Old 06-13-2004, 05:09 PM   #1 (permalink)
running board lights
more free weekend time...
NexLite Running Lights - a discreet, chrome accent - the lights look awesome. Install was about 4 hours.
running-board-lights-dscf0026.jpg  running-board-lights-dscf0031.jpg  running-board-lights-dscf0052.jpg  running-board-lights-dscf0047.jpg
Born On 12-15-03
King Cab LE
Radiant Silver
newenglandtitan is offline   Reply With Quote
Old 06-13-2004, 11:34 PM   #2 (permalink)
1blackx's Avatar
Looks Good! Can we have a picture of them at night?
1blackx is offline   Reply With Quote
Old 06-14-2004, 07:22 PM   #3 (permalink)
as requested...
not as bright as the pictures would have you believe - even the slightest camera shake attenuates the brightness.
running-board-lights-dscf0007.jpg  running-board-lights-dscf0015.jpg  running-board-lights-dscf0024.jpg  running-board-lights-dscf0025.jpg  running-board-lights-dscf0027.jpg
Born On 12-15-03
King Cab LE
Radiant Silver
Old 06-20-2004, 09:47 PM   #4 (permalink)
DallasTitan's Avatar
Man that looks great!
How did you do the wiring?
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
DallasTitan is offline   Reply With Quote
Old 06-21-2004, 12:59 AM   #5 (permalink)
1blackx's Avatar
Thanks. Those do look awesome. You do good work!
Old 06-21-2004, 06:50 PM   #6 (permalink)
connection info
The leads are run up inside the door panel (from under the running boards) an dtucked away with Silver (ahem, grey) electricians tape. They run to the inside of the cab through the already existing wire-duct used by the door and mirror wires. They then connect to a newly added illuminated switch and off to the +12v (on with accessories only) connection I ran from the BCM. I could have alos run them to any of thelighting connections (Fog, Headlights or DRLs) but I wanted independant operation. The 2 sides of the truck are connected via an electricians wire duct (heavy aluminum) which runs across the truck - waterproof, scruff resistant and not the lowest point under the rig. Pretty straight forward actually.
running-board-lights-dscf0006.jpg  running-board-lights-dscf0014.jpg  running-board-lights-dscf0018.jpg
Born On 12-15-03
King Cab LE
Radiant Silver
Old 06-22-2004, 01:00 PM   #7 (permalink)
I especially like the metal ducts underneath and lighted switches on the lower dash.
How do your extra fog lights in the lower grill come on?(other switch locations?)
Purchased 12-12-03
Old 06-22-2004, 05:24 PM   #8 (permalink)
DRL Connections
The DRL relay connection has power applied only while the key is in the "ON" position (turned on/off via a wireless remote). Some photos of the relay and remote receiver I needed to seal the deal. The photos have prompted me to go clean this wiring up - I should be ashamed of myself!
(Ken, I should have posted this here in the 1st place )
Good luck
p.s., the second illuminated switch is not currently connected - but I'm sure I can come up with a need for it - it's a solution looking for a problem. Volant Air Intake on it's way...stay tuned.
Born On 12-15-03
King Cab LE
Radiant Silver
