Rear axle shaft removal - Nissan Titan Forum
post #1 of 4 (permalink) Old 08-18-2009, 10:01 AM Thread Starter
iTrader Score: 0 reviews
Hello all. New member here and am amazed at the wealth of knowledge on this site. Unfortunately my first post is a question.
I have a 2007 Titan tow package and am replacing the rear parking brake shoes. The reality is the parking brakes on this vehicle are poor and due to that and my stupidity have driven on a couple of occassions with them on. Not that big of a deal as I recently replaced my rotors and calipers anyhow but was in a ruch and am now replacing the parking shoes and other components.
When I removed the rotor, I damaged the backing plate where the shoe retaining pins are housed. I am now replacing the backing plate but need to remove the axle as the plate does not fit over the wheel stud hub.
Is there any issues I should be aware of when removing the axle? I am presuming that there is an E-clip or similar inside the diff housing that I remove then simply slide out the shaft. Any advice would be appreciated before I finish tearing it apart tonight. Also, what rear end juice is recomended for this vehicle. I tow to the max regularly.
Thanks in advance, Jim
Backtothesea is offline
Advertisement
post #2 of 4 (permalink) Old 08-18-2009, 10:58 AM
BAD 24/7's Avatar
iTrader Score: 7 reviews
Re: Rear axle shaft removal
I'm not too knowledgable in the brake department, but I can reccomend Amsoil Severe Gear Oil 75w/90 for your rear differential.
Hope I could help.
2007 Nissan Titan SE Crew Cab Galaxy Black
HP: 347.6 TQ: 407.2 on 87 octane
PERFORMANCE: Uprev l Stillen LT Headers l Berk B-Pipes l Nismo Exhaust l Grounding Kit l Injen Intake w/ Hydro Shield l Airaid TBS l Stillen Radiator l 3.73 Gears Front/Rear
INTERIOR: Green LEDs l Legit Accessories Green LMU Kit l MTX Audio Thunderform Enclosure l Custom Seat Covers
SUSPENSION: Pro Comp Stage II Suspension with ProRunner Rears l PRG Extended Endlinks l PRG Drive Shaft Spacer l Stillen Front Sway Bar l Metalworx Offroad Trac Bars
BRAKES/WHEELS/TIRES: Stillen BBK l 35x12.50x18 Nitto Trail Grapplers l 18x9 Mamba M5's with Bullet Valve Stems
EXTERIOR: Billet Grille l Custom Colorshift Headlights l Black Altezza Tail Lights l Nissan Skid Plate l Short Bullet Antenna l Hornblaster's Shocker 240 Train Horn Kit l Stillen Diff Cover l BT Mirrors
COMING SOON: Legit Accessories Products l GlowShift Gauges l Custom Hood
BAD 24/7 is offline
post #3 of 4 (permalink) Old 08-18-2009, 11:21 AM
iTrader Score: 4 reviews
75/140 synthetic is the spec for the gear oil in the rear axle.
I don't think there are any clips. It just unbolts and pulls out. Be careful not to damage the axle seal. If the seal leaks, you have to destructively remove and replace the bearing to get to the seal.
bestatchess is offline
post #4 of 4 (permalink) Old 08-18-2009, 05:11 PM Thread Starter
Thanks for the reply. this saves me from draining the fluid.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
looking for a Pass side rear axle shaft 04 SE ineedabin2 Titan Parts & Accessories 0 07-30-2009 11:55 AM
FS. Front Left Axle Shaft spigs21 Buy/Sell 0 01-11-2009 07:30 AM
WTB Front Axle Shaft spigs21 Buy/Sell 2 11-05-2008 10:31 AM
Drive shaft dropped out, rear axle assembly mangled mneviaser Titan Engine, Transmission & Drivetrain 10 09-15-2007 07:21 AM
Has anyone ever bent an axle shaft? rmartinez0203 Titan Problems & Dealer Service 34 01-09-2006 06:12 AM
You may post new threads
You may post replies
