Old 10-27-2009, 08:57 AM   #1 (permalink)
noise in vent position when turning knob
when I turn my vent controll from all to the right defrost position to the vent position i get a cllicking noise like a plastic gear is striped and it will not stop untill i turn it back to the right has anyone had this happen and is the elect componet on the heater box to the right of the gas pedal? I feel the clicking at that device
kyle797 is offline   Reply With Quote
Old 10-29-2009, 10:15 PM   #2 (permalink)
Re: noise in vent position when turning knob
Not sure if it is the same. But, I had a clicking noise when I turned the fan on, and it would get louder when I turned the fan up. I took it to the dealer and they replaced the A/C fan.
grpape is offline   Reply With Quote
Old 11-04-2009, 03:19 PM   #3 (permalink)
PRJ
There is a bad actuator and it's skipping gear teeth. Do a search. There are many threads on this problem.
Nissan revised the part(s) causing this problem. Mine does the same, I just haven't had it fixed yet.
PRJ is offline   Reply With Quote
Old 11-04-2009, 08:41 PM   #4 (permalink)
Mine just started doing that last week and im getting it fixed on saturday. They said the same thing it's a gear and it bent and it doesnt hit the stop anymore and it thinks it can keep going.
Dino0085 is offline   Reply With Quote
Old 11-08-2009, 07:33 AM   #5 (permalink)
happened to me a couple of months ago, the problem is the gear
richkcmo is offline   Reply With Quote
Old 11-16-2009, 05:36 AM   #6 (permalink)
CaptFDU's Avatar
Is this a warranty problem? I have an 05 and this just happened to me this morning.
Capt. Trip Franklin
Florida Down Under, Inc.
PADI Master Instructor
www.fdu.com
05 LE 4x4 Crew Cab Deepwater Blue (Green)
Helper Spring Mod
Armada Air Dam
SilverStar Hi and Low
K&N CAI
Engine Cover Painted
Custom exhaust single in/ dual out with Flowmaster 70
Amsoil 75/140 Front and Rear Diffs
Amsoil 0/30 Oil
Remote Tranny Filter (extra quart)
Flex-a-lite Dual Electric Fans
Throttle Body Bypass
Titan "Black Box" Mod by ProAuto in Ft. Meyers
Hellwig Sway Bar (Awesome mod, Don't know how I drove without it!!!)
UnderCover Hard Bed Cover
CaptFDU is offline   Reply With Quote
Old 11-16-2009, 07:42 AM   #7 (permalink)
PRJ
No, it's just a problem. If you have less than 36,000 miles it will be covered under warranty. Although my local dealer tells me the revised part didn't fix the problem.
Old Yesterday, 10:53 AM   #8 (permalink)
SLASH 2008's Avatar
hey same here on my 05 se after i change the fan to something different it clicks for about 30 seconds then stops pretty annoying but sounds like a pain to fix. after i shut my truck off and about three minutes go by just sitting there it will do it again it's really weird it does it for about 30 seconds again and i didn't even touch any thing. really weird
SLASH 2008 is offline   Reply With Quote
Noise after turning off Manny Titan Problems & Dealer Service 6 02-18-2007 07:24 PM
Noise when turning... JoshU Titan Problems & Dealer Service 7 12-26-2006 10:04 PM
Thunking noise when turning FLTitan32539 Titan General Discussion 9 05-16-2005 02:45 PM
Noise when turning right. TriKKy Titan Problems & Dealer Service 2 02-07-2005 11:18 AM
Vent/defrost/air flow control knob rockwalltitan Titan General Discussion 7 12-19-2004 07:39 AM
