$2200 for virtually nothing!
quote from that site ".... Recommended tire size with lift is 315/70/17 or comparable. Shocks sold separately. Price - $2195.00"
other than cool looks what functional improvement is an 8" lift if 315mm tires are the widest tires you can switch to (which will only be 2" taller and 1.3" wider than stock 280/70/17s)?? price for new 315 tires are $800, another $800 for new 8.5" wide 17" rims.
so $3100 to $3900 will only gets you about 2" taller and 1.3" wider tires, but drastically upset rollever balance by truck being 8" taller while ground clearance will only increase by 1"...
not the most off-road performance enhancing move, unless looking cool is the goal.
note: 1" = 25.4mm
Twenty Aught Four Titan KC 4x4 SE, Smoke: Off-Road/Bench 6-seater.
"The state that separates its scholars from its warriors will have its thinking done by cowards, and its fighting by fools," Thucydides.
