Old 07-10-2004, 01:22 PM   #1 (permalink)
naming a cd in the RF CD changer
How do you name a disc or track in the RF system. Is there a file I need to burn onto the CD so that the RF system can display the CD title and Track?
2004 Nissan Titan KC LE 2WD
K&N Drop In (I don't feel a difference from stock)
OEM bug shield
VentVisor Window Vents
avpoh8 is offline   Reply With Quote
Old 07-10-2004, 05:55 PM   #2 (permalink)
Big Platinum's Avatar
I just burn the Cd under MusicMatch and whatever the title is on MusicMatch, that's what comes up on the CD player.
CC LE Smoke
JBA Cat Back Exhaust
K&N CAI
10" Fosgate He2
-Emerson
Big Platinum is offline   Reply With Quote
Old 07-11-2004, 12:42 PM   #3 (permalink)
mick3643's Avatar
re:naming a cd in the rf cd changer
This may not be your problem but One thing i noticed is the cd's i burned with an older cd burner and software did not put the names on the cd's but the cd's i burned after i got a new cd burner and software abuot a year ago put the names on there. I don't know if it was the burner or the software or a setting i was missing on the old software.
mick3643 is offline   Reply With Quote
Old 07-11-2004, 12:57 PM   #4 (permalink)
Sammy Sandbag's Avatar
It would be the software. Depending on what you use, there should be some option to title the cd.
-Counsel Yourself
Old 07-11-2004, 02:36 PM   #5 (permalink)
It's called CD TEXT and if you don't have that option when you burn, it's not going to show anything.
Try searching through your software's help, and it should come up (if it can do it)
Swankmonkey Racing
syntrix is offline   Reply With Quote
Old 07-11-2004, 05:07 PM   #6 (permalink)
I know the newer version of MusicMatch does it automatically but all my older CD's on the outdated software versions don't have titles.
CC LE Smoke
K&N CAI
10" Fosgate He2
-Emerson
Old 07-11-2004, 08:31 PM   #7 (permalink)
hawkeye680's Avatar
Send a message via AIM to hawkeye680
I am almost certain it is reading the "ID3" tag of the song. The easiest way to edit the tags of the song is to use WinAmp. You can use a lot of programs to do this, I just prefer WinAmp. When the song is in the playlist, right-click on it and view the file info. Here is where you can edit the tags.
Galaxy Black KC XE 4X4
hawkeye680 is offline   Reply With Quote
