The cats are covered under the Federal mandated 8 years/80,000 miles warranty. If you need the specific problem codes so the dealer can write it up correctly, PM NissanMike and he can get them to you.
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
A ticking noise coming from the exhaust where it leaves the side of the engine = cracked manifold. Also when I had the problem, I noticed reduced gas mileage.
Here lately, my truck has been sounding like a diesel in the cold weather. I've heard this before, but have NEVER heard anything like it. Last I remember, it was due to the battery grounding wire being too small. I actually just replaced the factory battery last month with an Interstate one, so I wonder if this is the reason.
Can you tell me more about the cracked exhaust manifold noise? I kinda hope it is cracked, so I don't need to replace it out of warranty! I have 64K currently.....
__________________ Straight, White, Republican Male (How else may I piss you off today?)
Loaded '09 LE 4x2 CC w/ Max Utility Pkg, Navi, sunroof, DDM HID low beams (35W 5000K), I-pod interface, chrome bug shield, Nissan rubber floor mats, and Retrax tonneau cover.
Nothing more than a loud ticking sound. I had brought mine into the dealer to have them verify it was the exhaust manifold.
Here are the pages you need to be concerned with from the warranty book...
Just found the codes. AT46 & AT47. The service writer should know what they mean.
Good job Mantis,you remembered.
In December,Nissan sent out a bulletin to it's dealers reminding them of the correct coding and coverage,hopefully this cleared up the confusion.
According to the warranty info above it states that the cats and ecm are covered until the 80k mark. Everything else including the exhaust manifold are covered to the 36k mark. Being that they are one piece does that mean if your cat goes out you get a free manifold but if your manifold goes out you have to pay for a cat?
04 SE KC. BT OR 128,000 miles and going strong. Still on the second set of tires.
06 LE KC. BT 50,000miles. S&B Intake. 22" magnaflow muffler. Bully Dog Power Pup. Truetrac, rear fog lights. 2.5" leveling kit. Air Lift airbags. Back up camera. 18x8.5 Viscera 506's w/ 325-60-18 Nitto Terra Grappler A/T's. Bushwacker fender flares color matched. 6000 hid low beams and fog lights.
I've had both manifolds cracked and replace under the 8 year 80,000 warranty. The manifolds are covered because the cats are attached.
Thats good to know. But by the way they have it worded I can see why some dealerships may get confused.
Nissan Mike,
Can you get me a copy of this bulletin so I can try to collect my $400 those assholes made me pay? Thanks.
I finally got around to taking mine in and I have the nissan "Gold" warranty for 75k well my odometer says 74,46x they said both my manifolds are cracked and that I would be covered for the 1800.00 worth of warranty work with a 50.00 dollar co-pay....................................buttttttttt ttt I also have to pay an extra 250.00 in labor cost due to my truck being lifted outta pocket????? Wtf??? I thought it would make it easier with the body lift if anything. I took my truck so I could call around other dealers and they were saying the same thing. The original dealer said I better hurry cause if I don't get it back before 75k it won't be covered!
Any insight on this?
04 TiTan Se 4x4
Intake
FlowMasters
2*Timing adv.
9" Pro comp
7" Rear Block + Deavers
20x10 XD RockStars
38x15.50 Kumho Mts
12000k Headlight H.I.D
3500k Fog H.I.D
2 10" Diamond Audio subs with custom box
1200.2 Infinity Amp
Stillen diff cover
OR Skid Plate
Bushwacker Pocket Flares Pain Matched
Matched Handles and rear bumper
NFabWorks Traction Bars
