Old 07-29-2009, 11:41 PM   #1 (permalink)
HavaTITAN's Avatar
Dash rattle fix.
I am on my second titan, the first one was an '04 and I now have an '08. There was a dash rattle on the first truck that drove me nuts, I fixed it and now the new truck has the same rattle so I'm thinking most all titans have this rattle so I am posting the fix I used for both my trucks. First, remove the defroster vent cover from the dash ( I use a stiff putty knife to pop it off). Now the long thin part of the dash that runs between the defroster vent and the windshield is what's rattling, if you tap along that piece you can feel it hitting the metal cowling underneath in some spots. What I did was take some thick wheather strip foam pieces and stick them between the dash and cowling until I could tap on the dash pretty hard and not hear or feel it hitting the metal underneath. Now reinstall the vent cover and your good to go, no more rattle, it worked on my '04 and my '08.
HavaTITAN is offline   Reply With Quote
The Following 4 Users Say Thank You to HavaTITAN For This Useful Post:
NBhunter80 (07-30-2009), thad5515 (07-30-2009), titanhornet (07-30-2009), titanss (08-03-2009)
Old 07-30-2009, 09:17 AM   #2 (permalink)
Re: Dash rattle fix.
THANKS, mine doesnt rattle now but might later. Did it effect airflow for the defrost?
2007 Titan XE King Cab / Mods: Spal Power window kit, Powercoated rear bumper, De-badged and Tinted.
dsmtuner1 is offline   Reply With Quote
Old 07-30-2009, 09:33 AM   #3 (permalink)
beason's Avatar
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
sounds good man, but can you give us some pics or a diagram of where you put the foam? im slowly working out the rattles in my truck so this may be one of them.
  • 06 Galaxy Black LE Crew Cab BT.
  • air box mod
  • Armada air dam
  • Aries stainless step rails
  • Power Acoustik REACT1-1100 Class D2 1100-Watt Mono Amplifier with dual 10" kicker cv-r subs
  • Dick Cepek DC-1 18" chrome wheels
  • Flowmaster 50 dual in/out dumped.
Soon to have: 2" drop shackles, Jet Tech mod, tinted tails, CAI.
beason is offline   Reply With Quote
Old 08-02-2009, 10:50 PM   #4 (permalink)
Shakedown's Avatar
HavaTitan. Is this what you are talking about?
My dash has a rattle also. It started on my '05 CC SE just two months ago after four years and 48,000 miles. It occurred to me too that it might be a speedo cable because it evoked memories of the sound my 1995 GL1500 GoldWing's speedo cable made when it went bad. So, since we don't have speedo cables just what in hades can be rattling in there?? When I am sitting at idle there is no noise. It appears that it is vibration sensitive because I hear it at near 55 mph and above and when the pavement is super smooth it rattles less. It seems to come from under the dash between the right side of the instrument cluster visor and left edge of the dash speaker. When I hit it with my fist the rattle get a little worse. I have a good tech but I have put off having him look at it as he will have to tear the dash apart to fix it. I am going to ask him if he thinks it will be better for him to do the job at the Stealership or at his small garage shop.
Shakedown is offline   Reply With Quote
Old 08-03-2009, 03:03 AM   #5 (permalink)
HavaTITAN's Avatar
shakedown, you can do this very easily with a putty knife (or even a butter knife) and a little bit of thick foam. Just pop off the vent cover and stick the foam between the dash and metal cowling up by the windshield. The dash plastic sags very close to the metal cowling that any vibration will cause it to rattle. I will try to post some pic's later this week when I get some time.
Old 08-03-2009, 05:25 AM   #6 (permalink)
titanss's Avatar
Good Fix..........................
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 08-03-2009, 06:19 AM   #7 (permalink)
PRJ
On my '04, I removed the defroster vent cover and tightened all of the bolts that secure the dash to the framing. Rattle hasn't been back since.
PRJ is offline   Reply With Quote
Old 08-03-2009, 07:49 AM   #8 (permalink)
Kronos1965's Avatar
Mine sounds like something hitting a cow bell. (insert gratuitous SNL sketch here)
Is that the sound others are hearing?
Mine doesn't sound like a little can of bb's but more of a "ting ting ting"...
HippieWhore™
Kronos1965 is offline   Reply With Quote
Old 08-07-2009, 01:28 PM   #9 (permalink)
BikerD's Avatar
Kronos I have the same thing and I have no clue wht it is.
BikerD is offline   Reply With Quote
Old 08-08-2009, 10:23 AM   #10 (permalink)
titan14's Avatar
I had a noise coming from the dash. Put a piece of clear, thick, tape between the top of the instrument cluster and the dash and it went away. It had a sqeeky sound, so if anyone has that, it would be a good place to look
titan14 is offline   Reply With Quote
Defroster rattle fix (hopefully) dragonhead08 Titan Problems & Dealer Service 4 11-23-2005 04:17 PM
Rattle fix adjmcloon Titan Problems & Dealer Service 0 02-13-2005 08:16 PM
Found another rattle and the fix! TallTexan Titan General Discussion 3 01-03-2005 09:32 PM
anyone try to fix the rattle in the dash on the passenger side? titanmike Titan General Discussion 6 05-01-2004 10:19 AM
Another Rattle Fix... titanized Titan Problems & Dealer Service 2 04-22-2004 04:34 PM
