Old 03-19-2009, 07:16 PM   #1 (permalink)
Axle U-Bolt Torque
I'm getting ready to install my Roadmaster Active Suspension and I was wondering what to torque the nuts on the axle U-bolts to when I put it together?
2008 Titan SE, Crew Cab, 4x4, Long Bed
Popular Pkg w/ Captains Chairs
Utility Bed Pkg, Big Tow
Smoke/Charcoal
Roadmaster Active Suspension, Westin Sure-Grip Aluminum Running Boards, Leer 100R Cap, Lund Bug Shield
Exocet is offline   Reply With Quote
Old 03-19-2009, 07:23 PM   #2 (permalink)
Re: Axle U-Bolt Torque
I have a 2004 service manual and it shows 89 ft-lbs for the nuts on the U-bolts that mount the rear axle. (if that is what you are asking).
The Following User Says Thank You to bestatchess For This Useful Post:
Exocet (03-20-2009)
Old 03-19-2009, 08:12 PM   #3 (permalink)
yamatitan's Avatar
Yep 89 is about right, my are tourqed to 93 as per prg if I rember that right.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 03-20-2009, 09:35 AM   #4 (permalink)
just did it, I think PRG said 50lbs on a frontier, 75lbs on a titan.
2005 Nissan Titan LE 4WD Crew Cab (non-big tow)
"Courage is not the absence of fear, but rather the judgement that something else is more important than fear" - Ambrose Redmoon
wojowojo16 is offline   Reply With Quote
Rear U bolt torque yagger Titan Performance Modifications 3 11-15-2007 08:44 AM
Leaf spring U bolt torque.... Vobra46 Titan Suspension 7 02-19-2007 11:59 AM
Got Torque? Toomnymods Titan Performance Modifications 30 11-26-2006 11:26 PM
Finned differential bolt torque? HudsonValleyTitan Titan General Discussion 2 09-05-2005 07:53 PM
Diff Bolt Torque Spec Titan4x4Aggie Titan General Discussion 1 07-15-2004 09:03 PM
