Leaking Axle Seal. . . how far can I drive? - Nissan Titan Forum
post #1 of 6 (permalink) Old 09-04-2009, 08:25 PM Thread Starter
iTrader Score: 0 reviews
One day before vacation (road trip), I find out that my driver-side rear axle seal is leaking. Must've just started in the last couple of weeks cause I just changed my oil and it wasn't leaking then.
How safe is it to drive? If safe, how far? I know it probably depends on how fast it leaks, but if it's isn't streaming out, I think I would be good for some miles.
Thanks!
Pbody is offline
Advertisement
post #2 of 6 (permalink) Old 09-04-2009, 09:40 PM
Duran's Avatar
Send a message via AIM to Duran
Re: Leaking Axle Seal. . . how far can I drive?
its a common thing with our trucks. limit travel check the fluid in the diff with a finger standard stuff really any pics? what year is your truck?
Duran is offline
post #3 of 6 (permalink) Old 09-04-2009, 09:49 PM Thread Starter
Nope, no pics. . . . yet! It's an '05. 138k. Not too many problems since new, but this one fo'sure. It's just bad timing with the planned vacation. Don't know what to do.
One thought, since the axle vent becoming clogged seems to be the root cause of this issue, would it help to take the little metal cap off the vent? I took it off to see what is going on down there. Under the cap is a light spring and a round flat piece of soft plastic (almost rubber), like a penny, just smaller. The spring applies pressure against the plastic "penny" against the axle vent. Inside the vent, nothing. Stuck a small pick in there and nothing.
Pbody is offline
post #4 of 6 (permalink) Old 09-04-2009, 10:12 PM
Don't run it with the vent removed. Get a new one, or do the mod.
I came into this world naked, screaming and covered in someone else's blood I plan on leaving this world the same way.
helomech is offline
post #5 of 6 (permalink) Old 09-04-2009, 10:17 PM
desertruner09's Avatar
iTrader Score: 1 reviews
I personally would do the vent mod if it were me. I've had no problems with my seals since I've done the mod. As for the leak, its really kinda hard to tell you if its unsafe without seeing it. My axle was just kinda wet around the seals, but it wasn't dripping on the rims or anything like a few I've seen. If it is just a little wet, then you should have no problems. Heck, I drove for probably 10K miles before I got my seal fixed.
2006 Titan 2wd CC SE Granite w/Big Tow with 150K miles
2006 BMW 330i w/Sport Package as my DD
desertruner09 is offline
post #6 of 6 (permalink) Old 09-19-2009, 10:58 AM
dgood's Avatar
How much did it cost to have the seals replaced?
dgood is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Rear Axle Seal Leaking sigep1967 Titan Engine, Transmission & Drivetrain 2 06-25-2009 05:14 AM
Axle Seal Leaking....again!!! 54warrior Titan Engine, Transmission & Drivetrain 13 04-01-2008 07:10 PM
How do you tell if a axle seal is leaking Wiscdave Titan Problems & Dealer Service 10 11-16-2005 02:34 PM
Another leaking Axle Seal?? 54warrior Titan Problems & Dealer Service 7 11-14-2005 03:20 PM
Rear Axle Seal Leaking?? JimB Titan General Discussion 15 10-11-2005 06:50 PM
You may post new threads
You may post replies
