...there's nothing wrong with them - though I did receive one cracked and...talked to customer service today and they indicated a replacement would be sent right out - we'll see.
What I meant was that these cost $100.00 and now that I have them, I have to say "ehhh". The one "feature" I do appreciate is the fact that the flanges sit inside the window channel (no adhesive). As far as effectiveness, I never had a problem with the AVS adhesive brand on my Frontier and they are considerably less $$. I will admit that the Weathertech looks a little more sporty, just not $40-$50 worth.
CAUTION ON INSTALLATION!!!
FOR THE ENTIRE INSTALLATION PROCESS, PAY VERY CLOSE ATTENTION TO THE FRONT END OF YOUR BOTTOM WINDOW FRAME (JUST BELOW THE SIDE-VIEW-MIRROR). THE BLACK
EXTREMELY THIN MATERIAL THAT RUNS THE LENGTH OF YOUR WINDOW WILL SCRATCH (AND REVEAL SHEETMETAL) IF YOU SO MUCH AS LOOK AT IT THE WRONG WAY - IT IS VERY EASY TO SCRATCH THIS WITH THE PLASTIC FLANGE ON THE MIRROR END OF THE RAIN GUARD (THE ONE YOU WERE ASKING ABOUT)...
and yes, that piece is meant to sit outside your window on top of your window frame (hence the scratching if your not careful). This is this way for a reason and will make sense to you after you install.
Best advise, read the directions 3x before you install (do not follow the "alternative" directions on the back).
Good luck!!
