Old 07-02-2009, 03:28 PM   #1 (permalink)
Need Help about my 4x4 operation
I have 4x4 OR,CC,BT 06 model. Every thing is factory stock. I was lubing 4x4 by driving in high and low at low or very low speed in a near by field.I do this once a month or so just to lube componenets in the 4x4 drive train.Today I took some sharp turns about as far as the wheel would turn both right and left. When turning to the extreme the truck jerks or jumps?? It acts like ABS is kicking in or slip or a brake locking up. Dosen't make a noise it just kinda hesitates jerks and lunges. Straight aways no problem.Turning right and left it dose the same. I have factory OR rims and BF factory tires. The tires don't rub on these trucks do they?? I don't know what it is or if it's normal. This is not my first 4x4 never had one that did this?? No lights come on slip or anything. When turning around in a tight area is how I discovered this. Can anybody Help with a suggestion or if this is normal it sure don't feel like it?? Thanks for any thoughts!!
curbfinder is offline   Reply With Quote
Old 07-02-2009, 03:33 PM   #2 (permalink)
ptvolly's Avatar
Re: Need Help about my 4x4 operation
Was it doing this while still in the field? If so, sounds like it is getting too much traction. If you were back out on pavement, sounds like the 4 wheel drive was still engaged. Check your dash and make sure it is OUT of 4X4.
I know my '05 doesn't always come out of 4X4 until I stop or back up.
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 8188 18X9
PC Xtreme A/T 325/65/18
Bully Dog / Magnaflow "cat-back" / Tint / NISMO CAI / 6k HID / Westin Bull w/ PIAA lights / Truxedo / Carriage Works Grill / Airlift rear bags / Bushwacker Pocket Flares
My super duper MPG doubler- a 1996 Grand Prix coupe!
ptvolly is offline   Reply With Quote
The Following User Says Thank You to ptvolly For This Useful Post:
curbfinder (07-02-2009)
Old 07-02-2009, 03:41 PM   #3 (permalink)
Yes it was doing it in the field. The thing was jerking like it was grabbing on the ashpalt. But I've never had it in 4x4 on the road. But as you said it feels like it's getting too much traction?? Straight runs smoth as silk. A little incline and turn the wheels as sharp as it will go with out stressing the power steering and it jerks pretty hard. It makes you staighten the wheel quickly to stop the jerk.
Old 07-02-2009, 03:41 PM   #4 (permalink)
thad5515's Avatar
If I understand you corectly, what you explaining is totally normal. I haven't had a 4x4 that doesn't do this.
thad5515 is offline   Reply With Quote
The Following User Says Thank You to thad5515 For This Useful Post:
Old 07-02-2009, 03:45 PM   #5 (permalink)
So you would recomend not turning super sharp while in 4x4? My 99 hard body frontier never did this or my 76 full time 4x4 blazer??
Old 07-02-2009, 03:52 PM   #6 (permalink)
ptvolly's Avatar
To build on and agree with Thad...
I wouldn't say to NEVER turn all the way, just realize it is putting everything in a slight "bind". My personal opinion is if the truck couldn't handle it, they would have cut down on the turning radius.
Any time you're in 4 wheel you should notice more input in the steering. Even with power steering, you are typically turning "dead" wheels. In 4X4 those wheels are now pulling, and any change in traction will affect how it drives and how much input you have to put into the steering wheel. You can definately get the asphalt feeling in fields. Just means your tires weren't slipping, making the differential unhappy! (Im sure Loufish or someone else can get technical and explain it much better and probably a lot more acurate than I can!)
Edit: I'm not really familar, but it could be your Blazer, although full-time 4X4, still had an open diff and only delivered power when it sensed wheel spin (or maybe even locked the diff at that point). Some vehicles work that way and some don't. Most trucks actually lock the front diff when 4X4 is engaged, which is why it gets mad when the outermost wheel tries to travel at the same speed as the innermost wheel.
As Thad said, it sounds completely normal and unless you're really beating on it, I wouldn't be concerned.
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 8188 18X9
The Following 2 Users Say Thank You to ptvolly For This Useful Post:
curbfinder (07-02-2009), thad5515 (07-03-2009)
Old 07-02-2009, 03:56 PM   #7 (permalink)
Pops's Avatar
Your Blazer and Hardbody had locking hubs. The Titan does not have any locking hubs, they are always locked and all axles are spinning all the time, even in 2WD. What you're experiencing is normal, I've done it too. You'll also find that the Titan has better OEM offroad traction than the Blazer or Hardbody had straight from the factory. Turning sharp while in 4x4 is usally best avoided if possible.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
The Following User Says Thank You to Pops For This Useful Post:
Old 07-02-2009, 04:12 PM   #8 (permalink)
Thank You very much, That makes me feel alot better. And yes both of my old 4x4's had lock in hubs. I was hopeing it was normal because it didn't do it going straight! It reacts as all you folks descibe like it just dosen't like that sharp turn. Mild turns for me from now on don't want to hurt my diff's.
Old 07-02-2009, 04:32 PM   #9 (permalink)
yamatitan's Avatar
Let me set something straight you can turn as sharp as you want in 4x4 when you dont have good traction like in ice or mud. But if you do it on dry land on asphalt is going to to do that.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
The Following User Says Thank You to yamatitan For This Useful Post:
Old 07-02-2009, 07:30 PM   #10 (permalink)
So hopefully I did no damage?? It was at very low speed but I did repeat it a couple times to make sure it wasn't just in my mind? It never made a noise nor dose it now after doing something I shouldn't have. I knew enough to stop doing it and get on here to ask you guys with all the knowledge. Is there anything I need to look at or for to make sure I didn't damage anything? Thanks again for great advice and input!!
Old 07-03-2009, 02:52 PM   #11 (permalink)
yamatitan's Avatar
Mostly likely you didnt damage anything. As long as everything is normal going straight your probably good. I wouldnt worry about it some people do that all the time without problems and some have stuff break the first time they do it. As long as you didnt hear a loud pop and you dont have and diff fluid or a broken cv boot you should be fine.
***Operation Blackout*** onebad2006titan Titan Pictures & Media Post 8 05-23-2009 08:16 PM
Proper Operation of Tranny 07texas Titan Titan Towing & Hauling 15 12-07-2008 12:01 PM
Here's a new one....weird heater operation???? jmeyer Titan Problems & Dealer Service 4 01-19-2008 07:24 PM
Operation BeeDAMNED!! Demondw3 Off-Topic Discussion 2 01-24-2007 04:58 PM
Operation Swarmer!!! Burly Off-Topic Discussion 5 03-16-2006 02:34 PM
