Old 07-03-2009, 08:30 AM   #16 (permalink)
Re: raced a duramax 2500 today
I don't think the D-Max knew you were racing, sorry OP.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 07-03-2009, 09:15 AM   #17 (permalink)
NBhunter80's Avatar
A tuner on a diesel will usually make more smoke. As was pointed out before, black smoke is from unburnt fuel. If you add more air then more fuel will burn resulting in less smoke. So with a larger turbo or modifying the geometry of the turbo to make more boost (VGT) you go alot faster and less smoke. Then you can add huge injectors and get your smoke back because you are putting even more fuel and the turbo can't keep up. Those are the guys who you see at the track billowing black clouds of death and running 11 second 1/4 miles. After you tune a diesel, essentially you do not have any restriction on how much fuel you can use, basically you can just trample it and dump as much fuel as your turbo can provide air to burn...or until the motor blows up. That is why the tuner makes such a HUGE difference in power on a diesel...and that is why a duramax or powerstroke with a stock Variable Geometry Turbo, stock injectors, and a tuner can go so fast. The tuner allows you to dump tonnes of fuel, and the VGT already provides alot of air to burn it...hence the 150hp 350ft*lbs tq increases from the tuner only. And a cummins with a vgt, injectors, exhaust and a programmer is just rediculous. Diesels can make HUGE power with very little modifications due to the compression ignition technology and lack of need to regulate the AFR. I love my titan and all, but I have no doubt that my old modded '03 powerstroke diesel 6.0 could have raped any equally modded T in a race like it was standing still. Keeping the heads from blasting off from the power was a whole different issue though lol. 1000 ft*lbs of torque is not easy on the drivetrain lol. But yeah, IMO diesel motors are a superior design in every way.
2005 LE King Cab 4x4 Offroad pkg Big Tow, Purchased used on 2008/11/30.
Silver with charcoal leather interior, black Nissan OEM brush guard, 285-70-17 BFG All Terrain T/A KO's on OEM OR 7-spoke 17" rims, 2 degree timing advance, Magnaflow 14" SI/SO muffler on stock pipes with 12" T304 stainless double-wall tip, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Future mod wish list:
6" Procomp stage I lift, SAWs, TC UCAs, 35x12.5x20's on 20X10 wheels
CAI, headers, catback exhaust
Bushwacker pocket style flares
Custom paint job over this OEM crap!
NBhunter80 is offline   Reply With Quote
Old 07-03-2009, 09:40 AM   #18 (permalink)
neworleanstitan's Avatar
speaking of a clean tune here is my buddies 2500HD 550 hp to the wheels
neworleanstitan is offline   Reply With Quote
Old 07-03-2009, 10:26 AM   #19 (permalink)
NBhunter80's Avatar
Yeah, you can see how fast the VGT spools up because there is a puff of black smoke when the rpm is low just for a second at the start and when it shifts, and then the turbo catches up really fast and no smoke while it is giving boost. The turbo gives enough air that there is no unburnt fuel. Does he have an aftermarket turbo on that bad boy with stock injectors? Also, it is a newer diesel they have a Diesel Particulate Filter and EGR that take away most of the smoke (and alot of the power). I bet your buddy would blast the smoke if he got rid of the EGR, DPF, and put monster injectors. Plus he would probably be making over 700hp at the wheels by then. My truck had no EGR or DPF and billowed black sunshine all day long when you raunched on it. I especially loved when you race a convertible and they get covered in diesel soot lol. Damn I miss that
This is what I'm talking about lol
Old 07-03-2009, 10:39 AM   #20 (permalink)
NBhunter80's Avatar
Number two is just rediculous lol.
Old 07-03-2009, 10:52 AM   #21 (permalink)
Just a custom tune, exhaust, no dpf and built tranny he killed the first allison.
Old 07-03-2009, 10:57 AM   #22 (permalink)
I'm not sure what's cooler on #2 the black or white smoke lol
Old 07-03-2009, 11:08 AM   #23 (permalink)
zsennett's Avatar
that's what you get for thinking... he was trying to race me not the other way around. but not doing a very good job at it, no dout in my mind or my friends mind who was sitting shotgun.
mods: injen c.a.i, prg 2" leveling kit, 33x12.50s on 18x9 XD rockstars, smoked fog lights and headlights, grillcraft black mesh grill, banks cat back and bully dog power pup (just untill i can afford nismo LTs and dual spintechs and uprev), burn out mod, 2 JL 10w3s, JL amp
zsennett is offline   Reply With Quote
Old 07-03-2009, 11:33 AM   #24 (permalink)
NBhunter80's Avatar
Ahhh..nice. Even the stock VGT does a great job on the duramax in keeping up with stock injectors. But yeah, I also roasted a tranny on my powerstroke a couple months after I first tuned it with SCT...by doing stupid stuff. It was still under warranty so I just had them throw a new torqshift tranny in and that was still going strong when I sold the truck at 101k miles and got the Titan. Can't say the same for the cylinder heads, driveshaft, radiator and some other powertrain stuff lol.
Old 07-04-2009, 10:56 PM   #25 (permalink)
OK then what I should have said is that I don't think the clown knew how to drive. Better?
With an experienced driver, a stock Duramax will walk on a mildly modded T like yours (or many others on this site) quite easily. So, it sucks for him that his driving skills suck ***.
Nothing against you or the Titan BTW, I love mine and would never give it up for ANYTHING.
Old 07-04-2009, 11:13 PM   #26 (permalink)
MSrockyblue's Avatar
Send a message via MSN to MSrockyblue
You're doing more drugs than you should. A stock duramax is slow. My boss had one for his work truck. I've driven it plenty. Lots of pulling power but slow. Maybe you got a lemon for a titan. Oh, and the only difference in the driver skills is if it's manual or the allison. The automatics don't spin, so just stomp it, right?
05 SE CC TX Titan
true dual magnaflows w/H pipe, bully dog pp, volant cai w/volant ram air, 37* degree timing advance, ROCKET BOOSTER, Armada air dam
MSrockyblue is offline   Reply With Quote
Old 07-04-2009, 11:24 PM   #27 (permalink)
SMOKEDYA2's Avatar
here is a duramax a the strip with absolutly NO smoke what so ever
04 xe 4x4 smoke
-uprev tuned, doug thorley lt headers, 07 intake mani, k&n cai, gibson catback, cats deleted, tb bypass, tb screen removed, and active tuning ground kit
-prg mini lift 2.5" front and 1.5" rear, hankook 33" mt's, and aluminum diff cover.
-20% window tint, ddm tuning 8000k hid's, bug deflector, rain gaurds, mcgrille 4pcs grille, and painted rear bumper
-sony 1100watt amp, 2 polk audio 10's, and 1.5 farad capacitor.
SMOKEDYA2 is offline   Reply With Quote
Old 07-04-2009, 11:29 PM   #28 (permalink)
vilim12's Avatar
Gonna have to agree, a stock durmax is slow and any stock titan should be able to take one.
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 07-05-2009, 07:48 AM   #29 (permalink)
O-FiveCC's Avatar
Here are the 16 second timeslips form stock D-max's
Stock 2007 Chevrolet CK2500 Truck 1/4 mile Drag Racing timeslip specs 0-60 - DragTimes.com
2002 Chevrolet CK2500 Truck LS HD 1/4 mile trap speeds 0-60 - DragTimes.com
Here they are running low 15's with intake, exhaust, and tune LOL
2004 Chevrolet CK2500 Truck HD CREW CAB 4 X4 1/4 mile trap speeds 0-60 - DragTimes.com
2006 Chevrolet CK2500 Truck HD 1/4 mile Drag Racing timeslip specs 0-60 - DragTimes.com
From Dragtimes it appears with intake, exhaust, and tuner has them mid 14's to low 15's. To get down in the 13's it appears that the intake, exhaust, custom tune are used with a transmission upgrade and a torque convertor upgrade (sometimes more boost on the turbo).
2005 Chevrolet CK2500 Truck CC SB 1/4 mile Drag Racing timeslip specs 0-60 - DragTimes.com
So no a stock 2500 isn't beating a Titan IMO, even with a tuner and an intake or exhaust, it's still game for a lightly modded Titan, I ran 14.5 with intake, exhaust, tune, and Tru-trac...Like i've been saying from the begining
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
Old 07-05-2009, 09:14 AM   #30 (permalink)
I read online that the 2011 Titan was going to have a small Turbo Diesel option. I don't know if it's just a rumor or not though.
Stump1000 is offline   Reply With Quote
Raced a (2004-06) 1500 and (2004-2006) 2500 (diesel) Silverados chepdog War Stories 11 12-01-2008 02:47 PM
Ordered the 3500 Duramax today...titan is on the block. ned946 Titan General Discussion 50 04-25-2008 09:26 AM
DuraMAX 2500 vs. TITAN!! BRACEYOSELF777 War Stories 49 04-17-2008 04:38 PM
Whos raced a new Duramax?? vegastitan21 War Stories 33 07-10-2007 04:06 PM
Titan vs. silverado 2500 Duramax SupraTitan War Stories 20 05-12-2005 11:13 AM
