Transfer case drain & fill - Nissan Titan Forum
post #1 of 32 (permalink) Old 04-08-2009, 05:01 AM Thread Starter
FLfinfan's Avatar
iTrader Score: 0 reviews
I am going to be draining and refilling both front and back diffs soon. Motor oil too. I also want to do the transfer case too. Never done one before. (have done the diffs and motor before).
Couple of questions
1. Is it as easy as the diffs and motor oil?
2. Are the drain and refill plugs/bolts easy to get too?
3. I have the fluid chart someone posted, so I know I need matic fluid for it, but do I need a hand pump. Someone said you need one for the front diff., I never needed one for that.
4. Anyone have any pics or owner's manual diagrams so I don't drain the Tranny by mistake.
Thanks in advance.
2015 SL CC 4x4, power moon roof, max utility / tow package.
Past: 2004 SE CC 4x4
FLfinfan is offline
Advertisement
post #2 of 32 (permalink) Old 04-08-2009, 05:36 AM
iTrader Score: 5 reviews
Re: Transfer case drain & fill
the diff's are the easiest. use a 3/8 extension to remove the plugs, drain, wipe off the crud from the plug and install. remove the upper plug and add your diff oil either Mobil1,Amsoil or Royal Purple. Sorry I cant post the service manual, left it home. Just ad the oil until its level with the upper fill plug for the diff's and transferr case
2014 Silver Ram Laramie 4x4 w/ leather and Alpine sound
2008 Red Brawn Titan SE 4x4 Popular package
ArmyAviation is offline
post #3 of 32 (permalink) Old 04-08-2009, 05:59 AM Thread Starter
FLfinfan's Avatar
Thanks for the reply. I have done the diffs twice already (2004 SE CC 4x4), once when they were having the initial diff problems and once again when Nissan upgraded the fluid type to 140. I know how to do those. They are easier to do than the motor oil.
The transfer case is the new one to me. So the transfer case has a bottom drain and top refill plug like the diffs do?
FLfinfan is offline
post #4 of 32 (permalink) Old 04-08-2009, 10:07 AM Thread Starter
FLfinfan's Avatar
Got this info off a different Titan site. Everyone here must be busy or at work.
"Last was the transfer case. Like the other fluids this proved to be a pretty easy deal. You do need a 10mm hex head to get the drain plug out and when it comes out the fluid shoots back a good 8" or so. I have one of those big 15 quart drain pans/containers that you see at all the parts stores and I positioned it so that the forward edge was just under the back of the transfer case. The fluid stream ended up hitting about 2/3 to 3/4 of the way back so that worked out quite well.
The plug much like the others was covered in goop and had quite a few metal shavings on it so I'd highly recommend an early change. The upper fill plug was clean and dry so the fluid level may have been a bit low from the factory. Since the fluid didn't come in a squeeze bottle I had to use a pump to get it in which was a bit interesting because I had to hold the hose in the transfer case. There is something right on the other side of the fill plug that prevents your pushing the hose in. It ended up taking just a shade over two quarts to refill the case. Do be sure to go and get new crush washers from the dealership before you begin.
All in all I'd rate changing the fluids on this truck as being pretty easy. The biggest thing is to be sure and have a catch basin large enough as there is a lot of fluid to catch if you’re doing more than one item. Also with both the engine oil and the transfer case be ready for the fact that the fluid comes out in a veritable torrent. It's certainly the fastest draining oil pan I've ever seen".
FLfinfan is offline
post #5 of 32 (permalink) Old 04-08-2009, 02:16 PM
You will probably need a fluid pump to get the ATF into the transfer case. Any auto store will have it for a few bucks - I needed one when filling with Mobil 1 ATF.
I'm going to do all my diffs soon too. Royal Purple for the rear diff and Transfer Case.
I'm not sure what I should use for the front diff - RP doesnt make the proper weight oil for the front diff in quarts, its only available in large quantities. What is everyone putting up there?
Also - the pump I bought has been laying in a sealed container for 2 -3 years now - with the old Mobil 1 residual still on there, what's the best and safest way (for the environment) for me to clean that up so I can use it again for the fresh fluid? Just wipe it down and go, or should I make sure its 100% clean?
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
PuvMan is offline
post #6 of 32 (permalink) Old 04-08-2009, 02:30 PM
mjw357's Avatar
iTrader Score: 4 reviews
I'm sure Mobil 1 or Amsoil in the proper weight would be more than adequate. 80W90 or 75W90
Just wipe with a lint-free rag and go. It's an oil change, not a heart transplant.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
mjw357 is offline
post #7 of 32 (permalink) Old 04-08-2009, 03:27 PM
Dirtytitan's Avatar
iTrader Score: 2 reviews
going to be doing this too in a couple weeks. thanks guys
2006 Crew Cab 4X4 SE Big Tow
Performance Mods: 2* Timing Advance, AEM Brute Force CAI, Banks Monster Exhaust, Superchips 91 Tune.
Audio Mods: Alpine Type R Door speakers, Boston Acoustics S35 3.5" 2-way Speakers in the dash.
Other Crap: 8000K HID lows beams, B&W Tow and Stow adjustable Tri ball hitch, Burn out switch, Prodigy brake Control, 2" NCD level and 275/70/18 Nitto Terra Grapplers, Mesh Grill
Dirtytitan is offline
post #8 of 32 (permalink) Old 04-08-2009, 04:26 PM Thread Starter
FLfinfan's Avatar
Got the front and rear diff. fluid cheaper at Wally World. It was the Wally World brand but meh. I was there to get motor oil for the two vehicles anyways. Trucks going in Fri. to have the power steering and brake fluid changed, I will get the Matic D transfer case fluid from them while I am there.
FLfinfan is offline
post #9 of 32 (permalink) Old 04-08-2009, 07:55 PM
iTrader Score: 1 reviews
I did mine today too. It was pretty easy. I did buy a torque wrench, and the 10mm hex key, and tightened all the plugs and fill holes to 25 ft. pounds. It didn't seem too much, but I hope it's enough.
I got Royal Purple in the rear, Castrol 80W-90 in the front, and Castrol Matic J compatible in the transfer case. It took longer than I thought, but my fluid pump I got at the parts store was a joke. If I would have had the proper tools, (pump), it would have been done in an hour if not less.
All 3 plugs had the grey junk on them, but the fluid didn't seem too dirty. Who knows what was suspended in it though when it drained out.
**What is that terrible smell in the diff's? I must have gotten some on me I can still smell it.
I'd like to thank all the folks who put good info on this website. No way would I have felt comfortable doing this myself without the info I got on here!! This job was simple.
Purchased 03-29-08
Searched for a Truck for a year, almost bought several before....
Red Brawn 08.5 Nissan Titan
No Mod's yet
It's the best truck ever!!!!
Joe B.
I'll keep my guns; you keep the 'Change.'
fpd7 is offline
post #10 of 32 (permalink) Old 04-08-2009, 08:40 PM
Gear oil smells... oh well nothing abnormal it's an aquired stench
tiller87 is offline
post #11 of 32 (permalink) Old 04-09-2009, 05:38 PM Thread Starter
FLfinfan's Avatar
Wanna know something weird? I can use the same oil filter on the Titan and the Z.
Whoever at the factory put the refill plug in the new rearend I got back in 06 (upgraded at request, never a problem) really horsed it down. I had to get off the creeper and lay on the ground to get leverage to get it loose.
The factory gear oil in the rear diff looked like crap. The front diff oil which I changed 5-28-05, looked like new golden honey.
I will take the Titans 4 bolt skid plate over the Z's 16 bolt spalsh guard anyday when changing the motor oil. Oh ya, and no ramps needed. What a pain. Oh, well, at least it's done.
FLfinfan is offline
post #12 of 32 (permalink) Old 04-09-2009, 05:49 PM
Bama334's Avatar
No need to pay the dealership for D-matic, it's just Dexron. I'd buy the pump for the transfer, it will make things much easier. I changed mine at 15K and then at 56K and it was dirty looking. The 2 1/8 quart of fluid does alot of work and overlooked the most.
2004 Titan LE CC 4X4 Offroad
PRG Performance Package Lift
PRG Rear Shackles- PRG Sway Bar End links
Bilstein Rears
Detroit Truetrac
315 BFG's All Terrain's
Bama334 is offline
post #13 of 32 (permalink) Old 04-09-2009, 06:01 PM
I agree with Bama334, why use D-matic? I pumped mine full of Mobil-1, may as well install a low pour point synthetic fluid for the cold winter and a higher temperature tolerable fluid for the hot summer periods. Most likely cheaper too...
Dr. Chaz is offline
post #14 of 32 (permalink) Old 04-10-2009, 09:44 PM
memsu's Avatar
I know my transfer case fluid was really bad looking at 30K. I highly recommend changing it regularly.
memsu is offline
post #15 of 32 (permalink) Old 05-04-2009, 03:15 PM
skohler's Avatar
+1 Just changed mine and I was about 1/2 quart low, fluid was black and the drain plug had the typical thick layer of fine metal shavings. I just got my T back from the dealer because the front diff and one of the transfer case sensors was leaking.
Found the leak when I went to drain the Tcase, don't know if that would account for the low fluid level, but glad I checked. Mine is at 26K.
2005 LE CC, 4x4, OR, DVD, NAV, Side Air bags, Sunroof, BT, PRG 2" Leveling kit, BFG KO's, KC slimlites in the bumper
skohler is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Transmission Drain and Fill w/ Amsoil ATF CoeCEO Titan Engine, Transmission & Drivetrain 1 03-23-2009 03:25 PM
Transfer case Luke Titan Problems & Dealer Service 11 02-03-2009 12:33 PM
Transfer case help, please. Scott. Titan Problems & Dealer Service 8 06-17-2008 05:17 PM
Exhaust Leak & Transfer Case Leak Clinsta Titan Problems & Dealer Service 1 01-29-2007 11:27 AM
Transfer case.. vector6 Titan Engine, Transmission & Drivetrain 2 12-21-2004 01:20 PM
You may post new threads
You may post replies
