 PM
Any pictures possible??
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers.
New front differential at 60500 miles. [goodwill fix denied]
Detroit Truetrac at 61000 miles
Herbpov is offline
post #8 of 35 (permalink) Old 01-09-2009, 08:03 PM
clavin48's Avatar
sorry i don't have any pictures and its way to clod to go lay under the truck now, but it is really easy I mean really easy.
clavin48 is offline
post #9 of 35 (permalink) Old 08-15-2009, 10:38 AM
Mbgame80's Avatar
I had the same problem with my truck only my dealership was a lot better...... only $495! I couldn't believe it was that cheap! Anyways I took my truck back, ordered it myself and put it in within 10 minutes while rocking out to some kicka$$ tunes. Just wanted to say thanks because I followed your directions and things went perfect.
Mbgame80 is offline
post #10 of 35 (permalink) Old 06-13-2011, 10:28 AM
OneCheekRider's Avatar
I have the same problem with mine. It's a 2005 with 65k miles on it. Took it to the dealer and they're looking for $800 (parts and labor). I had a long chat with the service manager and referenced this thread as well as several others and told him his price was extremely high. We broke it down by parts and labor and basically they'd be replacing everything associated with the error codes that were given (forgot all of them) but it'd be the vent control valve, filter, vent control canister, pressure switch and I think a few other items to ensure that the problem is fixed and will not return.
Now I'm confused which route to take, especially bc I am not mechanically inclined, but I wouldn't mind paying a little extra for piece of mind and so I wont have to take the truck in again later on down the road. What do you think??
OneCheekRider is offline
post #11 of 35 (permalink) Old 06-14-2011, 04:21 AM
PRJ
$800??? Your getting hosed. Replace it yourself. It takes less than 5 minutes. I've done it twice already. You have 2 options.
1.) Pick one up from Rock auto for about $40. It's a direct replacement for the one you have.
2.) Pick a new one up from Nissan for $90. They redesigned it so you don't have to install the filter kit. The filter kit solution was only temporary.
Read this...
CONFUSED! Evap vent control valve assembly. 2 Different parts?
PRJ is offline
post #12 of 35 (permalink) Old 06-14-2011, 05:46 AM
Mbgame80's Avatar
I agree, sounds like they're trying to rip you off. I only replaced the vent control valve and haven't had another issue for the past 20k miles so it seems like replacing the other parts would be a waste of time and money. You don't have to be mechanically inclined to change the valve either, it's extremely easy. Follow the link and you'll be good to go.
AFE Stage 2 Intake, AFE TBS, 2* Advance, BullyDog Power Pup and a Magnaflow exhaust.
Mbgame80 is offline
post #13 of 35 (permalink) Old 12-05-2013, 06:49 PM
I have a 2004 Titan LE 4x4. Does anyone know what part # the new Nissan redesign is? Or if someone has a direct link as to where I can get this part that would be awesome.
Tea Drinker is offline
post #14 of 35 (permalink) Old 12-05-2013, 07:25 PM
JohnS's Avatar
iTrader Score: 2 reviews
if I am thinking of the right part I got mine from Rockauto.com I used the $40 one DORMAN Part # 911503 which was for my 08 and have had no issues.
Silver 2008.5 XE King Cab 4x4
JohnS is online now
post #15 of 35 (permalink) Old 12-05-2013, 08:00 PM
butterbean's Avatar
iTrader Score: 4 reviews
I also used the Doorman part from Rock Auto. Part has a lifetime warranty. One issue is trying to top off the tank too much. I let it stop automatically then one more fill and that's it. If you keep trying to top it off it will throw code.
Sent from AutoGuide.com App
2006 CC LE 4x4
Leer Topper
Smittybilt Bull Bar
HID Hella 500 FF
butterbean is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
EVAP - Control Valve SES code P0455 phlydude Titan General Discussion 35 06-29-2016 02:07 PM
Evap Valve test? jamesbe Titan Engine, Transmission & Drivetrain 23 10-29-2008 07:56 PM
EVAP valve?? maurimx Titan General Discussion 1 05-21-2008 12:53 PM
EVAP Vent Control S/V 305hp Titan Problems & Dealer Service 9 05-07-2008 06:05 PM
Evap volume control knocking. Huey130 Titan Problems & Dealer Service 33 01-03-2005 06:04 PM
You may post new threads
You may post replies
