Old 04-23-2009, 03:47 PM   #1 (permalink)
Shane06fl's Avatar
Question New Radiator, Intersting Temp readings
This past Saturday the new Radiator went in with a new 170 degree T-Stat. All gauges read fine so there is no concern. But on Tuesday, Wednesday and Today after the same 25 mile ride I took some temp readings.
With the truck in drive (E brake on) I used a lazer thermometer that is very accurate. These are averages from 3 days.
Front of engine block right under the heads 187 degrees
Valve covers 171 degrees
T-stat housing 180 degrees
upper rad hose at rad 179 degrees
lower rad hose 167 degrees
Trany input to rad 151 degrees (remember this line has open air for about 4ft)
trany output of rad 165 degrees
Output of trany cooler 149 degrees
Trany body 161 degrees
Oil filter 191 degrees
very consistant reads over the 3 days.
So if you look at the input and outputs of the trany lines at the radiator you see the radiator is heating up the transmission fluid. This is a very good reason to bypass the radiator all together. You can see the cooler is cooling the fluid down 16 degrees. If that the fluid hits the cooler at 151 and cools it 16 degrees that should extend the life of the fluid and transmission.
I am going to test my other truck the same way and see what happens.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 04-23-2009, 09:11 PM   #2 (permalink)
desertruner09's Avatar
Re: New Radiator, Intersting Temp readings
That's pretty interesting about the tranny fluid actually being heated up by the radiator. I'm assuming the tranny was at operating temp.
I can't see Nissan not noticing that the radiator is actually heating up the fluid. Therefore, I think this may be there for towing purposes. When towing, I'm sure the ATF is quite a bit warmer and then the radiator might help cool it down, slightly.
Either way, very interesting findings! It would be nice to see what those temps are while towing.
2006 Titan 2wd CC SE Granite w/Big Tow with 80K miles
DIY Airbox mod with drop in AMSOIL Absolute Efficiency Air Filter and a DIY CAI //// Stillen Sport Rotors with Hawk HPS Pads //// Goodridge SS Brakelines //// Active Tuning Grounding Kit //// 265/70 R18 Toyo Open Country H/T Tires //// PRG Shackles //// Hellwig HD Traction Springs //// PML Differential Cover with Mag-Hytec gasket //// Armada Air Dam //// Headlight Mod (black)
desertruner09 is offline   Reply With Quote
Old 04-23-2009, 09:27 PM   #3 (permalink)
You might want to take into consideration that the truck is sitting still. Which means less air passing through the radiator and trans. cooler. This may affect the over all cooling giving you misleading temps. Note I do say may. I am not an engineer by any means, but I would think that while driving your temperature differentials between the radiator and the trans cooler would be considerably less. Either way it is an interesting find.
2008.5 CC Pro4X, PRG minilift, Truxedo LoPro cover, more to come pending the funds
th3sub is offline   Reply With Quote
Old 04-23-2009, 09:31 PM   #4 (permalink)
Quartz's Avatar
Sorry for the hijack. I have a laser thermometer also. It's a lot of fun to play with. My wife thought I was crazy when I got it but uses it in the kitchen all the time now.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 04-24-2009, 06:25 AM   #5 (permalink)
Shane06fl's Avatar
Since you have stated how wonderfull your wife is and she obviously is buying you such cool gadget you may hijack if you like.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
The Following User Says Thank You to Shane06fl For This Useful Post:
Quartz (04-24-2009)
Old 04-24-2009, 06:31 AM   #6 (permalink)
Shane06fl's Avatar
I pull in the driveway at home, pop the hood and take readings. Readings are done in less than two minutes. Trany in D with fluid flowing. It just doesn't make sense. The radiator is cooling down the engine coolant but teh trany fluid is cooler than the coolant when it hits the radiator. I can see if pulling a heavy load teh trany may heat up to more than the engine coolant and then be cooled down before it hits the cooler. Could be part of how the radiator helps to cool engine coolant.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 04-24-2009, 06:42 AM   #7 (permalink)
54warrior's Avatar
hahaha... nice theory... the trans fluid is a heat sink for the antifreeze. Interesting readings none the less.
2005 Nissan Titan CC SE 4x4
Old 04-24-2009, 06:57 AM   #8 (permalink)
NBhunter80's Avatar
You will never see the tranny fluid have a higher temp than the radiator unless you are pulling a heavy load up a steep hill. If the Titan is anything like my old diesel with regards to coolant, then having the tranny cooler and the rad linked actually helps bring the tranny fluid up to operating temperature faster. My old truck would automatically reduce power until the tranny fluid came up to operating temperature. I'm sure you are correct that the life of the tranny fluid will be extended if it runs 15 degrees cooler at normal temp; however, you must take into consideration what would happen if your tranny temp stayed lower than the ideal temp for longer due to not being warmed by rad fluid. I'm sure the tranny fluid would be more viscous and not do it's job as well if the temp was significantly below operating temp. So basically if you did seperate them, you would see lower temp under normal conditions, but your tranny temp would rise more under heavy loads, and take alot longer to reach normal operating temp because it does not have the influence of the rad to cool/heat the fluid. This would probably reduce your power for the first 10-20 minutes that you drive your vehicle, and it might cause excess tranny wear because the fluid is not warm enough when you first start driving. This is pure speculation, but it's something that I thought up when noticing exactly what you stated on my old truck.
2005 LE King Cab 4x4 Offroad pkg Big Tow, Purchased used on 2008/11/30.
Silver with charcoal leather interior, black Nissan OEM brush guard, 285-70-17 BFG All Terrain T/A KO's on OEM OR 7-spoke 17" rims, 2 degree timing advance, Magnaflow 14" SI/SO muffler on stock pipes with 12" T304 stainless double-wall tip, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Future mod wish list:
6" Procomp stage I lift, SAWs, TC UCAs, 35x12.5x20's on 20X10 wheels
CAI, headers, catback exhaust
Bushwacker pocket style flares
Custom paint job over this OEM crap!
NBhunter80 is offline   Reply With Quote
The Following User Says Thank You to NBhunter80 For This Useful Post:
54warrior (04-24-2009)
Old 04-24-2009, 07:30 AM   #9 (permalink)
Shane06fl's Avatar
I am with ya NB. I was shocked when I took the readings. I Am sure it's all in the design and specs of how it should operate. I know the trany needs to be at a certain temp to function correctly just as the engine needs to be at a certain temp to make the right power.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 04-24-2009, 11:35 AM   #10 (permalink)
Learjet's Avatar
your truck was designed to operate at a certain temp for many reasons, why do you want to change that?
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 04-24-2009, 12:13 PM   #11 (permalink)
layer1's Avatar
Sounds like she took your toy away.
1/4 Mile in 14.89sec | 90.43mph @ 5900pnds
AKA: ScotchWhore
layer1 is offline   Reply With Quote
Tranny fluid in Radiator! NEW Radiator time :) adamdude04 Titan Problems & Dealer Service 26 03-26-2009 11:35 PM
Strange DMM Readings ecbmxer Titan Visual & Audio Discussion 3 12-24-2005 05:19 PM
Interesting Readings jmacougar Titan General Discussion 5 01-03-2005 02:45 PM
intersting sales info from usatoday smoketitan Titan General Discussion 0 05-11-2004 01:55 PM
