Old 07-10-2009, 07:25 AM   #1 (permalink)
A/C Fan stuck on high?
My A/C is acting up. It currently only has two settings, off or full blast. The second I turn the fan control knob on it blows full bast. I took it by the dealership and they did not have time to look at it yesterday but the customer service rep. thought they would need to replace the A/C control unit, a $300 part.
Anyone had this problem before? If so what was your solution? I'm hoping to avoid the $300 part if at all possible since I am out of warranty.
Thanks!
squirm88 is offline   Reply With Quote
Old 07-10-2009, 07:38 AM   #2 (permalink)
beason's Avatar
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
Re: A/C Fan stuck on high?
ive never had this on my titan but on my honda it was the fan resistor. what it does is regulate the voltage to the fan per commands from the knob. if this goes out, you get a dead short, which means no regulation and full voltage all the time. mine was mounted to the bottom of the AC box in the Pass side floorboard. was a $25 part and i changed it myself in the parking lot. worth a try!
  • 06 Galaxy Black LE Crew Cab BT.
  • air box mod
  • Armada air dam
  • Aries stainless step rails
  • Power Acoustik REACT1-1100 Class D2 1100-Watt Mono Amplifier with dual 10" kicker cv-r subs
  • Dick Cepek DC-1 18" chrome wheels
  • Flowmaster 50 dual in/out dumped.
Soon to have: 2" drop shackles, Jet Tech mod, tinted tails, CAI.
beason is offline   Reply With Quote
Old 07-10-2009, 07:39 AM   #3 (permalink)
No remedy but till you get it fixed if you put the selector switch to feet only the amount of air circulating is reduced greatly. Not much help just temporary releif. You will be surprised how much it reduces the flow!
curbfinder is offline   Reply With Quote
My A/C fan will only work on High RW1050 Titan General Discussion 21 12-17-2008 10:13 AM
Oil guage stuck on High Black05xe Titan Problems & Dealer Service 0 12-20-2007 02:43 PM
Got stuck, and it is still stuck helomech Titan Pictures & Media Post 103 11-28-2007 10:11 PM
AC/vent stuck on high! jhedges Titan General Discussion 8 04-24-2006 10:27 PM
AC/vent stuck on high. Please help! jhedges Titan Problems & Dealer Service 2 04-09-2006 02:16 PM
