Old 05-06-2004, 07:27 PM   #1 (permalink)
cttitan's Avatar
MR Grille and zip tie longevity question
Having seen how well zip ties don't hold up when used outdoors I would be concerned about the longevity of the ties.
If you have installed one of these billet grilles do you think there is a better way to attach the grille using a different method, hopefully a little more permanent?
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
cttitan is offline   Reply With Quote
Old 05-06-2004, 08:07 PM   #2 (permalink)
CaliforniaTitan's Avatar
You could but you would need some patience and hardware.....
In between the billet lines you see the mounting braces are tacked to the back (Flat pieces).
With a lil inginuity and some very small black nuts and bolts...I don't see why you couldn't lay a flat piece of metal bar behind the grille --- drill a hole through the braces and the bar behind it and 'pinch' the grille in between with the nut and bolt.
There is NOT a lot of room between the billet lines there...as wide as the twist ties thats why they hide so well. So your hardware would have to be small and your drilled holes even smaller...
Another idea would be to fabricate a mount that comes in from the backside that could be tack welded to the back of the grille and bolted somewhere behind the factory grille...
ITs all up to how much work you want to put into it and how inventive you are.
Chris
Old 05-06-2004, 08:35 PM   #3 (permalink)
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
I had a billet grill held on by zip ties on my Durango for 5 years. It didn't slip or budge at all over that time and I beat that truck really hard.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
Old 05-07-2004, 09:40 AM   #4 (permalink)
I had the spare tire carrier on my Ranger held up by one of the smaller sized zip ties for 3 years. I think the grill may be ok too.
Davace97 is offline   Reply With Quote
Old 05-07-2004, 01:36 PM   #5 (permalink)
dman's Avatar
Hmmm...we regularly use high quality zip ties at my parents boat dealership to hold steering cables, hoses, wiring, etc together w/o any problems whatsoever for years. If they are decent quality this should not be a concern. Besides that if you have 10 of them holding on your grill, even if one or two broke you wouldn't be losing much strength. Just check them every time you change the oil and you should be fine.
dman is offline   Reply With Quote
Old 05-07-2004, 03:39 PM   #6 (permalink)
If zip ties make you that nervous, you can get a bolt on grill.
