Old 06-25-2009, 08:44 PM   #1 (permalink)
Brake/abs/slip/WTF
Ok, so i changed my rotors and pads a week ago. had to replace a front caliper because the piston was cracked and pieces broken. Sweet brakes, everything has been peachy, today tho. abs will kick in when i brake going for an easy stop , and i cant stop, and when im driving the abs/slip light both come on, and go away a few minutes later. i dont understand. any insight before i have to go get rapped at the mechanic? fluid level in resevoir is awsome, i dont know whats wrong ? thanks guys !
ajokeonspokes is offline   Reply With Quote
Old 06-26-2009, 08:20 PM   #2 (permalink)
Timmyo2L's Avatar
Re: Brake/abs/slip/WTF
abs sensor wiring is damaged?
Timmyo2L is offline   Reply With Quote
Old 06-27-2009, 07:58 AM   #3 (permalink)
yamatitan's Avatar
make sure there is no air in the brake line.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 06-29-2009, 04:46 AM   #4 (permalink)
thanks guys. speed sensor wire all mangled.
dealership says slip light + ABS is low brake fluid? Yomama Titan Problems & Dealer Service 22 05-09-2009 03:19 PM
ABS, Slip, Brake, 4WD light's on!! glensmachine Titan Problems & Dealer Service 19 03-13-2009 11:09 PM
Slip - abs GregP Titan Problems & Dealer Service 20 02-28-2009 08:26 PM
limited slip and abs cookimnster Titan General Discussion 7 10-14-2005 11:27 PM
dash brake, VDC OFF, Slip and ABS lights all lit up? llajumpvid Titan General Discussion 10 06-22-2005 08:48 PM
