Old 02-12-2009, 05:56 PM   #1 (permalink)
airforceruss's Avatar
4WD Switch Broken?
All -
I recently had an unfortunate accident and some liquid appears to have been spilled into (of all places) the 4wd switch. Of course the switch was in the 4LO position when this occurred so I now have a truck stuck on the 4lo position.
I won't even get started on how something managed to get into the switch, I just need to see about getting my truck all fixed up.
Does anyone know where I can purchase another switch and/or get the truck out of 4lo and preferably into 2wd without that switch?
Thanks!
*2005 Nissan Titan LE * Brilliant Red * 4x4 Off-Road Pkg * Big Tow Package * Factory Navigation * Factory DVD *
airforceruss is offline   Reply With Quote
Old 02-12-2009, 05:58 PM   #2 (permalink)
Country_Boy2493's Avatar
Re: 4WD Switch Broken?
I'm not sure but can you pull the switch off on a Titan? If you can then do that and take a pair of pliers and turn it back to 2hi.
1987 Ford Ranger 4x4 2.9 Fuel Injected V-6 with a 5 speed manual transmission.
"When the life light up the night, It's like the sun, Sit back enjoy life try to have some fun, Through the mud and the muck, Go on and lock the hubs up, And then look to the sky 'cause I'm 44 inches high." High Life
''Work Hard For What You Want it's The American Way, No-body Owe Ya Nothin Posed To Earn Your Keep, Put In A Hard Day's Work And Get A Good Night Sleep.'' Colt Ford
Country_Boy2493 is offline   Reply With Quote
Old 02-12-2009, 06:00 PM   #3 (permalink)
Banned
switches are linked to a fuse. it's just power giong to a joint which "switches" the power to a different post, which engages another function.
That said..check the fuse. coudle be the easiest way to fix it.
adamdude04 is offline   Reply With Quote
Old 02-12-2009, 06:01 PM   #4 (permalink)
So you can't pull the switch cover off? On my bro's chevy you can.....I don't thank that is normal.
Old 02-12-2009, 06:09 PM   #5 (permalink)
Banned
Yeah you can..but its not like his switch is stuck, at least I don't think. Just a short from liquid on the electric insides.
Old 02-12-2009, 06:19 PM   #6 (permalink)
Oh. BTW this is his Street Queen, Pavement Princess what ever you want to call it. HAHA
Old 02-12-2009, 06:55 PM   #7 (permalink)
Any idea what fuse I should pull? I pulled the panel off and really don't have any idea which one to pull.
I'm seeing :
A/T Cont
ADAPTIVE CRUISE CONT/RR DIFF
Either of those sound like they could do the trick?
Old 02-12-2009, 09:34 PM   #8 (permalink)
PRJ
Pull the front bezel off of the radio and then you can remove the 4wd switch and clean it up. There is a push tab on the back side of the switch that you will see when you pull the radio bezel off. Push that tab in and you can pull the switch out of the sash and unplug the wiring and fix it up or replace.
A new one is $61
http://www.courtesyparts.com/titan-p...1281_1285.html
PRJ is offline   Reply With Quote
The Following User Says Thank You to PRJ For This Useful Post:
airforceruss (02-13-2009)
Old 02-13-2009, 02:38 PM   #9 (permalink)
skohler's Avatar
Can't help with the titan, but had this happen to another car. Took out the switch, used some 90% rubbing alcohol on the internals and now it works perfect. So before ordering another switch, you might be able to just clean it out.
I'm thinking removing it might not be that hard once the center bezel is out.
Good luck
2005 LE CC, 4x4, OR, DVD, NAV, Side Air bags, Sunroof, BT, PRG 2" Leveling kit, BFG KO's, KC slimlites in the bumper
skohler is offline   Reply With Quote
The Following User Says Thank You to skohler For This Useful Post:
Old 02-13-2009, 06:11 PM   #10 (permalink)
Thanks everyone for the advice. I pulled the radio bezel off, then was able to remove the switch. Turns out the back plate had broken off in addition to the liquid getting in there. I took the pieces of the switch all apart and gave them a good cleaning, then pieced them back together.
If anyone ever runs into this thread, the switch pops out the front of the trim and there is a tiny ball bearing beneath the while plate in the switch which sits on top of a tiny spring. Make sure you put that ball bearing back on top of the tiny spring or the switch won't work correctly.
Anyway instead of dropping $60, a little electrical tape did the trick and now it's good as new.
Thanks again everyone!
Old 02-13-2009, 06:53 PM   #11 (permalink)
skohler's Avatar
Sounds like a good fix. Better than spending $60!
4wd Switch Lights PRJ Titan Interior Discussion 10 01-27-2008 10:07 PM
wtb: titan headlight switch w/fog switch Dom Buy/Sell 4 09-09-2007 11:04 PM
Busted 4wd Drive Switch-Where Can I Order One? Devildog Titan General Discussion 4 11-04-2006 07:06 PM
Haha...woops! Broken window switch Wallrat Titan Interior Discussion 3 07-27-2005 12:05 PM
Cool Use for blank 4wd switch plate MikeZ Titan General Discussion 11 01-05-2005 01:45 PM
