Ok guys and Gals I have made a huge decision i have wanted to lift my truck 6inc with 35's and some rockstars but i think i want to head down a different path so i need yalls opinions and guidance on if this is a good package setup so here we go..... first things first will be DANA 44 TRU TRAC with the HIGH FLOW RESIVOR DIFF COVER TO GO WITH IT, NEXT WILL BE THE BULLY DOG PROGRAMER VOLANT COLD AIR INTAKE, PRO FLO MASS AIR SENSOR WITH TRUE DUEL MAGANAFLO EXHAUSET THIS WILL GO WITH A 2.5 INC LEVELING KIT AND SOME KUMHO ROAD V 33'S ON MY STOCK 18'S please let me know what yall think good combo maby i should sub something out for something else let me know ???????
actually 4wheel parts .com has them for 655.00 i was looking at them all day today. and they also sell the dana 44 diff cover with the larger oil resivor and cooling fins here is the part number for it Part Number: DET913A582
There is no truetrac for the 08s+ yet and there might never be, 4wheelparts clearly doesnt know much about what their selling. Do a quick Titantalk search on it, and youll see. The diff cover would work though.
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
Unfortunately he is right. There is no Trutrac for the 08s and up. Which suck because I have an 08 too. Everything else sounds like a good set up tho.
"The Killer Tomato"
08' Red Alert Titan SE 5.6L 4x4 with No Fear package, 6" ProComp lift, 18" ProComp Extreme Alloy wheels, 35" ProComp tires, Flowmaster Y into the Dynomax Bullet dumped, 2* timing advance (Thanks FaFaFooey), sway bar removed, aluminium mesh grill inserts. No Fear badging on grill, sides, and tailgate. Stainless steel instument cluster and pedals w/ No Fear badging, No Fear floor mats.
The Following User Says Thank You to theextra1 For This Useful Post:
You know I started digging and on 4wheel Parts online ordering they claim to have the Detriot Locker Trutrac that works for the 08. I am calling shenanengens! But now I am going to call Detriot Locker to confirm.
"The Killer Tomato"
This is what 4wheel parts search for an 08 Nissan Titan shows. Detroit TrueTrac Differential But I am calling Eaton tomorrow to find out if it is BS or not. They are closed right now.
"The Killer Tomato"
i really hope that i found something new that will work on the o8's thats what it said it was made for so i hope there not bs'n but to try and rope this back in do yall think this setup will work well...? or what yall
Dana's a little confused also...I just looked at the latest application chart from their website and it lists a TruTrac for the Titan Dana 44 04'-07'....
Bottom line, for now there is NO TT for the 08' and up Titans....If I had an 08+ I'd be looking for a wreaked Titan to pull a factory e-Locker from and wire it up manually...
PRG Performance Kit w/SAW's
Born 9/2004
