My Timbrens should arrive tomorrow. Looking at the service manual for the Axle/Spring U-Bolt. The Manual calls for replacing the axle U-Bolt nuts when removed. My questions: is why? is this a locking nut? is this really necessary.
Thanks !!!!
2006 SE, CC, Big Tow, white
Born 5/06
oh well... I re-used the nuts and applied Red Loctite. I plan to mark the nuts with a white paint line just to keep an eye on them and verfiy that they don't loosen up for some odd reason.
Install is very easy. Can't wait to see the difference towing
Born 5/06
You will be amazed how something so simple can make that much difference!
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew Cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a 07 Clipper 1465HST Trail ready pop up, and "Cartzilla" Grumpy Old Man Club http://s3.bite-fight.us/c.php?uid=214743
You should do a write up on the install. I have been thinking of adding these myself. Were putting them on my mothers Titan, she tows a 5th wheel. When talking to Timbren themselves, if your truck still sags, they will send you additional spacers for free.
Do you essentially just loosen the nuts, slide the old bump stop out and slide the Timbrens in and re tighten?
FWIW, I was going to put them on the front when there was a possibility I was going to put a snow plow on my truck.
Essentially Stock 2006 SE 4WD with Bilstein HD's
Security System: Glock
yes, it is that simple! Just tighten the U-Bolts down so @ equal threads are shown for each of the U-Botls at 37 ft-lbs. That is from the Service manual for the Titan.
Born 5/06
