sorry about that!! It's been a long month
the kit came in, in just 4 days after winning the bid and the communication between the seller was near;y instantaneous, not to mention he had the cheapest prices
materials...
the leather used is actually really nice but like the factory leather and most other leather manufacturers there is a lot of use of vinyl. In the rear seats only the middle of where your back and butt are toucking are leather and all other panels a re a high quality vinyl. In the front seating the entire faces are leather.
Fit...
The rear seats were a perfect fit b/c of the prodigious use of vinyl and the front seats were a bit loose b/c of the use of leather, but it shrank after a couple of days in the heat to a factory fit! All seams perfectly lined up and no one will notice that it looks aftermarket.
Install...
After removing the seats the install was done with just 2 tools(hog ring pliers and snips) I installed mine over a week. I would remove a seat and just work on it in the garage and then replace. I estimate about 2 hours per seat max. Remember I have never done any type of upholstering
The hardest part by far is the headrest since they are so tight and the next hardest would be closing the damned end clips for the rear seats. It just takes some bruised hands but you will do it.
BEFORE
AFTER
07 CC xe 4x4 the "work truck"
pro comp lift
sway away coils and rr shocks
deaver leaf pack(W/1.5" block and traction bars
ebay special step (just for the prego wife)
2in-2out magnaflow
afe intake
35" hankook MT and kmc XD enduros
krylon paint on the rr bumper
