Old 06-23-2004, 12:56 PM   #1 (permalink)
Installing Aftermarket Radio Tonight...
I will be installing an aftermarket radio tonight into my '04 Titan SE 4X2 w/Popular Package (indash 6 disk)
Heres what I have so far....
I bought the wireing harness from crutchfield.com
Link to Harness
And I bought the XE Center Console Bezel Panel
so....i dont know how the stock radio is installed...will i need aditional hardware to mount the aftermarket one? Any other information I might need? any heads up on some time saving tips/tricks?
Thanks in advance!
-Beaker
Beaker is offline   Reply With Quote
Old 06-23-2004, 01:02 PM   #2 (permalink)
smoketitan's Avatar
Id highly recommend that you spend $20 and download the service manual from nissan, it will save you a tome of time with wire colors
and if you do search for stereo--I belive you will need a pathfinder mount box to fit your stereo in if it is a single DIN size
good luck
Old 06-23-2004, 02:10 PM   #3 (permalink)
I checked Nissan's web site, and it says $200 for the service manual, not $20. I know others have said they downloaded the manual for $20 from Nissan, so they must have raised the price.
Drew is offline   Reply With Quote
Old 06-23-2004, 02:32 PM   #4 (permalink)
$200?!?!?!?! you gotta be F'n kiddin me.
With my VW i got a full bently manual that basicly coverd every nut n bolt and wiring schematic of the car for $40....and that was a paper back book about 3" thick.
nissan has to be out of their mind to charge $200 for that.
anyways, sorry to vent, but back on subject....
For reference, here is a link to the universal mounting kit/cubby hole piece as described above:
METRA 88-00-9000 FORD/MAZDA/NISSAN/TOYOTA/VOLVO MULTI-POCKET
-Beaker
Old 06-23-2004, 02:34 PM   #5 (permalink)
also, i want to add.....
you wont really need to know the wiring color code (buying the overpriced manual) if you are using the wiring harness.......right?
Old 06-23-2004, 02:39 PM   #6 (permalink)
joel's Avatar
The harness wire colors/markings should match with what comes with the HU.
Just make sure you disconnect the neg. terminal on your battery before you yank the bezel. The damn airbag light will flash otherwise.
KC SE Galaxy
joel is offline   Reply With Quote
Old 06-23-2004, 02:50 PM   #7 (permalink)
-Beaker
Nope- you're looking at the CD version that's $200 smackers. 20 bucks buys you a look "on line " at the manual in PDF format - icon looks like a eyeball. You can download/save that by section (43 files) for 20 bucks/1 day subscription. Caution - some of the files/sections are big so don't try with dial up unless you have all day.
Born 6/04 Silver LE KC 4x4 Big Tow,Side Air Bags,Mats,SL Extender,SL Divider,Truxedo Low Pro,Nissan XM Sat,Weatherflectors
Stitch is offline   Reply With Quote
Old 06-23-2004, 03:00 PM   #8 (permalink)
smoketitan's Avatar
yep you will need the manual as I doubt that those connectors will match the current titan color coordination (lloking at the pic--I know they dont match, and believe me the service manual is a godsend. to access the page to download the manual ( you have to setup a login account name first. I would post it, but the AV section is 2.45mb--
GOOD LUCK
Old 06-23-2004, 03:06 PM   #9 (permalink)
-Beaker
That kit may work but it is a single DIN, you really need a double DIN. A kit that works is Metra 99-741 Univeral Nissan. I just used that one to install a Blaupunkt in my KC LE. This provides a single DIN opening plus a pocket to fill up the extra space in the dash. Use the side mounting brackets that give you a distance from the back of the mounting ears to the front of the mounting bracket of just a little less than 2.5 inches. You will have to drill a hole in each of the mounting ears to allow for the alignment pins that are between the mounting holes in the dash. Also there are a number of mount 'ears' that must be cut off the bracket in the kit for it to fit - a dremel tool is very handy for this.
The air bag warning light will blink if the plug is removed from the light on the bezel and the ignition key is turned on. If the ignition is off while you unplug the light connector and remains off until you replug into the new bezel, it should not be a problem. Even if it does blink after your installation, there is a method described in the FAQ thread for resetting the warning indicator - it worked for me.
Use the wiring info that came on the package for the wiring harness from Crutchfield and there will be no problem there. The harness is plug and play. The only colors you need to match up are the wires out of the harness to those of your head unit. Once that is wired, plug into the Nissan plugs removed from the Nissan head unit and you are good to go.
good luck on the install - it will sound much better when you are done.
Old 06-23-2004, 03:16 PM   #10 (permalink)
Thanks for the clarification. Where on can I find the online manual on the Nissan web site? I looked all over for it and can't find it.
Thanks.
Old 06-23-2004, 03:20 PM   #11 (permalink)
GOOD LUCK
so what is it guys? will this harness work or not?
Old 06-23-2004, 03:27 PM   #12 (permalink)
With the wiring harness which has mating sockets for the plugs in the dash there is no need to know the wire colors in the Nissan dash harness.
If you were going to tap into the Nissan harness without using the adapters then you would need to know the pinouts (wire colors) of the in-dash connectors. But this is not your case.
Old 06-23-2004, 04:48 PM   #13 (permalink)
thats what i suspected, but smoketitan said that the wires on the wiring harness are not right ....and that he could tell just by looking at them....
i guess ill find out the hard/easy way....
Thanks!
-beaker
Old 06-23-2004, 05:01 PM   #14 (permalink)
Thanks!
-beaker
Just for info: I installed a Blaupunkt head in my KC LE using the same wiring harness you will be using. Prior to this vehicle I have had the same radio in two other Nissan vehicles, I made no wiring changes on the adapter harness. All speakers, power etc. work as required.
Since I have the Fosgate radio and its pitiful amp, it was necessary to do some strapping at the amp connector to get the speakers to 'play through', but the mid-level radio you have does not have an external amp, therefore the strapping I had to do is not something you have to consider.
Enjoy your new radio.
By the way - which head unit will you be using?
good luck
ralph
Old 06-23-2004, 05:09 PM   #15 (permalink)
Thanks for the info!
I will be using the Kenwood MPV-6022
This is the deck i had in my VW....reason i went with it is because its color scheme closest matched the blue/red theme of the OEM dash lighting.
its Sirius ready with mp3 n such....i already have the reciever and antenna....paying the $40 for the bezel and $14 for the wiring harness beats the $370 for the OEM XM reciever and antenna
