Old 07-12-2004, 03:05 PM   #1 (permalink)
adding screen to stock dvd.
i have a few questions someone might be able to help me with. I have the stock dvd system with the single screen. I want to put one up front also but im not sure how to do it. Is it as easy as finding the 2 input wires going into the stock screen and running them to the new screen? If so does anyone know the colors of the 2 inputs, and which is the pos and neg? thanks for any help
piopremier is offline   Reply With Quote
Old 07-12-2004, 03:28 PM   #2 (permalink)
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
Refer to Owner's Manual for DVD entertainment system operating instructions.
Power is supplied at all times
 through 20A fuse (No. 31, located in the fuse and fusible link box)
 to DVD player terminal 16.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 4, located in the fuse block (J/B)]
 to DVD player terminal 15.
Power is also supplied
 from DVD player terminals 31 and 32
 to video monitor terminals 11 and 12.
Ground is supplied
 to DVD player terminal 22
 through body grounds M57, M61 and M79.
Audio signals are supplied
 through DVD player terminals 1, 2, 3 and 4
 to audio unit terminals 34, 35, 36 and 37.
Video signals are supplied
 through DVD player terminals 23, 24, 28 and 29
 to video monitor terminals 5, 6, 7 and 8.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
Old 07-13-2004, 10:53 AM   #3 (permalink)
yeah, i have the manual i just don't know how to read it. I can't figure out the color of the 2 wires that i need to splice into for video input to the second screen. I know how to get it power and stuff already.
Old 07-13-2004, 11:27 AM   #4 (permalink)
TriKKy's Avatar
Here is something that I have in my Honda, that I will get in the Titan:
www.avelectronic.com
Works perfectly.
1.
Old 07-13-2004, 11:48 AM   #5 (permalink)
I don't know anything about video splitters in cars, but in my house I had to use an amplified splitter.
Old 07-13-2004, 01:33 PM   #6 (permalink)
ensclark's Avatar
Send a message via AIM to ensclark
Does this make both screens show the same thing or are they still independent? How hard of an install is it? Where is the best place to put it? Where are you running the wires? If you can, show some pics of the install. You've got my curiosity up and my head working on playing with my truck more on the inside. Do tell do tell.
tks
White LE CC 4X4, OffRoad, Big Tow,Nav, DVD, back up sonar, sun roof, bug and window deflectors, Westin Bull Bar, K&N aircharger, A.R.E. bed cover, Centerline Stingray III's 17X8s, Utility Bed Package, W/ sliding bed extender and divider, Side air bags, all leather, Captain chairs. http://www.nitrousenterprises.com/ 3 inch Lift Kit. BFG 315/70-17 A/T
ensclark is offline   Reply With Quote
Old 07-13-2004, 03:22 PM   #7 (permalink)
llajumpvid's Avatar
tks
If you are referring to the Nav-tv its a fairly easy install. I put mine on top of the nav-dvd under the passenger seat. ran the wires through the center console and heeked in behind the monitor. If you get the switcher you can have independant video. The tv tuner system Sam sells I don't believe allows seperate sources playing at once...but you can hook up different sources.
Check out freshalloy.com under the titan/armada page and look for nav-mod finally completed.
llajumpvid is offline   Reply With Quote
