Old 03-08-2009, 09:56 PM   #1 (permalink)
Bleeding the brakes on an 08
I have had my 08 Titan now for about 15 months now with 15k miles and figured I might want to bleed the brake system. They feel a little spongier than when it was new.
I have only bled brakes on one other car in my life, a 1994 Corvette. That is my weekend car. The results were excellent. That car stops on a dime now.
I have a vacuum kit and it worked well on the Corvette. I just took the cap off the master cylinder reservoir and bled at each wheel in the order of right rear, left rear, right front, left front (moving from farthest away to closest). And I just made sure the reservoir stayed full as to not get any air in the system.
Would the steps be any different for my Titan? Any of obvious steps I might have missed?
What kind of brake fluid is the best?
Any good tips would help.
Thanks.
CRStewTAMU is offline   Reply With Quote
Old 03-08-2009, 09:59 PM   #2 (permalink)
twistedfreedom's Avatar
Send a message via AIM to twistedfreedom
Re: Bleeding the brakes on an 08
Same steps as described above. I just did this to a friends titan after a lift kit.
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts
Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub
Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit.
Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
twistedfreedom is offline   Reply With Quote
Old 03-08-2009, 10:44 PM   #3 (permalink)
desertruner09's Avatar
The best fluid (or one of the best) would be Motul RBF 600 but any DOT 3 or DOT 4 will work. Also, if you want to get rid of some of the sponginess, I would suggest upgrading to stainless steel brake lines.
2006 Titan 2wd CC SE Granite w/Big Tow with 80K miles
DIY Airbox mod with drop in AMSOIL Absolute Efficiency Air Filter and a DIY CAI //// Stillen Sport Rotors with Hawk HPS Pads //// Goodridge SS Brakelines //// Active Tuning Grounding Kit //// 265/70 R18 Toyo Open Country H/T Tires //// PRG Shackles //// Hellwig HD Traction Springs //// PML Differential Cover with Mag-Hytec gasket //// Armada Air Dam //// Headlight Mod (black)
desertruner09 is offline   Reply With Quote
Bleeding the breaks?? The Yetti Titan Wheels, Tires & Brakes 6 03-05-2009 01:11 AM
Installed new prakes and Bleeding them BEEMSANG Titan Wheels, Tires & Brakes 8 11-13-2007 10:27 AM
Brake Bleeding Procedure exit395 Titan Wheels, Tires & Brakes 1 08-03-2006 12:58 AM
Factory Brake Bleeding Procedure onthefence Titan FAQ & Howto Area 11 03-06-2005 02:06 PM
Hemi Brakes vs Titan Brakes Bayou Titan Titan General Discussion 4 02-01-2004 07:45 PM
