ac stuck on high - Nissan Titan Forum
post #1 of 15 (permalink) Old 07-20-2009, 09:03 AM Thread Starter
iTrader Score: 0 reviews
ac stuck on high
I have a 05 titan LE with the variable speed fan control and its stuck on high. Is there any quick possible fix before I have to take it in.
real_texan77 is offline
Advertisement
post #2 of 15 (permalink) Old 07-20-2009, 09:59 AM
Shane06fl's Avatar
iTrader Score: 1 reviews
Re: ac stuck on high
You will probably have to replace the entire control panel.
Easy to do yourself.
2005 Titan KC SE ***Sold 9/6/14***
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
2013 Chevy Silverado LT Z71 CC short bed
5.3L LC9 engine
Heavy duty tow package/cooling
4wd
loaded to the gills
mirrors sucks (for now)
2004 Keystone 24RS
Shane06fl is offline
post #3 of 15 (permalink) Old 07-20-2009, 10:13 AM
beason's Avatar
iTrader Score: 10 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
there are other threads going on the fan stuck on high. I think its the resistor for the blower, but i have never had this issue on my titan, only on my previous car which was a honda accord.
Titan mod list
WhinyWhore™
beason is offline
post #4 of 15 (permalink) Old 07-20-2009, 10:36 AM
If you aren't under warranty, I wiuld try the resistor first. It's a much less $$$ part. I had one replaced under warranty last year and it cured the problem.
Also, someone posted quite a while back about part of the knob breaking internally. They had a fix for that without buying the whole control module. Try a search for that.
Engine - Nismo CAI & headers, Magnaflow high-flow cats, Magnaflow catback, UpRev
Suspension - F/R swaybars, Bilsteins, PRG endlinks & Minilift
Brakes - PowerSlot rotors and Hawk brake pads
Other - Nismo gauge face, Autometer Trans, Diff & Coolant gauges, Mag Hytec diff cover, PML transmission pan, etc
IRC VK56 Member
bu_bear_sh99 is offline
post #5 of 15 (permalink) Old 07-22-2009, 10:02 AM
It's in another thread, but you can get a multi-meter and test the resistor. It is a plug under the glove box near the fan motor. I think it the second from the left of four wires. It should read 0 V when the fan is off and then go up to 5 V on max. If it does that it's the resistor. If not, you likely need to change the whole panel.
Resistor is about $60.00
Control Panel about $350.00
Someone else metnioned that when the resitor goes the blower motor is about to go out. I changed the resistor on mine after it did the same thing about two weeks ago....it just started intermittently blowing only on high again, so I think I'm going to change the fan this weekend...which is why I'm back here.
papabear is offline
post #6 of 15 (permalink) Old 08-02-2009, 09:36 PM
HavaTITAN's Avatar
I just bought a new '08.5 and the fan went from med to high on it's own.
HavaTITAN is offline
post #7 of 15 (permalink) Old 08-04-2009, 06:59 PM
jljue's Avatar
The fan control module now has a different heat sink to provide better cooling.
'07 Nissan Titan LE CC 4x4 w/ Pro-4X wheels
1985 Skeeter SF-175 w/ 150 HP Evinrude
jljue is offline
post #8 of 15 (permalink) Old 08-04-2009, 07:27 PM
JASANDALB's Avatar
yeah...move to florida. high is normal for us.
JASANDALB is offline
post #9 of 15 (permalink) Old 08-05-2009, 10:05 AM
FLfinfan's Avatar
word!................
2015 SL CC 4x4, power moon roof, max utility / tow package.
Past: 2004 SE CC 4x4
FLfinfan is offline
post #10 of 15 (permalink) Old 08-05-2009, 10:26 AM
HavaTITAN's Avatar
Florida! try living in AZ, it's been 110 to 119 for the past three weeks.
post #11 of 15 (permalink) Old 02-24-2011, 03:55 PM
It looks like nobody has posted a real answer since 2009, but if there's still people out there looking for an answer like I was, this is the solution:
As I was told by a Nissan Tech, this is what they call the VBC or Varible Blower Controller (nissan part number 27151-ZT00A) and it costs $60 bucks (compared to replacing the entire panel for $350) at the dealer. In order to replace it, you have to take the glove box out, but this is pretty simple. Then all you need is a socket wrench and after replacing it with the new part, everything works as before.
Below is a link on how to remove the glove box.
Nissan Questions - I am trying to replace the variable blower resistor in my 2005 - JustAnswer
huehueteco is offline
The Following 3 Users Say Thank You to huehueteco For This Useful Post:
hyboost (10-16-2013), Nivlac (06-25-2011), wssboard18 (05-06-2014)
post #12 of 15 (permalink) Old 06-25-2011, 08:37 PM
Nivlac's Avatar
I just replaced that part today. Its sooooo easy....you would kick yourself for paying someone else to do it.
2007 Nissan Titan 4x4 - 6000k HIDs, PRG 2" leveling kit, Nitto Trail Grapplers (285-65-18)
2015 Mustang GT
2015 Audi A4 Quattro
Nivlac is offline
post #13 of 15 (permalink) Old 01-03-2013, 08:14 AM
Thanks for the part number and good information. Paid Nissan to do it the last time it went out because didn't know about the greatness of this forum yet! First Nissan told me it was the control unit/sending unit or some such and it was going to cost me 500 to fix it. Lucky for me I didn't have the 500 to drop at that time because when I did bring it back another mechanic laughed and said sorry someone told me that and knew right away that is was the VBC!
chinookboy is offline
post #14 of 15 (permalink) Old 07-20-2013, 05:13 AM
Replaced the VBC on my 05 two years ago,.. right after I bought it,,... with the new updated model,... and it's out again,... one of the notorious problems Titans have,... and Nissan will never acknowledge.
djhn9 is offline
post #15 of 15 (permalink) Old 10-16-2013, 11:18 AM
hyboost's Avatar
Garage
Thanks Huehueteco for the info. My entire heater/ac unit had to be replaced when still under warranty. Was hoping it didn't need another one now that it's not under warranty anymore. Will buy VBC today and give it a try.
hyboost is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Oil guage stuck on High Black05xe Titan Problems & Dealer Service 7 09-08-2012 10:00 AM
A/C Fan stuck on high? squirm88 Titan General Discussion 2 07-10-2009 06:39 AM
AC/vent stuck on high! jhedges Titan General Discussion 8 04-24-2006 09:27 PM
AC/vent stuck on high. Please help! jhedges Titan Problems & Dealer Service 2 04-09-2006 01:16 PM
Stuck CD Mombo Titan General Discussion 10 05-13-2004 04:35 PM
You may post new threads
You may post replies
