Old 06-02-2004, 05:22 PM   #31 (permalink)
TNT TITAN's Avatar
Originally Posted by gero
another pic.
They ought to come from the factory that way, probably would sell a bunch.
TITAN SE 4X2 CC: OFF ROAD PACKAGE, TOW PACKAGE,ROCKFORD FOSGATE,MAGNAFLOW DUAL EXHAUST, AIR BOX MOD WITH K&N DROP IN, PRERUNNERS LEVELING KIT, AIRRAID THROTTLE BODY SPACER
TNT TITAN is offline   Reply With Quote
Old 06-02-2004, 05:26 PM   #32 (permalink)
My dealer sells em that way. Although I would have put a lift on it anyway, I test-drove one at a dealership and was sold. I think I could save some money buyin a lift outside of the dealership, but sellin em like that wouldn't be a bad idea!
TrojanDan is offline   Reply With Quote
Old 06-02-2004, 05:49 PM   #33 (permalink)
Send a message via AIM to MaxPowers
4x2 and a KC. Yes that was the price including labor, it was a good deal. Yes i have 35's. That is the biggest size that you can fit under the lift.
MaxPowers is offline   Reply With Quote
Old 06-02-2004, 06:01 PM   #34 (permalink)
Did you try 37s? Or were you not even interested in them?
Old 06-02-2004, 06:30 PM   #35 (permalink)
Well my tires in the front barely rub but that is because i have 17x10 wheels, but the system goes better with 17x8. It says on a couple of websites that it is designed to fit 35"s. I doubt 37s would fit at all.
Old 06-02-2004, 08:19 PM   #36 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Hey Max, I've seen you cruising around east county (I think). Nice looking truck!
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 06-02-2004, 08:22 PM   #37 (permalink)
SarkaZm's Avatar
Oh yeah, almost forgot...is it possible to have a level lift with the CTS kit? Or will the front be higher than the back all the time? Thanks
More Pic's Here
Old 06-02-2004, 09:02 PM   #38 (permalink)
I'm wondering the same thing. Lift kits as high as 8" usually level trucks out. You're truck looks good, but it looks like you need 37's. The wheel wells seem a bit too big, kinda empty. You really rub w/35s? Could probably take a sawzall to the wells and shave em down a little, make 37s fit. Maybe a 2 or 3" body lift? Any more lift might make 37's look too small though.
Old 06-02-2004, 10:56 PM   #39 (permalink)
I have a 1 inch spacer due to the wide rims. I would never get a body lift, had one before on old truck and hated it. I'm pretty sure the wheel well in the front has a little bigger space in the back on most cst lifts, ask Gero, i'm not sure. I have yet to see your nice truck sarka, but make sure you honk if you see me.
Old 06-03-2004, 01:20 AM   #40 (permalink)
sorry about not replying sooner --answers trojandan
How much was the lift, and how much did it cost to install?
first of all, my dealer wanted $8000 more for a lifted titan... i test drove it and did the lift myself.
the lift was $1995.95 ... $2600 installed by SoCal Supertrucks special deal pm me for details if you're doing it in socal-- I think that they ask for $3200 if you call them today)
how much did the wheels and tires cost you? $850
315/70/17 tire with 8" wide wheels with 5" of backspacing
centerline stingray III's were $100 each
BFG AT 315/70/17 were $250 each at costco, but I can get a set of 4 for $400 (pm me when you're ready to buy tires) it was $50 to mount/balance them. (oh and $20 for wheel locks)
about the lift
The kit achieves 8" of lift using a solid one piece subframe that provides a strong foundation for the lift kit and the truck. The kit also utilizes new 1/4" steel to construct the new lift spindles that are laser cut for precision, and fully mig welded for additional strength. Also included are a set of replacement upper control arms with integrated 1" uni-balls to replace the weaker factory ball joints, and new extended front brake lines.
To lift the rear the kit uses a new 4" block and u-bolt kit. .
i hope that answers your questions.
gero
gero is offline   Reply With Quote
Old 06-03-2004, 09:21 AM   #41 (permalink)
Thanks for the in-depth answers Gero. Sounds like the lift kit covers everything, even brake lines (are the new brake lines steel?). I'll definitely pm you in a few months, when I'm ready to lift. My dealer wanted around $3500 for the lift, another $2500 for wheels and tires, and other costs for teh banks and grille they put on. Hope you're still around in Nov. or Dec!
Old 06-03-2004, 03:20 PM   #42 (permalink)
no worries.. glad to help
right on! just pm me when you're ready to lift it.
gero
Old 06-08-2004, 05:47 PM   #43 (permalink)
gotjumps's Avatar
Do you know when the CST lift for the 4X4 will becoming out
gotjumps is offline   Reply With Quote
Old 06-08-2004, 05:51 PM   #44 (permalink)
I emailed them a couple of weeks ago. They got back to me late last week saying that a kit for the 4x4 should be out in several weeks (for CC and KC). I think that means that it'll eventually be out by July or August at the latest, cause usually they are later than they say they'll be.
Old 06-13-2004, 01:31 PM   #45 (permalink)
TitanRAGE's Avatar
lots of good info, beautiful trucks guys. i cant wait to get one.
2005 SE in Silver
4x4 CC
utility package
RF stereo w/xm
Tow package
bed ext.
TitanRAGE is offline   Reply With Quote
