Old 06-15-2004, 01:36 PM   #1 (permalink)
Aftermarket Door Speakers
Has anyone actually installed aftermarket door speakers? I did numerous searches, but all the posts talk about plans to do it, or speakers they have in other vehicles. I plan on swapping out the RF head unit with an Alpine or an Eclipse unit with XM capability, and getting all new door speakers. Right now I am considering Alpine, Eclipse, and Infinity speakers. Any thoughts? I have heard good things about Infinity, except that the Reference series sucks. Eclipse only seems to be a available at Good Guys or at Al n Eds Autosound.
Along the same lines, are component speakers superior to non-component systems? What are the mounting considerations?
Thanks in advance.
2004 Nissan Titan Crew Cab LE 2WD
Smoke - Graphite/Titanium
socalsharky is offline   Reply With Quote
Old 06-15-2004, 01:46 PM   #2 (permalink)
joel's Avatar
Thanks in advance.
6X9's in the front doors. The doors have plastic mounting baffles that hold the driver away from the door cavity. I think crutchfield or somebody makes a 6X9 to 6.5 adapter. I removed the plastic and mounted a chunk of 3/4" mdf with a hole to hold 6.5's. There's plenty of room to hide crossovers under the dash and it wasn't too difficult to place the tweeters at the stock location in the dash.
I used Memphis Audio components because I have a local dealer that offered very good prices. I didn't even bother with rears because I think they screw up good stereo imaging.
KC SE Galaxy
joel is offline   Reply With Quote
Old 06-15-2004, 05:51 PM   #3 (permalink)
Send a message via AIM to MaxPowers
Are you saying you put the tweeters in the spot of the dash that points straight up to the ceiling? I was told not to put the tweeters there because and to put them in the door because it would sound a lot better since i would guess they are pointing right at you.
MaxPowers is offline   Reply With Quote
Old 06-15-2004, 07:47 PM   #4 (permalink)
joel's Avatar
It's subjective. If your speakers offer an easy way to mount the tweet to the mid, try it both ways. Choose that which you like better.
KC SE Galaxy
